Running Lights Don’t Work
Discussion in 'Lighting' started by johncartersands, Feb 26, 2020.
  1. Feb 26, 2020 at 3:45 PM
    johncartersands
    johncartersands [OP] New Member
    2014 Tundra SR5
    I have a 2014 Tundra SR5. Last week my passenger side running light/turn signal and side reflector light went out. I replaced them both and they still don’t work. I checked the fuse and none of the fuses are blown. Any idea as to what this might be? Can I fix it without going to a dealer?
  2. Feb 26, 2020 at 4:16 PM
    TTund16
    TTund16 New Member
    see if you can trace the wires … maybe a loose connector and/or cut/chewed up wire?
    also sometimes fuses look good but are not. check for continuity.
    DRP82 and Sas like this.
