Schooled by a Firestone Alignment Tech
Discussion in 'Suspension' started by Hyperlite33, May 9, 2019.
  1. Sep 18, 2019 at 1:23 PM
    #91
    Froi CM20184X4
    Froi CM20184X4 New Member
    2018 White CM platinum
    Still few
    Yep and your rear specs are way better
  2. Sep 18, 2019 at 2:01 PM
    #92
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    These rear specs may make me re-evaluate my thrust angle...
    himey, RitcheyRch, 15whtrd and 2 others like this.
  3. Sep 18, 2019 at 9:22 PM
    #93
    Froi CM20184X4
    Still few
    Hahah i think i will stay with that rear specs
    gosolo[QUOTED] likes this.
  4. Sep 18, 2019 at 9:23 PM
    #94
    Froi CM20184X4
    Still few
    Thank you, i think pulling the passenger side will be my option. Thank you
    Watt maker likes this.
  5. Sep 19, 2019 at 9:06 AM
    #95
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    I would stray away from the Firestone lifetime alignments. The techs don't get paid crap and this translates to a bad attitude a rushed job. The service adviser told me the techs only get paid .5 hr flat rate for a lifetime alignment. For a tech making 25 hr flate rate that's only $12.50 to align your truck! No wonder they rush through them.
    Also, as mentioned before, being 'in the green' means nothing. The tech can actually go into the software and changes the numbers to whatever he wants! You don't even have to lean on a tire to change values, you can simply use the keyboard. Seen it happen with Hunter alignment racks.
  6. Oct 10, 2019 at 5:43 PM
    #96
    himey
    himey New Member
    I have a 13 DC Tundra with a 6" PC lift and TC UCA. I have chewed through a set of tires (35x12.5x18) in less than 2 years. Went to Big-O tires and dropped another $1800 for a new set and signed up for their unlimited alignment for $150 bucks. 3 weeks in on the new tires and already noticing outer wear. Camber was set at -0.7 left, -0.6 right, Caster at 1.9 left, 2.8 right. Where did they go wrong?
  7. Sep 10, 2020 at 6:20 AM
    #97
    lassiter1979
    lassiter1979 New Member
    Donnie
    NC
    2020 Tundra SR5 Crewmax 4x4 in Silver Sky Metallic with XSP Package
    3" front lift, 1" rear lift; BFG KO2 295/60R20; color matched front grille and hood bulge
    Old thread I know, but curious how much the lift was? Less than or more than 3" ? Fighting this same battle and this info will help.
