S.o.b fabrication “High clearance rear bumper”
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mrf1987, Apr 19, 2022.
  1. Apr 24, 2024 at 6:21 AM
    #181
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Looks awesome. I need to add the tire carrier to mine already. Also, love the license plate :rofl:. I thought about putting a hybrid/prius decal on mine and see how many people I piss off
  2. Apr 28, 2024 at 4:56 PM
    #182
    CaptRussia253
    Ruslan
    Has anyone added fender flares with this rear bumper? Trying to see what it looks like.
    Jonnynewton909 and STravis like this.
  3. Apr 28, 2024 at 6:02 PM
    #183
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    @Jonnynewton909 has flares on his. The flares are a bit wider than the bumper though.
  4. Apr 28, 2024 at 6:04 PM
    #184
    STravis
    Travis
    Ruidoso, NM
    Here are some pictures of another one I found on my phone.
  5. Apr 28, 2024 at 7:00 PM
    #185
    CaptRussia253
    Ruslan
    Thank you!
    STravis likes this.
  6. May 3, 2024 at 7:39 PM
    #186
    Jonnynewton909
    Jonnynewton909 Jonnys_Tundra
    Jonny
    East Texas
    2017 Tundra CrewMax
    Accutune Fox DSC 2.5 front w/ SPC UCAs, Alcan custom spring pack and Accutune Fox DSC 2.5 rear. 37 Toyo RT Trails on Method 312s. SOB Fab F&R high clearance bumpers. AT Overland Atlas.
    I have bushwacker flares that are about 2" wide and they do hang out but I don't notice them. I originally thought about adding plate to the bumper to match the contour of the flares, but once I got the bumper on there you really don't notice it looking down at the flare.
    This angle makes the overhang noticeable but unless you're looking up from below it's never that noticeable. This is again with the 2" wide flares. Stock and some options aren't this wide.
  7. May 3, 2024 at 9:38 PM
    #187
    CaptRussia253
    Ruslan
    Very helpful, thank you!
  8. May 7, 2024 at 9:26 AM
    #188
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    What bed cage is that? And does water get in the bed with it installed that way?
  9. May 22, 2024 at 9:33 AM
    #189
    AZBoatHauler
    So.Arizona
    Bump for towing update. Had the chance to tow our wake boat with the new bumper setup - boat and trailer are around 6,500-7,000 and took it from storage about 40 miles down winding dirt road then later 125 miles home. First try I had the hitch adjusted too low and it gave more bounce than I like. Moved the ball up an inch and it tows just as good as it did before the adding the bumper. Time for a 5.29 re-gear but that’s a separate issue.
  10. May 22, 2024 at 9:39 AM
    #190
    CaptRussia253
    Ruslan
    Awesome! I have three trips planned for the end of June and July to tow our 30' travel trailer. I knew this bumper can handle towing.
    STravis and AZBoatHauler like this.
  11. May 22, 2024 at 12:39 PM
    #191
    FiveO Enduro
    FiveO Enduro New Member
    Buffalo, NY
    2020 Army Green Pro
    BillieBars - I get some water through the seal of the tonneau cover, but it would be easy to remedy with a better/ additional seal. It’s a cheap Amazon tonneau cover so a better seal should probably be added regardless.
    Damie Street[QUOTED] likes this.
  12. May 24, 2024 at 9:52 PM
    #192
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    tow hitch under OPs license plate?
  13. May 24, 2024 at 10:21 PM
    #193
    AZBoatHauler
    So.Arizona
    CaptRussia253 likes this.
  14. May 25, 2024 at 5:41 AM
    #194
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    You gonna throw a powertrax or locker in it when you regear?
    I’m considering it as well. I just use these big heavy LTs too much to go back to stock size SLs.
  15. May 25, 2024 at 7:46 AM
    #195
    AZBoatHauler
    So.Arizona
    Yes - e-locker rear.
  16. May 25, 2024 at 8:52 AM
    #196
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    I’ve been very happy with my 5.29s and Eatons f/r.
    haven’t had much time to abuse them (15k miles) but they’ve been off-road several times.
  17. May 28, 2024 at 10:48 AM
    #197
    FiveO Enduro
    Buffalo, NY
    2020 Army Green Pro
    Tis the season in NY for hitch accessories. I can’t remember if I saw someone with an accessory hitch added to their swing out or not. I don’t think it would be a problem for Travis to add.. but dangit, I wish I did! I may look into trying to find someone to add one on. I have to add a hitch extension to clear the tire but then the swing out doesn’t clear the rack to be able to drop the tailgate. Would be killer for the rack to be attached to the swing out. Just throwing this out there for an option to consider when purchasing.
  18. May 28, 2024 at 1:46 PM
    #198
    CaptRussia253
    Ruslan
    @STravis added a hitch to his. Im sure a local welder can easily add one.
  19. May 28, 2024 at 5:09 PM
    #199
    STravis
    Travis
    Ruidoso, NM
    We've actually been taking a different approach recently and extending the tube on the passenger side to center up the receiver.
    PXL_20240116_191723033.PORTRAIT.ORIGINAL.jpg PXL_20240116_191732526.PORTRAIT.ORIGINAL.jpg PXL_20240116_191712456.PORTRAIT.ORIGINAL.jpg
  20. May 28, 2024 at 5:55 PM
    #200
    FiveO Enduro
    Buffalo, NY
    2020 Army Green Pro
    Dang, nice job!
  21. Jun 8, 2024 at 8:02 AM
    #201
    JungleFev3r
    JungleFev3r New Member
    2020 MGM Tundra TRD
    I’m not sure if this has been mentioned in this thread yet, but what is the weight of the rear bumper with dual swing outs, hitch and side guards?
  22. Jun 8, 2024 at 10:16 AM
    #202
    AZBoatHauler
    So.Arizona
    Being awesome = weightless.
  23. Jun 8, 2024 at 10:53 AM
    #203
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Be thankful, the LED BSM taillights from Ford are $1100 each and I had to wait 6 months for one of them. I’ve managed to break both of them on separate occasions! And the BSM module doesn’t even come with the light for that price. You have to swap them!
  24. Jun 8, 2024 at 10:53 AM
    #204
    CaptRussia253
    Ruslan
    This
    JungleFev3r and FrenchToasty like this.
  25. Jun 8, 2024 at 1:50 PM
    #205
    STravis
    Travis
    Ruidoso, NM
    The bumper is ~ 150 lbs, each swingout is ~ 45 lbs, the bedside protection adds about 35-40 lbs
  26. Jun 22, 2024 at 4:53 PM
    #206
    CaptRussia253
    Ruslan
    Towed our trailer today. Went 150 miles over white pass. Transmission temps stayed under 200* except over the pass. With stock gears and 37s truck handled it with ease.
  27. Jul 9, 2024 at 2:00 PM
    #207
    STravis
    Travis
    Ruidoso, NM
    Quick SOB Fabrication update, we are now officially a vendor on the site. If anybody has any questions feel free to reach out to us.
  28. Jul 9, 2024 at 2:04 PM
    #208
    STravis
    Travis
    Ruidoso, NM
    Also, quick question from @Trdwillie14 , he needs a measurement to see how far the spare tire hangs off the back of the truck. If somebody can get a measurement off of the tailgate to the furthest point on the spare mounted on the swingout.
    Also tire width and offset would be good info as well.
  29. Jul 9, 2024 at 2:43 PM
    #209
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Trucks to tall
    For the garage and this is the only room I got
    Left in my shop but my wallet is hoping along with my wife it won’t fit lol
  30. Jul 9, 2024 at 2:45 PM
    #210
    AZBoatHauler
    So.Arizona
    A small garage made my swing out decision for me as well.
