Running Boards
Discussion in 'General Tundra Discussion' started by cmp1960, Feb 5, 2017.
  1. Feb 5, 2017 at 10:34 AM
    cmp1960
    cmp1960 [OP] New Member
    Anyone have any experience with Iron Cross, particularly their Patriot series. Install and looks?
    I like that they have a 5 year warranty on the black and lifetime on the stainless steel.
    Thanks!
  2. Feb 5, 2017 at 11:00 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  3. Feb 5, 2017 at 1:56 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    @cmp1960 , @joonbug is correct, I have them and like them a lot. They are identical to the OEM ones that come on the XP mammoth package that I had on my 2015. They are a simple design, which I like quite a bit. A bonus is Iron Cross teamed up with the Folds of Honor foundation and a portion of the proceeds go directly to the foundation in support of military families.
    GNTundra, 040Tundra and joonbug like this.
  4. Feb 5, 2017 at 4:12 PM
    cmp1960
    Excellent.. I go back and forth on the black vs the stainless steel. I like the black as it blends, but the stainless breaks it up a little and the lifetime warranty on the stainless is appealing as well. What prompted you to go with black...the blend with your TRD Pro gear? Also, did you install them? Custom fit? Any drilling? Also, where did you get them and would you recommend that vendor? Thank you!!
  5. Feb 5, 2017 at 7:08 PM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Like @GNTundra said, I went with black bc it goes with my theme. No, I didn't install them myself, I ordered them from a local shop and they did the install while I waited. I watched them and can confirm there was no drilling involved. When you order them, be sure to note that the brackets are listed seperate, so you'll need order those as well.
  6. Feb 6, 2017 at 4:42 AM
    cmp1960
    A small percentage of some of the reviews I've read say that the boards flex a little compared to others they have had. Have you experienced this or are those folks to hyper critical?
  7. Feb 6, 2017 at 2:10 PM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I haven't experienced a flexing issue, but they've only been on a week or so and I haven't tried to flex them either. I always take reviews with a grain of salt bc there are actually people out there more critical and OCD than me and they are always the ones that post reviews.
  8. Feb 6, 2017 at 2:25 PM
    cmp1960
    Thanks Lou.... Makes sense... agreed about some being OCD and impractical. do the steps stick out past the tires (along long axis of the truck)
  9. Feb 6, 2017 at 8:36 PM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    @cmp1960 My tires stick out a little further, but I'm running a +18 offset on 295 tires, so they stick out a bit. Here is a pic of mine along that axis...the tire you see is the rear.
  10. Feb 7, 2017 at 5:51 AM
    cmp1960
    Thanks, Lou.. If it's not too much trouble, could i ask you to take a pic, like the one above, but step back about 15 feet to get a look see from that distance? Thanks!
  11. Feb 7, 2017 at 6:09 AM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    @cmp1960 here you go, I snapped a few for you
    Bear likes this.
  12. Feb 7, 2017 at 6:13 AM
    cmp1960
    those look awesome can you get a side angle as well... perpendicular to the truck looking at the doors
  13. Feb 7, 2017 at 6:14 AM
    cmp1960
    Also, what Tonneau cover is that... BAK?
  14. Feb 7, 2017 at 6:35 AM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    TundraJunkie likes this.
  15. Feb 9, 2017 at 12:23 PM
    NoDak
    NoDak New Member
    2017 Tundra TRD Pro CM - Super White
    CMP1960 -
    Louscrw is spot on -- and the pictures he provided are better than mine.
    I recently installed these on my truck. The install was easy, it took me less than an hour by myself. The boards look great, they're reasonably priced, and part of the proceeds go to a worthy cause.
    I haven't experienced any flex in the boards. Granted, I'm not a heavy guy but they seem very sturdy.
    I'm running the Bak Revolver X2, and I'm happy with that as well. Again, install was easy and it looks good on the truck.
  16. Feb 9, 2017 at 12:42 PM
    PMG
    PMG New Member
    And here I am thinking I was all set and FINALLY decided I was going the nerf bar route.... I'm torn again
    PMG
  17. Feb 9, 2017 at 1:25 PM
    cmp1960
    I just ordered mine moments ago. I was going back and forth on the more OEM style, but the larger footprint and the stealthier look and being involved with our service folks was compelling as well. Once I get them and install I will take pics for those who are in the same boat...
  18. Apr 2, 2017 at 2:15 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What's a good site to order NFAB nerf bars from
  19. Apr 2, 2017 at 2:26 PM
    cmp1960
    I got mine Iron Cross Patriots from Auto Anything. Wasn't sure about gen but I've got a few things from them with good success.
    I looked at a number of running boards and settled on the patriots without seeing them up close other than a few pics above. THey are made in the USA and part of the sale goes to Folds of Honor.
    They are excellent and have far exceeded my expectations. Would highly recommend them. There nice looking and blend well With your white truck I beleive they have stainless steel. Hope this helps.
    Jsena likes this.
  20. Apr 2, 2017 at 2:29 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Thanx a lot man
  21. Apr 2, 2017 at 9:36 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    When choosing a model if they don't have crewmax, only option is reg cab or double cab.. would double still fit crew max? Anyone thanx a lot
  22. Feb 6, 2021 at 3:03 AM
    cbillig79
    cbillig79 2021 Tundra Limited CrewMax TRD Offroad 4x4
    North Carolina
    @louscrw with the patriot board installed, are they level with the body of the truck; or are they level with the ground?
    My Tundra came with the stealth boards. I did a 3/1 SST Ready Lift, and now I visually notice that there is a lean to the boads. The front end is higher than the back. I assume this was level with the ground... so the lean compensated for rake of the vehicle. Now that I have leveled the truck, that rake is gone. I have not measured, but I would guess there could be 3/4" slope from the front to back of the board on my crewmax. (and there seems to be no good avenue to adjust this with the current brackets)
    If the Patriot board sits level with the body, then I would consider buying the brackets ($90) to correct the lean. If not... then I will have to get more aggressive and slot my brackets and/ or work out some way to shim.
