Rugged off road Toyota 1” rear lift block kit
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Oct 7, 2023.
  1. Oct 9, 2023 at 5:25 PM
    And just as an addendum to the above, @au.ramsey
    Ideally, you want to cross-tighten. I'm that anal-retentive mofo that'll get all the nuts to flush with the u-bolt shafts (or to some arbitrary thread count showing if long as hell), then go criss-cross 1-4-3-2 for 8 half turns, 6 half turns, 4 half turns, then 2 half turns and usually I'm in the ballpark by then, starting to snug up.
    It's probably overkill, and I dunno if anyone actually follows it, but given that lower plate is supposed to share the load across both sides, it's the safe thing to logically do and it's what I've been doing the last 35-40 years of my life on every truck I've touched.
    EDIT: Actually, I feel better, the "HINT" from the FSM page @assassin10000 posted suggests doing the same. Maybe I'm not so OCD after all.
    Weagle[OP] likes this.
  2. Oct 9, 2023 at 5:33 PM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    you kicked in my OCD. Tomorrow morning, I’m gonna go out and loosen them and then re-snug them to 98 foot pounds
    I did alternate, and I may not go to that extreme if they all are the same length below the nut
  3. Oct 9, 2023 at 5:44 PM
    Just know u-bolts can stretch with proper torquing (and def with overtorquing), so ... :rofl:
    Just count the threads on both sides and if you're within a thread or two, don't sweat it.
    Weagle[QUOTED][OP] likes this.
  4. Oct 11, 2023 at 8:32 PM
    Weagle
    Prattville, AL
    now after watching a video on replacing the ball joints and the front shocks/coil overs, could’ve done this myself as well
