SCS F5 vs Gen5, it's time to vote!!!
Discussion in 'Wheels & Tires' started by SCSPerformance, Jul 19, 2021.
F5 or Gen 5???
Poll closed Oct 17, 2021.
  1. F5
    57.4%
  2. Gen5
    42.6%
  1. Jan 25, 2023 at 10:39 AM
    #211
    cruising808tundra
    cruising808tundra New Member
    Allen
    2019 Toyota Tundra SR5
    What is the lift on this truck?
  2. Jan 25, 2023 at 11:27 AM
    #212
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  3. Jan 27, 2023 at 6:15 PM
    #213
    17inferno
    17inferno New Member
    I ordered a set today, matte jet black for my 21 Tundra(army green). I was super torn on color because bronze sure looks great with the greens in my opinion. Should be here Feb 02, and will be mounted on 03. I'll post pic when when mounted so can get some color variations here. Everyones truck looks great! I love the simplicity, and weight.
    Also, is anyone looking into center cap options? I scoured the internet, and I know for certain, I would prefer one, and will have to come up with something.
    mcharfauros and Odin43 like this.
  4. Jan 27, 2023 at 7:04 PM
    #214
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    I found this on Facebook. Not sure if they work with the tundra wheels but assuming the are a 108mm bore it should work.
  5. Jan 27, 2023 at 7:04 PM
    #215
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Waiting for my trailer up sell or tax return to show up before I get mine. Can’t wait!
    mcharfauros and 17inferno like this.
  6. Jan 27, 2023 at 7:53 PM
    #216
    baron
    baron New Member
    Brett
    2021 TRD Pro
    Those are pretty clean. I've seen a couple options like this floating around. Do we know if the center bore is the same?
  7. Jan 28, 2023 at 7:02 AM
    #217
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I checked with the seller. You would need to confirm that opening size. He said they were made for the 17x9 wheel.
    17inferno likes this.
  8. Jan 28, 2023 at 4:40 PM
    #218
    baron
    baron New Member
    Brett
    2021 TRD Pro
    Got mine installed earlier today. They look great but are rubbing with 295/70s at full lock, so a bit frustrated as I have both the Westcott lift plus JBA UCAs, the latter I shouldn't even need. Going to find an off-road shop to align it as I'm hoping I can eliminate the rub with more caster. I need like a damn 1/4" forward.
  9. Jan 28, 2023 at 5:01 PM
    #219
    cruising808tundra
    Allen
    Everything I read it points to not needing a BMC with a 295/70/18 setup for your tires. What type of tires did you get? Is it rubbing the front plastis inner fender?
  10. Jan 28, 2023 at 5:02 PM
    #220
    cruising808tundra
    Allen
    I am getting mines installed next week.
  11. Jan 28, 2023 at 5:27 PM
    #221
    baron
    baron New Member
    Brett
    2021 TRD Pro
    I need to look again tomorrow. It was rubbing the stock mudflaps, which I was replacing with RokBlokz anyway, but it hit those too. I pulled the flaps off for now but it's still catching somewhere at full lock as I was backing into my driveway - probably fender liner. I don't see a need for BMC as it's still a bit away from the mount. Tires are Nittos. This is a pretty tried and true set up even at stock Pro height, so I'm at a bit of a loss here...
  12. Jan 28, 2023 at 6:14 PM
    #222
    RusPro21
    Don
    Pa.
    Yeah that’s odd there rubbing with 295’s where others with SCS wheels and 295’s not rubbing. If I put 295’s on my SCS wheels in the spring I’m doing a test fit before I have them mounted.
  13. Jan 28, 2023 at 6:22 PM
    #223
    baron
    baron New Member
    Brett
    2021 TRD Pro
    Glanced just now and it looks like there are some witness marks on the passenger side where the front spats used to be. So, I suppose I can fix that with the CB shims then hopefully push the caster enough to resolve the mudflap rubbing as I really don't want to run it without flaps. Guess I'll just continue to throw money at it...
  14. Jan 29, 2023 at 4:31 AM
    #224
    RusPro21
    Don
    Pa.
    Hey Brett, Any pics?
  15. Jan 31, 2023 at 11:47 AM
    #225
    pandapro
    pandapro New Member
    Opening size is slightly larger on tundras. I have Gen5s on a 4runner and checked this morning.
    RusPro21[QUOTED] likes this.
  16. Feb 2, 2023 at 10:25 AM
    #226
    17inferno
    Heres the matte jet black wheels. Currently maybe 2.5 inches lifted in the front, and nothing but stock in the rear(adding 1 inch when it warms up). 295/70/18 Michelin Defenders for tires. Just adding this so people have more variations to view. Super bright cold day, so kind of washed pic.
  17. Feb 3, 2023 at 11:56 AM
    #227
    TP4Sale
    TP4Sale New Member
    Nick
    Grand Junction CO
    2019 White Tundra SR5
    Mine just came in today going on a 275/70/18 Cooper Discover ATP II with no level. Wanted to go E for towing and off road stoked to see the weight difference from stock steelies with HT.
    Edit looks like the new setup will only weigh 2 pounds more per wheel. Not too shabby.
  18. Feb 14, 2023 at 10:53 AM
    #228
    SCSPerformance
    SCSPerformance [OP] #teamstealth Vendor
    Vin
    Bay Area, CA
  19. Feb 16, 2023 at 10:45 AM
    #229
    Nightshade1970
    Nightshade1970 New Member
    2021 Tundra Nightshade Edition
    Carven Exhaust, Nitto Ridge, Bora 2" spacers, TRD Rear Sway, AFE Air Filter, LED bulbs, Truxedo Pro cover, Eibach 2.0 Coilovers, Smoked taillights, Lamin-X fogs, more mods coming
    Do these not come with center caps or are they not used for another reason? Just curious.
  20. Feb 16, 2023 at 11:00 AM
    #230
    AZBoatHauler
    So.Arizona
    No center caps.
    RusPro21 likes this.
  21. Feb 16, 2023 at 11:19 AM
    #231
    Nightshade1970
    Thank you.
  22. Feb 16, 2023 at 12:45 PM
    #232
    RusPro21
    Don
    Pa.
    That’s what makes them look so bad.
  23. Feb 16, 2023 at 1:36 PM
    #233
    TP4Sale
    TP4Sale New Member
    Nick
    Grand Junction CO
    I understand they are for locking hubs on older style vehicles. There are companies that make center caps for these if its really the only reason. I prefer the more basic look and weight.
    RusPro21[QUOTED] and Terndrerrr like this.
  24. Feb 16, 2023 at 5:39 PM
    #234
    17inferno
    Hey Nick, do you know of anyone? I've been looking like crazy for a perfect fit one. I will eventually figure something I like and modify though, I'm sure. I'd rather just buy centercaps, though.
  25. Feb 16, 2023 at 5:48 PM
    #235
    Odin43
    Odin43 YNWA
    Rich
    NJ
    2021 MGM Platinum, 2015 Lexus LX 570
    I love the look of the F5 and will be getting them when my current tires wear down. Do any members have additional pictures of the F5 mounted? This thread definitely needs more pictures.
  26. Feb 16, 2023 at 7:50 PM
    #236
    TP4Sale
    TP4Sale New Member
    Nick
    Grand Junction CO
    I know liftd customs makes some and I know there are a few Etsy shops that will make them. If you google it a few show up. I prefer the Etsy ones as they look pretty clean.
    You might need to reach out and send the measurements to them as these haven’t been around that long. Just a thought.
    17inferno[QUOTED] likes this.
  27. Feb 16, 2023 at 8:58 PM
    #237
    moonrover
    moonrover New Member
    2022 Tundra SR5 TRD OR
    My fav wheels for the gen 3 :)
    SCSPerformance[OP] and 17inferno like this.
  28. Feb 17, 2023 at 5:30 AM
    #238
    Odin43
    Odin43 YNWA
    Rich
    NJ
    Looks amazing
    moonrover[QUOTED] likes this.
  29. Feb 17, 2023 at 10:50 AM
    #239
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Just knock the rust of the rear hub, paint it black, gray or whatever and put the wheels on. A cap really does not add anything but some bling. 35x12.5s
  30. Feb 27, 2023 at 1:58 PM
    #240
    gearnuts
    gearnuts New Member
    Joel
    Greer, SC, United States
    can you add a close shot of the rear wheel on the gen 3? thinking this would look good on blueprint trd off road 1794 but can't decide gunmetal or bronze! glad this wheel got produced Vin
