SE Toyota center console wireless charger.
Discussion in '2.5 Gen Tundras (2014-2021)' started by prerunnerseth, Nov 19, 2019.
  1. Oct 22, 2020 at 5:38 PM
    #691
    Boss hog
    Boss hog Tundra_Tombstone
    San Antonio, Texas
    2021 Crewmax TSS 4WD --- Cement
    Wheels: KMC KM535 18x8.5 Tires: General Grabber X3 35/12.50 R18 F Bumper: C4 Fabrication Overland Series, powder coat black R Bumper: C4 Fabrication Overland Series, powder coat black Suspension: Fabtech 6" lift Interior Trim: A-pillar grab handle (Toyota Sequoia) Security: Exxtreme Console Safe ® Half Size Body: TRD Grill
    Got home to a couple boxes and one was my wireless charger. I'll be installing this weekend. Anything I should be looking out for?
  2. Oct 22, 2020 at 5:43 PM
    #692
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Ordered this from sparks Toyota on Monday and it got here today. Got home from work, took about twenty minutes to install. Works like a charm and will be used often.
    If anyone needs the stock part that this replaced I am happy to karma it to you
  3. Nov 8, 2020 at 11:49 PM
    #693
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Anyone else having trouble with charging the iphone 12 Pro on this charger? Seems to work for a few minutes then turns red, thinking it may have to do with stainless band or magnets?
  4. Nov 9, 2020 at 12:00 AM
    #694
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Mine turns red from time to time with my 12 Pro but no more than my iPhone X. Both have stainless steel cases though so who knows
  5. Nov 9, 2020 at 4:17 AM
    #695
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    My 12 pro used to turn red but after installing the latest software updates yesterday for the phone it seems to have fixed the issue. Charging without any problems now
  6. Nov 9, 2020 at 7:33 AM
    #696
    ejl04
    ejl04 New Member
    Mine doesnt seem to charge too quickly and the phone get's really hot. So hot that it starts to function slower. Does anyone else experience this? I was hoping for better wireless charging out of this unit.
    Flyinryank likes this.
  7. Nov 9, 2020 at 4:37 PM
    #697
    TundraTXTSS
    Conroe
    2020 White TRD Pro
    Just checked, looks like I have an update. I'll try that and hopefully it and hopefully that will fix it/ With my iphone 8 plus i never had a problem neither did my wife. In fact she was jealous and wished her highlander had a charging pad.
  8. Nov 10, 2020 at 5:27 AM
    #698
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Anyone have any issues charging Samsungs? Also has anyone used this with GPS/Waze for extended roadtrips?
  9. Nov 10, 2020 at 5:34 AM
    #699
    Clemsonman14
    If you look in the details for the update mine said something like resolves issues where wireless charging may not work so seems like a software issue more than anything
  10. Nov 10, 2020 at 11:17 AM
    #700
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
    Yes, and it seems as the charger can't quite keep up with the discharge. Phone gets hot also.
  11. Nov 10, 2020 at 12:20 PM
    #701
    primeiro
    primeiro New Member
    Henk
    Netherlands
    got the same with mine S20 ultra
  12. Nov 10, 2020 at 1:30 PM
    #702
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    So i was thinking about get this but i have a question. How does this charge a phone that has an Otter box case? It's an S9+.
  13. Nov 10, 2020 at 4:16 PM
    #703
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I had an otter box on my s7 and it didn't work very well. It was sensitive to what position it was in. Switched to a thinner case and no issues.
  14. Nov 10, 2020 at 6:34 PM
    #704
    Chucko2340
    Chucko2340 New Member
    2019 platinum
    3 inch lift, hdx running boards, under cover flex cover, nitto terra grapplers 285/65/20,trd exhaust, trd cold air intake
    Thanks to this thread mine will be delivered Thursday.
  15. Nov 13, 2020 at 8:59 AM
    #705
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    dont particularly want to read through 24 pages of stuff for possibly no info. I am about to purchase an iPhone 11 pro max. (6.5" screen) will that fit in this charging tray? currently have an iPhone 7. I will have this on order after the phone if I know forsure it will fit. Thanks!
    I dont know if there is a search function within a thread or not, I tried to search through google with no luck figured I would just ask myself here.
  16. Nov 13, 2020 at 10:32 AM
    #706
    HaveFun
    HaveFun Happy to be here
    Fair Oaks Ranch, Texas
    2019 Black Tundra CM SR5
    I have iPhone 12 and it fits with plenty of room. Not sure of size dimensions but I don’t believe it’s substantial.
    Clemsonman14 likes this.
  17. Nov 13, 2020 at 10:54 PM
    #707
    MGM2020
    MGM2020 New Member
    Sacramento CA
    2020 MGM Tundra SR5
    6" Rough Country Lift 37" on 22" V2 Monotube Rear L3 Lifted Struts Front
    I've tried everything to try and get my Samsung Galaxy S20 Ultra to work. I've removed the case. Positioned it all over. I've even replaced the phone thinking it was the phone and I've got nothing. I reached out to Sparksparts and they said they are trying to get a fix for it. For now it just charges off and on about every 15 seconds and gets hot after 2-3 minutes. Hopefully they get a fix for this soon
    g6t9ed likes this.
  18. Nov 15, 2020 at 12:18 PM
    #708
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    keep us posted on your findings.
  19. Nov 15, 2020 at 12:45 PM
    #709
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Yes please keep this updated. I wanted to get this on Black Friday and I own an S20
  20. Nov 15, 2020 at 12:59 PM
    #710
    MGM2020
    MGM2020 New Member
    Sacramento CA
    2020 MGM Tundra SR5
    I'll let you guys know. I took it into my local dealership and they said since it didn't come on the truck they can't help me so my only option is to get a fix through sparksparts.
  21. Nov 15, 2020 at 6:00 PM
    #711
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    I have 11 pro max with the big Otter Box case, fits perfect, no issues.
  22. Nov 16, 2020 at 5:44 AM
    #712
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Thanks for the update, the phone will be here tomorrow or Wednesday. I will have a charger ordered soon as well.
    TomC843[QUOTED] likes this.
  23. Dec 1, 2020 at 11:19 PM
    #713
    MGM2020
    MGM2020 New Member
    Sacramento CA
    2020 MGM Tundra SR5
    Sparksparts is asking that I replace the wireless charger to see if I got a bad one. Will update when new one is installed.
  24. Dec 2, 2020 at 5:05 AM
    #714
    1UP
    1UP Truck Gang
    Mine came in this week. Will install and when I do I'll provide feedback if my S20 5G charges as well.
    Djone27 likes this.
  25. Dec 2, 2020 at 10:38 AM
    #715
    Djone27
    Djone27 New Member
    Interested in this as I just ordered that same phone.
  26. Dec 2, 2020 at 10:51 AM
    #716
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    I would be really surprised if that fixes it. My older S9+ and a Note 8 didn't have issues. But now with me having a S20 Ultra and Note 10 Ultra, they both show the same on/off charging symptoms. I think something's changed in Samsung's design.
  27. Dec 3, 2020 at 5:43 PM
    #717
    Bluesttape
    Bluesttape New Member
    Jesse
    2021 Grey Platinum
    Is the wireless charger for the center console any deeper on the bottom? aka Does this wireless charger interfere with closing the center console if you have the insert tray inside?
  28. Dec 3, 2020 at 6:01 PM
    #718
    HaveFun
    No. Same dimensions. Just the wire attached to supply power but routes next to the hinge.
    Bluesttape[QUOTED] likes this.
  29. Dec 4, 2020 at 9:24 AM
    #719
    realprotundra
    realprotundra Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock TRD Pro DC
    Anyone know if a iPhone 12 Pro Max will fit in this tray?
  30. Dec 14, 2020 at 3:54 PM
    #720
    1UP
    1UP Truck Gang
    Sorry for the late follow up.. I installed mine yesterday. No issues with my S20 5G note. Charges like a champ.
