SE Toyota center console wireless charger.
Discussion in '2.5 Gen Tundras (2014-2021)' started by prerunnerseth, Nov 19, 2019.
  1. Nov 22, 2019 at 9:32 AM
    #91
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    cool, thanks
  2. Nov 22, 2019 at 2:10 PM
    #92
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Is the center console emblem easy to switch out? Does it pop in/out or is it glued/taped in there?
  3. Nov 22, 2019 at 2:27 PM
    #93
    prerunnerseth
    prerunnerseth [OP] New Member
    Apex, NC
    2015 MGM Limited 4x4
    Its taped in but theres holes under it. Easy to push it off from underneath. Then just restick it.
    GasGuzzler and KnuckleHD[QUOTED] like this.
  4. Nov 22, 2019 at 5:17 PM
    #94
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Santa is bringing this for me. I usually get a couple little things for myself since my daughter believes Santa brings me stuff too. Last year it was detailing supplies. This year it's this. I got a gift card from work for my 15 year service and it covered this. I wasn't gonna shell the money out but what the hell. I ordered on the 14th i think and was told on the 18th it was backordered. I have a 3 coil in my console now but it's never worked well with my spigen slim armour case, and my ancient galaxy s7
    GasGuzzler likes this.
  5. Nov 22, 2019 at 5:58 PM
    #95
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    Just got this installed. It looks and works great! My only wishes are that the illumination wouldn’t be as bright at night and the color matches the light blue color of the other buttons on the dash instead of the bright green color. Think it would look more oem that way. Other than that, it is great!
  6. Nov 22, 2019 at 6:00 PM
    #96
    Pudge
    CT
    I'm not digging the green much either. Bad choice IMO. One picture I saw in this thread the light didn't look green. Does it change when you place the phone down?
    GODZILLA and Voyagermike like this.
  7. Nov 22, 2019 at 6:02 PM
    #97
    MGMTundra251
    yes, color changes to blue when it is charging. It is a darker blue color so it still doesn’t match the light blue dash color
    Pudge[QUOTED] likes this.
  8. Nov 22, 2019 at 6:02 PM
    #98
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I think it’s changes to blue when the phone is on it charging
  9. Nov 22, 2019 at 6:24 PM
    #99
    P-Factor
    P-Factor New Member
  10. Nov 22, 2019 at 7:23 PM
    #100
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    It’s not available right now, just got email from Sparks saying it’s on back order. It also said at least I have a place in line though.
  11. Nov 22, 2019 at 7:29 PM
    #101
    Blue Thunder
    Washington
    Did they give you an date or estimate? I’m in the queue too...
  12. Nov 22, 2019 at 7:52 PM
    #102
    bensky
    bensky PlatinumPro
    Ben
    Utah
    Nope.
    Blue Thunder[QUOTED] likes this.
  13. Nov 23, 2019 at 8:27 AM
    #103
    ejd049
    ejd049 New Member
    2018 Tundra Crew Max TRD Off Road 4X4
    Received my shipping notice to today.
    KnuckleHD likes this.
  14. Nov 23, 2019 at 8:37 AM
    #104
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    From Sparks?
  15. Nov 23, 2019 at 8:55 AM
    #105
    ejd049
    ejd049 New Member
    Yes
  16. Nov 23, 2019 at 9:21 AM
    #106
    KnuckleHD
    When was your original order? Mine was on the 19th. I’m guessing they will slowly get 1 or 2 in at a time..
  17. Nov 23, 2019 at 10:11 AM
    #107
    And1
    And1 New Member
    Andy
    2019 Silver tundra TRD
    Just had to log in today and see this dam.. Just ordered as well...
    GasGuzzler and Blue Thunder like this.
  18. Nov 23, 2019 at 10:13 AM
    #108
    ejd049
    ejd049 New Member
    The 15th
  19. Nov 23, 2019 at 9:06 PM
    #109
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Got mine today. Probably get it put in tomorrow or Monday
    Blue Thunder and KnuckleHD like this.
  20. Nov 24, 2019 at 11:18 AM
    #110
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    It's worth it. Works very well with a my phone case. I'm very happy. :thumbsup:
  21. Nov 24, 2019 at 12:35 PM
    #111
    2chains
    2chains New Member
    Southern Ablerta
    Do you have to drill for the Scosche install on 2019?
  22. Nov 24, 2019 at 1:27 PM
    #112
    shellshock
    Iowa
    2019 TRD PRO
    Got mine installed today. Super easy and clean install. Highly recommended
    yoshi82, Willy224, porkitt and 5 others like this.
  23. Nov 24, 2019 at 2:04 PM
    #113
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    so clean! came out great
    Voyagermike likes this.
  24. Nov 24, 2019 at 2:07 PM
    #114
    shellshock
    Iowa
    2019 TRD PRO
    Mine was just clipped in. No tape
    KnuckleHD[QUOTED] likes this.
  25. Nov 24, 2019 at 4:00 PM
    #115
    Blue Thunder
    Washington
    Please post how well it works, what phone you are using and what protective case you have. All good stuff to know since performance can vary by phone and case.
  26. Nov 24, 2019 at 6:02 PM
    #116
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
    Can the charger be turned on and off when not in use?
  27. Nov 24, 2019 at 6:04 PM
    #117
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    Yes it can. The button on top/front.
  28. Nov 24, 2019 at 6:47 PM
    #118
    shellshock
    Iowa
    2019 TRD PRO
    Its awesome. iPhone 11 Pro with Apple silicone case. It seems to charge fairly quickly
  29. Nov 24, 2019 at 6:48 PM
    #119
    shellshock
    Iowa
    2019 TRD PRO
    Yup. Button on the front.
    It’s green when it’s on and ready. Blue when it’s charging. Red if there’s an issue.
  30. Nov 25, 2019 at 12:55 AM
    #120
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Looks sweet! Can’t wait for mine.
    Anyone know if the trd pro console badge can be purchased and if so what the part number is?
