Runaway Truck Wheel Sends Kia Soul Flying
Discussion in 'General Automotive' started by katekebo, Mar 27, 2023.
  1. Mar 29, 2023 at 5:31 AM
    #61
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    That happened to me in Mario kart
  2. Mar 29, 2023 at 5:55 AM
    #62
    FloridaMan80
    FloridaMan80 New Member
    As a non-engineer and mostly non-retarded person, I've learned that most "disasters" had numerous warning signs which were ignored before the catastrophe occurred. I don't believe everything normal and suddenly the wheel fell off. It was likely vibrating, making noises, pulling weirdly, and a host of other factors which were ignored.
    I'll put this up there with people driving down the road with the gas pump hose hanging off the back of their vehicle. They know full well something happened, they simply choose to ignore it and pretend it's fine.
  3. Mar 30, 2023 at 1:12 PM
    #63
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Although the offset is extreme and obvious, I don't think it had anything to do with the wheel coming off. Since the brake disc is still attached, we must be looking at the hub coming off the axle. The hub should be held on by a pinned nut and big washer. There should be a tapered roller bearing in there... but the hub needs to get past the nut and washer even if the bearing disintegrates into pieces. It's also going to take awhile for the bearing to disintegrate and it will be very obvious that something is wrong. So I think what we are seeing is the nut coming loose... which isn't caused by the offset but rather a failure to pin it properly.[​IMG]
  4. Mar 30, 2023 at 1:58 PM
    #64
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    This was my impression when I first saw the video. Improper lug nut torque / failure to inspect regularly. I don't discard metal fatigue, but that's forensics stuff.
  5. Mar 30, 2023 at 2:01 PM
    #65
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    I knew it! I'm surrounded by assho....I mean engineers.
  6. Mar 30, 2023 at 2:29 PM
    #66
    rruff
    rruff New Member
    You can see the inside of the wheel after it comes back and runs into the car again. You can see the disc rotor which means the lug nuts didn't come off, rather it was the hub. At first I thought the hub-knuckle bolts could have broken or come loose, but that should be visible if that was the case. Most likely the axle nut loosened and came off. I see some axles have "self-locking" nuts which sounds dangerous.
  7. Mar 30, 2023 at 2:36 PM
    #67
    C.I.
    Cesar Pedrin
    Cabo, Mx
    Honestly I didn't analyze the video, had to look at the screencaps to even connect what you were saying. Which leads me to belive some idiot forgot about the cotter pin/used an old or worn out pin... if it even uses it.
    User error most likely.
