Screen upside down and inverted
Discussion in '2.5 Gen Tundras (2014-2021)' started by hunterg6, Apr 11, 2021.
  1. Apr 12, 2021 at 8:44 AM
    hunterg6
    hunterg6 [OP] New Member
    Hunter
    2020 tundra trd pro
    Dealership has never heard of it the dealership was booked for the next 2 weeks and they moved me to tomorrow because of a “safety concern” I’ll keep everyone updated
    KneeYa, Sumo91, bleach and 3 others like this.
  2. Apr 12, 2021 at 8:55 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Disconnect the battery for a couple of minutes, then get someone to hold the power button down while you reconnect the battery. This should reset the radio and correct the screen problem.
  3. Apr 12, 2021 at 9:14 AM
    heyacker
    heyacker New Member
    The dealership will prob replace it.
  4. Apr 12, 2021 at 11:53 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Make sure the replacement has a warranty for at least as long as the rest of your truck. Sometimes dealers will only warranty for a year or less for electrical replacement items. Ask questions before they replace it.
  5. Apr 12, 2021 at 2:56 PM
    TaquitoBandito
    Joel (AKA Bif)
    If they don't fix it, invite a friend to drive it and then say "What'd you do?!!!!!!!!"
    batman900, Astom22, bleach and 2 others like this.
  6. Apr 13, 2021 at 12:26 PM
    hunterg6
    Hunter
    2020 tundra trd pro
    Dealership said they will replace the “radio” which I’m assuming is the whole head unit I’m really hoping they do this right or I’ll be hearing wires bounce around for the next 7 years
    TaquitoBandito and Drainbung like this.
  7. Apr 13, 2021 at 12:27 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The head unit swap is very straight forward. Nothing for them to screw up with loose wires. Glad they're getting you squared away.
  8. Apr 13, 2021 at 12:37 PM
    TaquitoBandito
    Joel (AKA Bif)
    I agree with Jake. You'll be fine. Really strange that it happened though.
    TRDFerguson[QUOTED] likes this.
  9. Apr 16, 2021 at 1:39 PM
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    Hope you get your radio replacement sooner than me. While fixing a rattle in the IP the dealership damaged the bezel around the radio on both sides. I have been waiting on a replacement now for over 2 months!!! On the bright side they at least acknowledged their screw up and are going to fix it....eventually.
  10. Apr 18, 2021 at 3:16 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    If you really want, you can get to the diagnostics section of your touchscreen and do a factory reset, but I would probably only do that as a last ditch effort if they were not going to cover it on warranty.
    Obviously, you'll probably have to do this while standing on your head:
    Without starting the truck, put the pushbutton start into "on/ignition" without touching the brake pedal (do not start the truck). After the touchscreen cycles though the intro/warning screens, press and hold down the (physical) menu button while cycling the headlights on and off 3 times. Release the menu button. Should bring up the diagnostics screen with the reset option. I've never had to use it; use at your own risk. Might be best just to wait and get the new head unit if they're going to warranty it.
    TaquitoBandito likes this.
  11. Apr 19, 2021 at 2:43 AM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    If you give your 2 weeks notice to quit your job where I work, they won't let you touch the network. I heard a computer tech did this to all the computers on his last day. Upside down and inverted.
