S vs D and Tow/Haul Switch
Discussion in 'Towing & Hauling' started by smstoyloy, May 31, 2020.
  1. Jul 8, 2020 at 1:19 PM
    #61
    AZBoatHauler
    So.Arizona
    Yes, you keep the temp down by staying out of OD which results in higher RPMs and a happier truck.
    Cpl_Punishment likes this.
  2. Jul 25, 2020 at 4:15 PM
    #62
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I have two questions if you guys can help me out on. So i can have a better understanding.
    1. If i have it in S4 and went to a complete stop, ( or slowing down) do i have to switch it back to D, or i can just go to from S4.
    2. Can you use the S4 going up or down the hill without any trailer, or is it used for towing only.
    TIA
  3. Jul 25, 2020 at 5:22 PM
    #63
    Kanobi13
    Kanobi13 New Member
    I would personally leave in D but as others have stated they use 4s to tow. I use D with tow haul on big hills in the mountains and the truck slows down nicley without loaded or trailer
    Ely010606 likes this.
  4. Jul 25, 2020 at 5:27 PM
    #64
    Kanobi13
    Kanobi13 New Member
    Then again i do have DD exhaust and use the sequential shifting to get her to purrrrr.... so you can use without towing
  5. Jul 25, 2020 at 5:28 PM
    #65
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    First time towing recently and I was using Tow Haul S5 over the flat prairies and Tow Haul S4 over the rolling hills of Ontario.
    No cruise control. RPMs were often under 2k but never above 3k. No issues on highway, taking off at stops or passing vehicles. Km/L or MPG sucked, but I wasn't concerned.
    Used D after I unhooked.
  6. Jul 25, 2020 at 7:14 PM
    #66
    AZBoatHauler
    So.Arizona
    1. You can leave it in S4. All this does is limit the top gear to 4.
    2. You can use it whenever the circumstances warrant. I use mine on steep grades up and down to limit shifting back and forth and for engine braking without a load.
  7. Jul 25, 2020 at 7:55 PM
    #67
    Ely010606
    SPARKS, NV
    Thanks Adam. That’s good to know i dont have to keep switching it. I was at Tahoe and i was switching it back to D each time i stop. Im very grateful for the advise. Thank you again
    AZBoatHauler[QUOTED] likes this.
  8. Jul 26, 2020 at 8:55 AM
    #68
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    You would feel differently If you seen how hot your transmission fluid was when you were towing ! If you haven't heard 2019+ have no trans cooler and people see upwards of 250 degrees when towing , lucky you can still retro fit your truck with a cooler .
    sask3m likes this.
  9. Jul 26, 2020 at 10:04 AM
    #69
    BravoDeltaRomeo
    Bruce
    MB Canada
    I know it doesn't have a cooler but figure it is how they made it, it's new and serviced by dealership.
    If anything goes wrong, I'm confident I'll be covered
  10. Aug 9, 2020 at 7:57 PM
    #70
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    How heavy were you towing? What was your transmission temps ?
  11. Aug 9, 2020 at 8:05 PM
    #71
    BravoDeltaRomeo
    Bruce
    MB Canada
    17' hybrid, 4 people, dog, firewood, supplies, camping gear
    Don't have anything to monitor temps, so didn't even think about it or worry about it.
    Dry Weight
    2,708 lbs.
    Payload Capacity
    1,138 lbs.
    GVWR
    3,846 lbs.
    Hitch Weight
    346 lbs.
  12. Aug 17, 2020 at 1:04 PM
    #72
    Jtundra81
    Joe
    I have 19 tundra crewmax , tow around 4000lb travel trailer , I keep it in S4 with tow haul ,speed around 60mph, mpg 10 to 12 depends on wind .
    Transmission temp around 215 on pan and climbs up between 217 to 220 going up hills . Torque will see up to 245 very rare when stopping and accelerating ( most times goes 235 and drops down).
    If I put truck on s5 highway , transmission temp will creep up slowly , S4 is your bet , I take my time and I don't push it more then 60-65 mph which keeps transmission temp under control . RPM is lower then 3 on highway and gets to 3 on hills , plenty of power on S4 and keeps the converter locked also more fluid circulation with higher rpm which is what you want for cooling.
