Rust Corrosion
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sakana65, Jun 26, 2017.
  1. Jun 26, 2017 at 7:04 PM
    Sakana65
    Sakana65 [OP] New Member
    Gary
    2017 Pearl blue trundra
    I have a 2017 Tundra in the blue color. I have rock dings where the paint and primer have been removed. I have developed rust/corrosion in those spots. Has any one have the same issue? I live in the Seattle area. I am disappointed in that the rust occurred so fast from the dings. I have touched up with Toyota touch up paint. Any feed back would be appreciated.
  2. Jun 26, 2017 at 7:59 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    I go off road quite a lot so I have numerous scratches and areas of chipped paint. Did you sand the rusted spots down a little before applying paint? Pictures?
  3. Jun 27, 2017 at 4:05 AM
    TTund16
    TTund16 New Member
    my Tacoma has a very thin paint and i hear tundras are like that also!
    being a 2017, any rust is a minor surface rust and will cleanup quickly with a little rust-oleum or wd-40 or even a little oil, try to stay on the ding and then apply the touch up paint.
  4. Jun 27, 2017 at 10:25 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    It's just surface rust if your truck is that new; also most likely showing quicker due to the moist environment you live in.
    On a somewhat related note, how is the offroading/overlanding in Washington? There's a good chance I might be moving there by September or latest by the end of the year.
