Sagging Truck Bed?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Ccwf9787, Jul 3, 2019.
  1. Jul 3, 2019 at 1:34 PM
    Ccwf9787
    Ccwf9787 [OP] New Member
    2019 Tundra TRD PRO
    I justbought a Leer XQ hard top shell for my 2019 Tundra TRD PRO. The bed is slightly sagging now, that the hard shell is installed. What's the best way to fix the sagging bed problem? Thanks
  2. Jul 3, 2019 at 1:50 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Define "Sagging Bed"?
    Are you saying that the weight of it made the entire rear end drop (springs are more compressed now)?
    15whtrd likes this.
  3. Jul 3, 2019 at 1:52 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Lots of ways. Best way depends on use. For me it would be add a leaf or new springs
  4. Jul 3, 2019 at 1:55 PM
    Must be a pretty heavy shell. I vote Add-a-leaf
  5. Jul 3, 2019 at 2:08 PM
    AZTundra
    Paul
    Phoenix, AZ
  6. Jul 3, 2019 at 3:37 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Almost every trd pro I have seen looks nose high to me, I would only imagine a cap would make that even worse. You probably need new leafs packs or at least an add a leaf
  7. Jul 3, 2019 at 3:46 PM
    15whtrd
    15whtrd Mr. Blonde
    I think a good cheaper route would be an add a leaf. Since the weight will always be on the back of the truck it will probably still ride nice. I think add a leafs may ride a bit stiff if the truck is unloaded. But if it’s always going to be there it’s a good option. Also add some nice shackles and polyurethane bushings. I bet it will ride nice.
    Pudge and Watt maker like this.
  8. Jul 3, 2019 at 8:02 PM
    Ccwf9787
    2019 Tundra TRD PRO
    The weight of the hard top shell made the entire rear end truck bed drop slightly. The springs are probably slightly more compressed now.
  9. Jul 3, 2019 at 10:32 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I have 2” shackles on mine with a leer 100xl rides great and looks better :)
  10. Jul 3, 2019 at 10:35 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I would go with an add a leaf. Just lifting the back doesn’t help with the additional weight.
  11. Jul 4, 2019 at 8:16 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
  12. Jul 4, 2019 at 8:25 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Adjustable air bags.
    Kerch71 and Watt maker like this.
  13. Jul 4, 2019 at 10:13 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It’s not so much that his suspension is sagging. It’s just too low in relation to the front since the pro has a 2 inch front lift
  14. Jul 4, 2019 at 10:18 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    True. I’m in the same boat. Waiting for my CB#3’s so I’m not starring at the sky when I haul something.
    Bsincs2k likes this.
  15. Sep 2, 2019 at 5:24 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Those Coachbuilder +3's are no joke. I have over 700 lbs of weight equipment in the bed.
  16. Sep 2, 2019 at 6:43 AM
    Grumpy Uncle
    Pat
    CO
    My shell weighs in at 300'ish lbs. That's one reason I went with the Dakar spring pack.
    JoshuaA likes this.
  17. Sep 2, 2019 at 6:47 AM
    Cox3497
    Cox3497 New Member
    Toyota Tundra Crewmax
    With sustained weight I would probably be inclined to do add a leaf as well. I went that route with my 2007 Tundra that had a cap and it worked great. On my 2016, I used shackles and am happy with those as well, but if the weight is around to stay you might as well use the extra spring.
  18. Sep 2, 2019 at 7:45 AM
    Ccwf9787
    2019 Tundra TRD PRO
    Just installed Leaf Spring. No more sagging. Thank you to everyone that responded.
    COTundra23, Rica25, Winning8 and 5 others like this.
  19. Sep 2, 2019 at 8:15 AM
    aresenalgunner007
    aresenalgunner007 New Member
    San Diego
    2019 Black TRD PRO
    BFG KO2’s
    What size tires are you running on there?
  20. Sep 2, 2019 at 8:47 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    What leaf did you go with?
  21. Sep 2, 2019 at 8:56 AM
    Cox3497
    Cox3497 New Member
    Looks great! Nice work.
  22. Sep 2, 2019 at 9:52 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Cant believe a cap would make it sag
  23. Sep 2, 2019 at 9:55 AM
    xtyfighterx
    Ty
    North Idaho
    Added shackles to mine
  24. Sep 2, 2019 at 10:11 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    But aren’t the shackles just masking the issue? You’re raising it up an inch and three-quarter’s to compensate for sagging. The stronger springs would hold the weight. Now if you put something in the bed it’s still going to sag since the shackles don’t increase payload.
  25. Sep 2, 2019 at 10:14 AM
    Primalbryan
    Primalbryan New Member
    2019 Limited Tundra Off-Road TRD- White
    TRD dual exhaust
    What leaf did you end up adding? I just got a Leer XR canopy and the Decked system, now fully loaded with all my work gear and am experiencing the same thing. I wanted a leveling kit but definitely need to help out the rear end before I even consider that now
  26. Sep 2, 2019 at 2:50 PM
    jjreuter
    jjreuter New Member
    I have an xq on my Pro as well...definitely some sagging. Is there truly an issue or just visual preference? Also, novice here and don’t know what a leaf is or how you go about having one installed...any input if this is a necessary fix or just a visual fix would be appreciated.
  27. Sep 2, 2019 at 3:03 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Here’s a leaf pack. This is what helps you with your payload in the back
    http://iconvehicledynamics.com/shop...ta-tundra-multi-rate-rxt-leaf-spring-kit.html
  28. Sep 3, 2019 at 3:50 PM
    xtyfighterx
    Ty
    North Idaho
    Correct. But i never use the bed really it’s just to correct the lean from the cap. A new leaf pack would be ideal really but I’m not going drop that kinda cash cuz the canopy sags the rear a half inch or whatever it way be.
  29. Sep 3, 2019 at 6:32 PM
    MGM
    MGM New Member
    I too don’t want drop that kinda cash on a new leaf pack because I don’t use the bed that much. Keeping the shell on so that’s not a option. I just want the rear sag gone but the PRO dual exhaust will has some issues under certain circumstances if third-party shackles are installed and I don’t want any problems in the future. So I think I have come to the conclusion there is no simple and inexpensive remedy for the rear sag on my PRO.
  30. Sep 3, 2019 at 7:49 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Wow! How about a $100 tough country add a leaf? Gain 500lbs in payload and raise the rear 1.5”. If $100 is too much then I guess this idea is SOL as well.
