Running wires through firewall
Discussion in 'Lighting' started by swede78, Oct 30, 2023.
  1. Oct 30, 2023 at 11:41 AM
    swede78
    swede78 [OP] Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    I have a 19 tundra crewmax, where have you run wires through the firewall to run off-road lights and switches?
  2. Oct 30, 2023 at 11:43 AM
    AZBoatHauler
    So.Arizona
    Assuming wires are going near driver, there is a big grommet through the firewall under the ABS module that comes in near the parking brake. Be careful not to damage existing wires making your hole.
    FrenchToasty likes this.
  3. Oct 30, 2023 at 11:54 AM
    swede78
    Lars
    westminster co
    Nothing yet
    The harness comes where you can disconnect the main harness about 2-3 feet from the switch, that connection is about 3/8-1/2 inches wide. And yes it will on the drivers side, not sure where I’m putting the switch.
  4. Oct 30, 2023 at 12:01 PM
    swede78
    Lars
    westminster co
    Nothing yet
    On my 08,I took a coat hanger taped the wires to it and went through the grommet where the parking brake went through. The hole for this harness connector will have to be larger.
