Screeching noise coming from drivers front
Discussion in 'Wheels & Tires' started by Cummins3500, Feb 29, 2020.
  1. Feb 29, 2020 at 4:12 PM
    Cummins3500
    Cummins3500 [OP] Never finishes.....
    Logan
    Truck had all the u-joints, carrier bearing, and lower control arm bushings replaced. Picked the truck up drive fine with no issues. Trucks sat for a week and now I’ve got a schreeching noise that changes with speed. I’m kinda hopin I picked up a gravel. Any other guesses as to what’s causing it?
  2. Feb 29, 2020 at 4:53 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    Heat shield rubbing the rotor maybe??
  3. Mar 1, 2020 at 4:04 PM
    Cummins3500
    Logan
    Spot on, appreciate the response.Jacked the truck up today, and seen fresh marks on the heat shield. Bent it back out the way and good to go
  4. Mar 1, 2020 at 4:55 PM
    Pitbull410
    Awesome:cheers:
