Running Board Step Pad
Discussion in '1st Gen Tundras (2000-2006)' started by DrivePCH, Apr 16, 2021.
  1. Apr 16, 2021 at 8:13 AM
    DrivePCH
    DrivePCH [OP] New Member
    2004 Tundra Double Cab Limited
    I’m looking to replace my faded and worn out running board step pads on my 1st Gen Limited Double Cab. Can anyone confirm the Toyota part number 51773-0C900? Can anyone recommend an aftermarket option?
  2. Apr 16, 2021 at 11:40 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Checked my auto body ticket and can confirm that’s what they ordered/put on when I had a booboo on passenger side
  3. Apr 16, 2021 at 4:19 PM
    Professional Hand Model
    Hand Protectors
    You can search junkyards. I bought a pair for my 2002 a few years ago for about $125. Here is your part # new from stealership parts programme.
  4. Apr 19, 2021 at 4:39 AM
    eddieb02
    eddieb02 New Member
    Eddie
    2005 tundra sr5
    Stock for now
    Im looking for running boards as well, craigslist and Facebook market place are your best bets for used options. The main problem I have come across is it seems that anything after 2007 won’t fit, which limits buying options. If you are handy I have seen cheaper eBay options without mounting brackets you could make work.
  5. Dec 23, 2023 at 5:44 PM
    cedenk
    cedenk New Member
    2005 Tundra Crew Cab
    I know this is a couple of years old, but VERY confused. I'm assuming the step pad is simply the black rubber pieces that attach on the running board, right? If so, for my 1st gen DC there are two different sizes of pads. 28"x5" for front door, and 18"x5" for back door. The part mentioned here on all Toyota sites doesn't have a size, so I'm not sure if that is a single pad for the entire side (front AND back door). And given the price (higher when looking today), I would hope that is a much larger piece of rubber. What did you end up getting? I'm probably just going to get some machine screws and use those to fix my problem - which is that the pads are falling of the running board, due to clamps failing...
  6. Dec 24, 2023 at 1:49 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Were it me I would just "engineer" a solution on the cheap...
