Satellite radio loses reception easily
Discussion in 'Audio & Video' started by MrWrench, Sep 8, 2017.
  1. Sep 8, 2017 at 7:17 AM
    MrWrench
    MrWrench [OP] New Member
    2017 White Tundra limited
    Spray on bed liner, Bak mx4
    When listening to the satellite radio in my truck, it loses the reception when I drive under just about anything. Even if some tree branches are slightly over the road, I lose reception. Has anyone had this problem? My VW rarely ever lost signal. Thanks
  2. Sep 8, 2017 at 7:22 AM
    Borgs
    Borgs New Member
    PA
    Yes, it is terrible. I am not going to renew the XM subscription.
  3. Sep 8, 2017 at 7:26 AM
    MrWrench
    That sucks. I was gonna ask the dealer to look at. I thought maybe there was a problem with the receiver.
  4. Sep 8, 2017 at 7:28 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    It happens to me from time to time. Just for a few seconds. Minor annoyance.
    SouthBoundSteve likes this.
  5. Sep 8, 2017 at 7:38 AM
    Borgs
    Borgs New Member
    PA
    I had the same problem with my wife's Highlander. Dealer said nothing was wrong with it. I am assuming it is a Toyota problem, as my brother and uncle have other brand vehicles and their XM works great. And I have had bad service all over - in cities and suburbs under bridges and trees, to up on top of mountains in norther PA and the Adirondacks. It's brutal.
  6. Sep 8, 2017 at 8:08 AM
    MrWrench
    It's by far the worst out all the vehicles I've had or been in. I wonder if there is an aftermath antenna for xm that will pickup the signal better.
  7. Sep 8, 2017 at 9:10 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    my Tacoma did that as well as my tundra. it is very minor and only rarely happens under bridges or overpasses. its like a 1 second blip. no biggie for me.
    however, I totally lose the signal when I go into the parking garage at work, but that's 10's of feet of concrete and building materials that are blocking the signal.
    Devcom and AxelsHumanDad like this.
  8. Sep 8, 2017 at 9:52 AM
    Borgs
    Borgs New Member
    PA
    I am cancelling.
    NewImprovedRon likes this.
  9. Sep 8, 2017 at 9:53 AM
    Borgs
    Borgs New Member
    PA
    I wish. I can't go 1/4 mile without a hiccup or blip. So annoying. I'd think less of it is I wasn't PAYING for radio signal.
  10. Sep 8, 2017 at 9:59 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Thanks for reminding me Ron... It's time to do my yearly Comcast threat to cancel. Gawdddd... I hate Comcast.
  11. Sep 8, 2017 at 10:01 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Yes, i lose reception also when i pass under a bridge or under the tunnel, i thought that was normal.
  12. Sep 8, 2017 at 10:03 AM
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    Same here. Sometimes it will lose the signal and then take miles to pick it back up. Others here have said the antenna placement is part of the reason, all I know is I don't lose the signal in any of our other vehicles in the places my Tundra does.
  13. Sep 8, 2017 at 10:06 AM
    Borgs
    Borgs New Member
    PA
    how about on the top of a friggin mountain?
  14. Sep 8, 2017 at 10:11 AM
    Ely010606
    SPARKS, NV
    Dont know, maybe it will give me a reason to drive down to Big Bear and find out, unless you know already itll save me a trip.
  15. Sep 8, 2017 at 10:47 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    yup..lose signal for a few seconds...but I use it all the time...plus if you live or visit alaska or hawaii they don't got it..so I stream it from my phone
  16. Sep 8, 2017 at 11:19 AM
    Borgs
    Borgs New Member
    PA
    I wish. White Face, the Adirondacks in New York, and the Appalachians in PA. Those are speed bumps compared to where you roam!
  17. Sep 8, 2017 at 12:07 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Bad here too. I had it with my old Tahoe under overpasses and stuff. But now I lose reception under areas with lots of power lines or anything else. It's so frustrating....
  18. Sep 8, 2017 at 4:36 PM
    AxelsHumanDad
    AxelsHumanDad I am Groot
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    It's not the hardware itself, or the location of the antenna, or the service. The buffer is too small in the firmware. There is some delay built in to the decoder which will allow the stream to continue through minor dropouts in the signal. Unfortunately whoever these head units come from didn't allow a big enough buffer to allow for much of a dropout. The four trucks I've had with built-in XM have all sucked for carrying over momentary dropouts. The little XM Roady standalone unit I use to use never dropped out.
  19. Sep 8, 2017 at 4:56 PM
    MrWrench
    I really noticed it last night, but the way the patriots were playing everything was driving me nuts haha
  20. Sep 8, 2017 at 6:41 PM
    AxelsHumanDad
    2015 CM Platinum
    Right. If it's a dedicated unit, it gets engineered to do it's job and just that. These all-in-one things we have in the dash are forced to do a little bit of everything so corners have to be cut somewhere.
    Sure, there are units out that are better than what we have, but they are still a compromise somewhere. :)
  21. Sep 8, 2017 at 6:46 PM
    Black Wolf INCOGNITO undercover mafia
    Aurora CO
    TuwaPro headache rack
    I have aftermarket XM basic receiver and antenna. Only time it loses a signal is when going through a tunnel. Factory antenna has to be the source or crappy ass receiver. Root Cause Analisys......
  22. Sep 9, 2017 at 5:46 AM
    Borgs
    Borgs New Member
    PA
    I am driving to Hawaii in a month - thanks for the heads up. :thumbsup:
    tAcomaPueblo likes this.
  23. Sep 9, 2017 at 5:53 AM
    Borgs
    Borgs New Member
    PA
    What if I reroute my mainframe, adjust my coaxials and download MS DOS 5.0?
  24. Sep 9, 2017 at 6:13 AM
    onetohunt
    onetohunt New Member
    Marvin
    2016 Magnetic Gray Tundra TSS
    Mine would lose it just driving down the road for a second here and there, no rhyme or reason. Wore me out.
  25. Sep 12, 2017 at 9:30 AM
    TheBronze1
    TheBronze1 New Member
    Al.
    Maryland
    2017 bronze mica 1794
    bed cover, upgraded stereo system, light bar in hood and front grill, bed lights, switch back lights by step bars
    mine wont even pick up the signal at all and its only a week old lol lol just keep saying loading...
  26. Jul 14, 2019 at 4:23 PM
    Redspider
    Redspider Super White
    Mark
    2019 Super White Tundra Trd
    I only have issues when I’m near a cell phone tower, any fixes for that?
  27. Jul 14, 2019 at 5:31 PM
    Black@Blue19
    Black@Blue19 New Member
    Ken
    Galveston County
    21 SR5 TSS OnRoad Tundra Crew Max
    Came with all the lane departure and that stuff, electric tail gate lock, fog lights, 20s, sprayed on bed liner, tint, cat protector, and that’s about it??:)
    Pandora works just fine!!!:)
  28. Jul 22, 2019 at 6:58 AM
    illfixit
    illfixit New Member
    Potter Co.
    15 TUNDRA TRD OFF ROAD
    Hi all, has there’s been any solutions found for the reception yet cause I don’t want to reinstall my portable dock and radio because I fear of getting tangled in the 300 feet of multiple wires!! Or should I just learn how to sing better !!!????
  29. Jul 22, 2019 at 7:56 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    I lose the signal often in my 2019 Tundra. I don't understand why the receiver is not designed to buffer a minute or so of data so it can keep playing when the signal is temporarily lost. I doubt that I'll renew my XM/Sirius when it expires.
    RBDTx likes this.
  30. Jul 22, 2019 at 8:05 AM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    Pretty much the same as my truck it blips going under the flyovers and overpass on I-35 at the I-435 interchange. It comes right back though otherwise its good. For those saying it does it under branches my Tundra does not do that and not even my 16 civic does that and its much lower to the ground then my Tundra. I live in an area of the metro with a lot of trees and branches too and the signal goes right through it and works fine. I would either keep pestering the dealer or try another one to get it fixed and you are welcome to show them my post if you want if that does anything.
