RW rims ???
Discussion in 'Wheels & Tires' started by Jason808, Aug 1, 2018.
  1. Aug 1, 2018 at 7:30 PM
    Jason808
    Jason808 [OP] "Thrust you can Trust"
    2012 Platinum crewmax
    Hey everyone! I tried searching for this and came up empty handed. So......... I was wondering if a set of 2011 17 inch RW rims will fit my 2012 platinum CM? And if so what size tire will fit with only a 2 inch lift up front?
  2. Aug 1, 2018 at 7:35 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    The RW wheels will fit. Not sure about the TPMS, I think they will work...
    Not sure on the tire size.
    Sorry I'm not much help.
  3. Aug 1, 2018 at 7:54 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Yes they will fit, from what I have read you are looking at 285/70r17 tires.
  4. Aug 1, 2018 at 7:57 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    285-70-17 will fit no doubt, I believe that size came on stock RW trucks.
    You could probably put on 285-75-17 with maybe minor trimming. That’s what size I’m running on my RW wheels.
  5. Aug 1, 2018 at 8:09 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    A lot has to depend on your alignment as well.
    You'll fit 285/70/17 no problem as it was the stock size. 285/75/17 may need some additional caster to stay away from the cab mount. You may need to trim a little plastic or remove some of the "mud/splash" guards.
    Technically speaking 35s fit with RW on a lift... May need a little finess. Many threads out there discussing RW and 35s.
