Running board lights?
Discussion in '2.5 Gen Tundras (2014-2021)' started by wyone, Nov 10, 2018.
  1. Jun 23, 2019 at 7:49 PM
    #61
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Ok, thanks.
  2. Jun 23, 2019 at 11:27 PM
    #62
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    47A6E396-A389-49D7-BF20-F27B9C3D14BC.jpg Idk if this helps, but I installed puddle lights that turn on/off under these conditions:
    I unlock the truck with the key fob: lights ON.
    I lock the truck with key fob: lights OFF
    I stop the truck, pull the key and open the door: lights ON
    I turn the cargo light switch on: lights ON
    I turn the cargo light switch off: lights OFF
    I tapped a small pink wire in the driver side rocker panel, under the plastic door jamb trim. Obviously that’s the cargo light circuit.
  3. Jun 24, 2019 at 4:05 AM
    #63
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    It’s the blue one. The pic didn’t come out very good though.
    mav7021234 likes this.
  4. Jun 24, 2019 at 6:00 AM
    #64
    KennethFarmer
    KennethFarmer New Member
    Kenneth
    thank you... I need to go to store and look for some lights
  5. Jun 24, 2019 at 6:12 AM
    #65
    KennethFarmer
    Kenneth
  6. Jun 24, 2019 at 6:43 AM
    #66
    NCTundra18
    Jeff
    Candler, NC
    Thanks, i tested that once but couldn't remember. Then i went back to test the other wire and blew a fuse so i gave up.
  7. Jun 24, 2019 at 6:15 PM
    #67
    NCTundra18
    Jeff
    Candler, NC
    20190624_211016.jpg Finally got these put on today. Thanks to @madmatt for his help.
  8. Jun 24, 2019 at 7:20 PM
    #68
    madmatt
    madmatt New Member
    Ocala Florida
    Looks awesome! Good job! I finally got mine sorted out too!
    NCTundra18 likes this.
  9. Jun 24, 2019 at 7:30 PM
    #69
    NCTundra18
    Jeff
    Candler, NC
    Thanks, glad you got yours working.
  10. Jun 24, 2019 at 7:48 PM
    #70
    madmatt
    madmatt New Member
    Ocala Florida
    Not a good pic but I’m headed to bed and just took a pic from upstairs.
  11. Jun 29, 2019 at 11:41 AM
    #71
    madmatt
    madmatt New Member
    Ocala Florida
    Since (after whining like a little byotch about not being able to get power) I finally have power wherever I want it, I decided to keep going. Today I did bed lights.
  12. Jul 8, 2019 at 4:18 PM
    #72
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    With some help from @phabej I was able to get mine hooked up first try.
    I ran my power through the hole in the driver panel near the back. There is a rubber grommet that I drilled a little hole I'm for the power cable. For my 19 it was the biggest pink wire with no stripes on it.
    I grounded each set of LED strips on each side and ran everything through wire loom.
  13. Jul 8, 2019 at 5:40 PM
    #73
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    thanks to all on this thread i did this over the weekend:
    mav7021234 and (deleted member) like this.
  14. Jul 8, 2019 at 7:55 PM
    #74
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Now I just need running boards
    02D96660-761C-4EE4-BD5D-BBD96076AEA8.jpg 2831B2A6-6370-469A-91AF-DAB1BC5B29D9.jpg
  15. Jul 8, 2019 at 8:04 PM
    #75
    phabej
    phabej New Member
    2018 Platnium
    I have the lights and the wire already installed for my bedlights, I just need to find time to install them.
  16. Sep 3, 2019 at 12:30 PM
    #76
    soobahru
    soobahru New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    How did you ground?
  17. Sep 3, 2019 at 12:45 PM
    #77
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    I grounded the LED's by using the bolts that attach my side steps to my truck. I'll try to get a pic shot tonight, but I wont be home for a while. If you message me in about 4-5 hours it will jog my memory.
  18. Sep 3, 2019 at 1:01 PM
    #78
    soobahru
    soobahru New Member
    Ok. Thanks! I know what you are talking about.
    Truck looks great! Nice lift!
    Ynot_tonY likes this.
  19. Sep 4, 2019 at 9:23 AM
    #79
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Which LED strips did you get?
  20. Sep 4, 2019 at 10:26 AM
    #80
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Damn, Ron, I believe you started a puddle light revolution. What a great thread, very helpful wiring info. Got me really thinkin about the possibilities....:thumbsup:
    #80
    tinman10101 and NewImprovedRon like this.
  21. Sep 4, 2019 at 1:43 PM
    #81
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
  22. Sep 29, 2019 at 9:36 AM
    #82
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    how are those boxes holding up ?
  23. Oct 7, 2019 at 4:09 AM
    #83
    DamirDa
    DamirDa MURICA
    IMG_20191006_054744005.jpg IMG_20191006_063140230.jpg IMG_20191006_054721842.jpg IMG_20191006_054710211.jpg IMG_20191006_054558759.jpg IMG_20191006_054614390.jpg
    Finely done it! Feel free to criticize the long larger then life running boards. Wired it to cargo light and blinkers.
    [2pc 70-Inch] Truck Light Running Board LED Kit for Extended Cab & Crew Cab Trucks - [AMBER/WHITE] - Turn Signal Side Marker & Courtesy Light Bar Strip for Pickup Trucks, SUV, Cars, and Work Van [70"]
    by SPE Direct
    Learn more:
    https://www.amazon.com/dp/B078YDTG77/ref=cm_sw_em_r_mt_dp_U_G2XMDbWXANAA7
  24. Oct 7, 2019 at 9:00 AM
    #84
    SiberianTundra
    Greg
    War Machine
    Dude that is an awesome job. I wanted to do something similar but with spaced amber lights. But you totally provided the blue prints. Nice !
  25. Mar 3, 2020 at 6:43 PM
    #85
    Toshito
    Toshito New Member
    2017 Red Tundra Limited
    This is how mine turned out. I had to do some work to make it like this. If anybody wants any ideas I can share picture of how I did it.
  26. Mar 3, 2020 at 7:07 PM
    #86
    biebs96
    PA
  27. Mar 4, 2020 at 9:34 AM
    #87
    SiberianTundra
    Greg
    War Machine
    good info thank you!
  28. Jul 29, 2020 at 7:04 AM
    #88
    Jamesz
    Jamesz New Member
    I have a 2015 limited. i am about to do the same thing you show here. seems like a mix up between people saying its a brown wire or a grey/purple wire small 22 24 gauge. going to positap it ill know as soon as i do. what im concerned with is the amount of amps / watts its going to strain on the cargo light circuit. narrowed it down to 2.5 amp/30 watts total draw coming from 2 60 inch led strips i plan to use. think that cargo light will withstand that draw? ive read it can handle 7.5 amps which doesn't make sense to that gauge wire. you get so many different answers on these threads you seem like you know your stuff so i am asking you directly
  29. Jul 31, 2020 at 11:29 AM
    #89
    Jamesz
    Jamesz New Member
    Its a dark grey almost black wire which has a purple tint to it. 18 gauge. The pics make everything look larger but i got it on my first shot. Thanks man im wondering how long that adhesive will last.
  30. Jul 31, 2020 at 4:21 PM
    #90
    Jamesz
    Jamesz New Member
    I used 60 inch strip lights on the frames
