SE Toyota center console wireless charger.
Discussion in '2.5 Gen Tundras (2014-2021)' started by prerunnerseth, Nov 19, 2019.
  1. Dec 15, 2020 at 1:09 AM
    #721
    MGM2020
    MGM2020 New Member
    Sacramento CA
    2020 MGM Tundra SR5
    6" Rough Country Lift 37" on 22" V2 Monotube Rear L3 Lifted Struts Front
    Well then maybe it's just the Galaxy S20 Ultra because I've tried 2 different ones from Sparksparts and both of them won't continuously charge. I've even replaced my phone with a brand new one.
  2. Dec 15, 2020 at 5:18 AM
    #722
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Which N20 do you have because this does not work with my N20U?
    Edit: The more and more I think about it, I'm wondering if that camera bump is causing most of the issue. Hence, why it affects both my S20U and N20U and not my previous S9+.
  3. Dec 15, 2020 at 5:22 AM
    #723
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Galaxy Note20 5G. Model # SM-N981U
    g6t9ed[QUOTED] likes this.
  4. Dec 15, 2020 at 5:27 AM
    #724
    1UP
    1UP Truck Gang
    Per Google search -
    bulldog93 and g6t9ed like this.
  5. Dec 15, 2020 at 6:53 AM
    #725
    g6t9ed
    I didn't even think to check if it was a software/firmware issue. Thanks for the confirmation.
  6. Dec 19, 2020 at 5:52 PM
    #726
    g6t9ed
    Well, @1UP, you may be right. After updating my N20U to the November update, I tried charging it again recently and it didn't once give me the charge cycle on a 20 minute drive. Things are looking up. Hoping to test some more but so far so good.
    1UP likes this.
  7. Dec 19, 2020 at 6:14 PM
    #727
    JAMES
    JAMES COLORADO TUNDRA
    2016 Colorado Tundra Crew Max MGM
    6" PC Stage II Coil Over 37x12.50x20 Toyo RT 20" Fuel Recoil Wheels N-Fab black Step Bars Splash 5% Window Tinting Clear Mask Protection Premium leather interior with 2-front Heat/Cool seats Viper 5806v Alarm w/ remote start Garmin 2589 Garmin Dash Cam Dual Flo-Pro 3.5 18" Glass Packs Black Chrome exhaust tips Bakflip Bed Cover Weather Tech Floor Mats Bushwacker Pocket style with matching paint TRD Pro Grill Tesla 12.1'' Head Unit Oh Shit handle on Drivers Side Under seating Storage 4.88 Gears NSV LED Light bar Upgraded Sound system with JL Audio Speakers and Sub
    Yes my 12pro max fits. Here's a pic. Although pictured is my Xs max1229473B-D03D-49AD-8463-035077C6C1D9.jpg
    realprotundra[QUOTED] likes this.
  8. Dec 27, 2020 at 4:07 PM
    #728
    AlexJet
    AlexJet New Member
    2021 TRD Offroad CrewMax
    Would it fit Note 10+?
    My original tray does not allowing the phone to sit flat.
    bedfordfalls likes this.
  9. Jan 4, 2021 at 9:44 PM
    #729
    Bodizaffa
    Bodizaffa New Member
    Calgary Canada
    2020 tundra crewmax
    Heritage grill. Black badging on exterior Leer 100xr campy color matched cement grey. AJT black out interior. Painted center surround. 275 70 r18 KO2s Spray bed liner Ellis precision shifter on way Blistein 6112 front and 5160 rear on way Charging tray on way Box led lighting on way Sill protectors on way Kat skinz once my kids stop destroying my stuff Any advice on custom bed storage. It's in the plans
    Anyone know if we can get this in Canada for a fair dollar.
    BravoDeltaRomeo likes this.
  10. Jan 28, 2021 at 10:15 AM
    #730
    bedfordfalls
    bedfordfalls New Member
    Can someone who has purchased the wireless charger provide the actual dimensions of the base? My phone will almost lay flat in the opening of my armrest, but not quite. The area in the front is slightly angled as is the charger. I am trying to tell from pictures that have been posted if the angle on the charger is less steep, and therefore possibly providing a little more room front to back. I don't want to spend the money and then deal with the hassle of a return if it doesn't fit. My local dealer says the part number is no good so I will have to order. My phone, a Galaxy Note 20 Ultra with case is 6 7/8 long. There is a backwards taper at the rear of the opening that my phone doesn't quite tuck into and the slope in the front that prevents the phone from laying flat. 2016 SR5 CM.
    Sorry for rambling. I hope someone help me out.
  11. Feb 28, 2021 at 5:55 AM
    #731
    camron1039
    camron1039 New Member
    Camron
    2021 Tundra Platinum
    How well does it charge through the otterbox?
  12. May 3, 2021 at 8:38 AM
    #732
    wiltech
    wiltech New Member
    Tony
    Lafayette, IN
    2018 Inferno Limited
    Hate to necro this old thread...
    But does anyone have one of these with a S21 Ultra with an OtterBox case (approx. 6.75")? It barely fits in the original tray.
    I checked the local Toyota dealer to see if they had one on the lot with this already installed... but no such luck.
    Thanks
    Tony W
  13. May 22, 2021 at 4:17 PM
    #733
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Exact same phone, exact same case. Looking to find this out as well.
  14. May 22, 2021 at 4:43 PM
    #734
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    It fits! I have a different case but mine has large corners on it, I can only assume they are as big as the Otterbox case. I'll try to get a picture of my phone in it.
  15. Aug 20, 2021 at 5:03 AM
    #735
    redrum448
    redrum448 New Member
    Has anyone had any luck with S21 Ultra being able to charge on the wireless tundra tray?
    mines not working and I think its because the trays voltage isnt steady enough.
  16. Aug 20, 2021 at 5:17 AM
    #736
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Make sure it's not your case. I have the same phone and it wouldn't change in my Otterbox
  17. Aug 20, 2021 at 5:19 AM
    #737
    redrum448
    It doesnt work even without a case, says charger is incompatible and cycles from green to blue. I need to "clean" up the charger power somehow
  18. Aug 20, 2021 at 5:38 AM
    #738
    TucsonTundra1794
    Anthony
    Tucson, AZ
    That's strange. I have the exact same phone and mine works.
  19. Aug 20, 2021 at 5:44 AM
    #739
    redrum448
    what is your software version please? and carrier
  20. Aug 20, 2021 at 5:45 AM
    #740
    TucsonTundra1794
    Anthony
    Tucson, AZ
  21. Aug 20, 2021 at 6:36 AM
    #741
    redrum448
    thanks, mine ends in "AUGQ" not "AUGE" .
    Supposedly all this started with a software update around march 2020.
    Now what Im going to do with that information? no clue lol
  22. Aug 20, 2021 at 6:48 AM
    #742
    primeiro
    primeiro New Member
    Henk
    Netherlands
    it still does not work, even with all the updates and all
  23. Aug 20, 2021 at 8:25 AM
    #743
    redrum448
    seems a "Qi wireless charger" is required.... I take it our tundra wireless chargers arent "QI" certified
  24. Aug 20, 2021 at 8:38 AM
    #744
    g6t9ed
    Taken from the product page for it:
    • Product ID:00016-34506
    • Description:
      This is a wireless charging tray directly from Southeast Toyota that installs in the lid of the center console on the Tundra. Because this is a Toyota part, it falls under your Toyota warranty. It is a direct replacement for the center portion of the lid and reuses the existing vehicle trim badge. It has a simple plug-n-play installation that requires no cutting or drilling.
      This armrest tray contains a three-coil, fast charging wireless charging devise to charge smartphones that support Qi-standard wireless technology. The wireless charger tray provides a convenient location for your smartphone to charge without the need to connect a charging cable. This wireless charger will deliver up to 10 Watts of fast charging to the coupled smartphone. The actual charge rate is dependent on the smartphone brand, model, software version, and the state of the battery to be charged.
      • 10W max output - Samsung Galaxy S7, Note8 and newer
      • 7.5W max output - Apple iPhone 8 and newer
      • 5W max output - Other Smartphones with QI-standard wireless charging
  25. Aug 20, 2021 at 8:40 AM
    #745
    redrum448
    Yeah I read that after i posted, but regardless the newer samsungs with certain software builds arent playing correctly with the tundra charging trays.
  26. Aug 20, 2021 at 8:50 AM
    #746
    g6t9ed
    Agreed. Mine's one of them. At one point, they seemed to have fixed this issue for my S20U and went and screwed it up again. Same for my N20U as well. I haven't tried in a while with either but I do notice it cycles a lot less when the vehicle isn't moving. Both phones have cases. I've been looking at alternatives currently and I won't get rid of the wireless charger as I like the flat surface compared to the ridged one.
    I haven't met anyone that had an iPhone with the issue though but that has been a while and according to some of the replies here, it seems to not just be a Samsung thing.
  27. Aug 20, 2021 at 8:52 AM
    #747
    redrum448
    Its my understanding its a safety issue implemented by software from the manufacturer (apple or samsung doesnt matter) if the phone detects a wireless charging source that isnt "clean" or where the voltage is jumping around.
    g6t9ed likes this.
  28. Aug 20, 2021 at 2:00 PM
    #748
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    My 11 Pro Max with Otterbox fully updated charges fine. Little slow but still come out ahead with map use and streaming over Bluetooth.
  29. Sep 9, 2021 at 3:08 AM
    #749
    redrum448
    So it gets crazier... Since my new phone wont charge (would cycle from charging to not charging every 5seconds) I put this liner in the tray hoping I could lay the phone there and it being somewhat thick it would prevent any attempt at charging.
    Well it charges instead lol.....
    Granted it only charges on slow but its better then nothing.
    So to others with the charging error try putting something thick (er) between the phone and charger and post results.
  30. Nov 23, 2021 at 3:42 PM
    #750
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    I have to report that my iPhone 13 Pro Max is having issues with the charger. My Iphone 8 Plus worked like a champ. I've tried no case, and three other cases, it will charge for about 40 seconds then turn red. Its pretty maddening.
