Running 285/75R17
Discussion in 'Wheels & Tires' started by JM14, Feb 27, 2019.
  1. Feb 27, 2019 at 1:18 PM
    JM14
    JM14 [OP] New Member
    Jacob
    2010 TRD CrewMax Tundra
    2" levelling kit, Borla exhaust
    Hey guys,
    I recently bought MRW Bronze NV305's for my 2010 Tundra CrewMax, these measure 17" in diameter, 8.5" wide and have a 0 offset (4.75" backspacing). I'm debating on running K02's in the 285/70R17 (32.7" diameter) or 285/75R17 (33.8" diameter) configuration. I would prefer the bigger diameter tires so I can fill out my wheel well but I'd like to avoid any major trimming to the truck. I have a 2" levelling kit in the front. Are any of you guys running a similar setup? Simply for reference, the tires installed on the truck in this pictures are 285/55R20's.
    Rica25 likes this.
  2. Feb 27, 2019 at 3:16 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    @Bailey is if I recall correctly.
  3. Feb 27, 2019 at 3:17 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
  4. Feb 27, 2019 at 3:17 PM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    I am :)
    285/75/17 or 34x11.5 Toyo ATII
    Jorgesworld86 and TXMiamiFan like this.
  5. Feb 27, 2019 at 3:20 PM
    JM14
    Jacob
    @Bailey So that truck is levelled 2 inches? No trimming required?
  6. Feb 27, 2019 at 3:28 PM
    Bailey
    CO
    Probably 2.5" of lift in the front. No trimming on the body mount or TOTAL CHAOS Skid Plates
  7. Feb 27, 2019 at 3:32 PM
    JM14
    Jacob
    @Bailey Any offset on your rims?
  8. Feb 27, 2019 at 3:33 PM
    Quebec
    Quebec New Member
    At 34", given your setup the only thing which may be limiting you is the 0 offset of the wheels.
    AT 35" you will have to trim or replace the skid plate.
    +25 offset and 285/75r17 and leveling will not require any trimming.
    Bigolbaddy likes this.
  9. Feb 27, 2019 at 3:35 PM
    Bailey
    CO
    I'm not sure of the exact specs on the Rock Warrior Wheels, here is some info found in another post:
    17" wheels - Width: 8", Offset: +50mm, Backspacing: 6.5"
  10. Feb 27, 2019 at 3:47 PM
    JM14
    Jacob
    @Quebec so you’re saying the offset of the wheels would make it worse? If I remained with +60, I wouldn’t have to trim anything?
  11. Feb 27, 2019 at 4:13 PM
    Quebec
    Quebec New Member
    +25 is the sweet spot to allow for most variation. +50 obviously works.
    60 offset brings the wheels in even more and I would think you'd be hitting your control arms before even worrying about articulation of the wheel or trimming.
    +25 is what the tundra needs to avoid this, luckily mfrs are finally coming around to see it.
    Edit: 60 gets you very close to the control arm with 35"s but requires skid plate trimming. Still works though.
    khens12 likes this.
  12. Feb 27, 2019 at 4:23 PM
    JM14
    Jacob
    @Quebec I already purchased the 0 offset wheels so I have to deal with it now. Most forums have been saying that negative offset doesn’t negatively affect wheel rub. I’m assuming the 34’s with 0 offset would be tight but fine, fill up the wheel well nicely.
  13. Feb 27, 2019 at 4:34 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    No rubbing with 285/75/17 on +25 Icon Rebounds and Bilstein 6112s set at 1.9”. I removed the bumper plastic liner in front of the wheels before I installed everything, so I don’t know if they would’ve rubbed.
    Hike likes this.
  14. Feb 27, 2019 at 4:41 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I had 0 offset before on 285/55/20, it rubbed on the front plastics so I heat gunned it and pushed it forward and it solved the issue. If anything rubs on 285/75/17 on 0 offset it might be the same just plastics but when I do get my wheels with +25 offset and maybe the same size tires I will do the body mount chop because eventually I will move up to 315/70/17 or true 35’s. Here’s a pic of the truck now on stocks, it needs small wheels and big tires bad!
  15. Mar 12, 2019 at 9:39 AM
    DMB4x4
    DMB4x4 New Member
    2014 Tundra SR5 CM 4x4
    What is your average mpg w the 285/75/17. Overall thoughts on that size tire? Think about ordering today
  16. Mar 12, 2019 at 10:55 AM
    equin
    Ed
    DFW, TX
    MPG went from about 16.4 at its best stock to about 14.1 or so. I’m guessing the 2” lift adds a bit of aerodynamic drag as well.
    I really like this size. It’s not too big to require a body mount chop or require more than 2” of lift, but it’s big enough to handle some light trail riding fairly well compared to the smaller stock tires.
  17. Mar 14, 2019 at 5:48 PM
    TXHUNTER85
    TXHUNTER85 New Member
    2015 Tundra Crewmax
    6112/5160, air ride 5000, icon add a lead pack, Icon Wheels, 285/75r17 Toyo at3, trd sway bar
    I am currently debating between the 285/75/17’s and a 315/70/17. Do you think the fuel mileage would vary that much between those two sizes?
  18. Mar 15, 2019 at 8:34 PM
    equin
    Ed
    DFW, TX
    Sorry. I made an error in the mpg. It used to be around 14.1 with 275/70/18s, but it dropped down to 12.8 with 285/75/17s. I knew mpg would drop with bigger tires, but I also knew before I bought my Tundra that it’s not the most fuel efficient vehicle to begin with.
    Rica25 likes this.
  19. Mar 15, 2019 at 8:42 PM
    equin
    Ed
    DFW, TX
    I don’t know, but my uneducated guess is that it may drop at least 1 to 2 mpg. The 315s are about 1/2” bigger in diameter and over an inch wider. Taller with a wider contact patch (and presumably heavier rolling weight) will definitely affect mpg as well as power.
    Another factor to consider is the added lift needed to fit the 315s. More lift affects aerodynamics, which also affects mpg. If ride height will remain the same for either size, then I suppose it wouldn’t be a factor.
  20. Aug 17, 2019 at 12:35 PM
    Bambam67
    Bambam67 New Member
    Voodoo pro 2019
    Method MR312 wheels, Toyo RT 35x12.50R18 +18 offset. Go Rhino RB20 running boards. 1” shim and 1” shackle
    JM14,
    Did you ever mount your 0 offset wheels with the 285/75r17 tires?
  21. Aug 19, 2019 at 11:47 AM
    4RunnerKid
    4RunnerKid New Member
    Oceano, CA
    '19 Cement CM SR5 4x4
    TRD Pro Bilsteins w/ single CB shim, 285/75-17 Falken AT3, Method 701, debadged, ceramic coated, Husky liners
    here's mine on 285/75 Falkens and 0 offset Methods. truck has Pro Bilsteins with a single CB shim up front. rubbed the front inner liner, mudflaps, and gets awfully close to the body mount. hope that helps
    COTundra23, CCLJ03, Bambam67 and 2 others like this.
  22. Aug 19, 2019 at 10:51 PM
    Bambam67
    Bambam67 New Member
    Voodoo pro 2019
    That stance looks perfect.
    That stance looks perfect. I was debating on whether to get the 285/70r18 with spidertrax spacers and stock Pro rims or this. I can get a c rated 285/75r17 tire (Nitto RG) and method mr312 wheels and have a softer ride. Thanks for posting! Helped me decide.
  23. Aug 19, 2019 at 11:10 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Those forums are wrong.
    A lower offset will cause tires to rub.
    My truck came second hand with 275/65/20’s on stock wheels instead of the 285/55/20. Nothing rubbed. Nothing touched. It was gravy. The Oe wheels are 20x9 +50 offset.
    As soon as I went to aftermarket wheels (20x9 +18) I had to remove my mud flaps.
    I’m not good with geometry but the short answer is yes, a lower offset with the same tire will change where it rubs.
    0 offset on these trucks is considered between somewhere between aggressive and wild. That’s the best way I can describe that. Lol.
    equin likes this.
  24. Dec 20, 2019 at 8:42 AM
    back_cast
    back_cast New Member
    Denver, CO
    This thread helped me make the decision, so i figured i'd contribute after going through with it. Now i need to rip off those step rails haha
    nomad_dave, equin, Skey44 and 2 others like this.
  25. Dec 27, 2019 at 9:53 AM
    Salty Shakas
    Salty Shakas MTN OPS
    2017 MGM Crewmax
    I just put on Bilstein 5100s to level my 2017, fronts are at the top setting. With 295/70/18 +25 Nitto Ridge Grapplers and no rub at all.
    BajaTundra1794 and drobb like this.
  26. Jan 9, 2021 at 12:52 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    @4RunnerKid would love to see any other photos of your setup you have!
    Seems like a good compromise between size and fitment- being able to use a 0mm offset wheel without too much rubbing opens up options a lot.
  27. May 25, 2021 at 7:16 AM
    whowe
    whowe New Member
    2012 Tundra Limited
    Bailey - nice set up. Will possibly be putting 285 75/17 (Icon Rebound or Six Speed) on my 2012 crewmax limited with OME sport suspension.
    Do you have any issues with gear hunting or other power lag etc ? Do you still get to all the gears without issues?
    I also live in CO and travel up and down I-70 in foothills trying to decide between 285 75/17 vs 285 70/17.
    Really do not want to regear (do you recommend regearing / did you regear for the 285 75/17)?
    Thank you
    Very Newbie, aka do not know anything...
    Will
  28. Oct 1, 2023 at 9:33 PM
    COAlpineTundra
    COAlpineTundra New Member
    2018 Cement Tundra TRD Off Road
    What rim size are you running on this?
  29. Oct 7, 2023 at 2:27 PM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    Dude, this entire thread is about 285/75R17 tires. So yeah 17 inch rims.
  30. Oct 9, 2023 at 12:40 PM
    COAlpineTundra
    Whoops, the devil's lettuce got me on this one.
    DirtyMike5 and pvmike[QUOTED] like this.
