Rubbing with larger tires? Enter the Relentless Fab CMC plates!
Discussion in 'Relentless Off-Road Fabrication' started by Relentless, May 7, 2014.
  1. May 7, 2014 at 4:00 PM
    Relentless
    Relentless [OP] Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    As with other Toyotas, the front cab/body mount on '07+ Tundra's is fairly obtrusive into the front fender wells and larger tires and negative offset wheels will make your truck rub when turning. Well we now have a solution to eliminate that embarrassing rub! Cut into that CMC and weld on our new CMC boxing plates. They free up over an inch of fender well tire room- Tested on an '11 Tundra with severe rub issues while running 35's on a Procomp 4" lift, our plates gave plenty of room!
    Plates can be ordered right off our website. Check them out: http://www.relentlessfabrication.com/collections/toyota/products/07-tundra-cab-mount-chop-plates
    Link to Post containing outline of install procedure.
    And dont forget the Tundra's.com discount code when ordering! :)
  2. May 7, 2014 at 7:52 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I will be getting some of those since another vender I questioned about them hasn't confirmed he has the drawing still to cut more.
    FlashCulprit likes this.
  3. May 7, 2014 at 8:51 PM
    Relentless
    Eric
    Ah didnt even know there were others out there on the market. Do the others have the bend in them like ours? I was going to initially make them flat like our Tacoma/FJ/4runner plates but it just didnt make enough of a clearance difference, hence more cutting and the additional bend. Probably net us another 1/2" clearance easily
    619Tundra likes this.
  4. May 7, 2014 at 8:54 PM
    csuviper
    Broomfield, CO
    Well the other vender only has them for sale for a Tacoma. Said he did one for a tundra a while back but wasn't sure if he still had the drawing for the laser cutter. I assume his was flat
  5. May 7, 2014 at 9:17 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Good price!
  6. May 7, 2014 at 9:29 PM
    Relentless
    Eric
    Gotcha, well we just did this chop for a customer and designed the plates. They fit great and offer maximum clearance. If you're interested, feel free to toss in an order on our site and we'll send out a pair for ya!
    Thanks! I think for what it is, we're giving them at a very fair price. Between cutting/cleaning/bending/shipping, we arent making much! ;)
    TruckyTruck[QUOTED] likes this.
  7. May 8, 2014 at 10:33 PM
    TruckyTruck
    Gary
    Absolutely. And I may be needing these very soon.
  8. May 9, 2014 at 7:02 AM
    csuviper
    Broomfield, CO
    Ordered. Thank you for the 10% and free shipping :)
    Was going to add some gussets for the heck of it but the shipping cost brought it out of my price range for not having a project for them at the moment.
    TruckyTruck likes this.
  9. May 9, 2014 at 11:37 AM
    Relentless
    Eric
    Thanks man. Already packaged up and will be mailed out this afternoon.
  10. May 16, 2014 at 1:39 AM
    Beer'd_n_yotas
    Beer'd_n_yotas New Member
    2013 Super White Tundra
    Plasti-dipped and lowered!
    These are nice, I like the curve to them. More to add to my parts list!
    Relentless[OP] likes this.
  11. May 19, 2014 at 10:27 PM
    csuviper
    Broomfield, CO
    Might take me awhile to add on. No welder yet.
    ColoradoTJ likes this.
  12. Jan 12, 2016 at 3:15 PM
    csuviper
    Broomfield, CO
  13. Jan 12, 2016 at 3:16 PM
    csuviper
    Broomfield, CO
    Updated the link on the OP because their site moved locations from .us to .com
  14. Jan 12, 2016 at 5:28 PM
    Relentless
    Eric
    It's $24.99 for the pair, both sides. They're in stock currently. If it says they're out then the stock just needs to be updated, we made some more about a week ago.
  15. Jan 12, 2016 at 5:49 PM
    If I'm not mistaken that price includes shipping. Mine are going in soon. Well worth it. Looking forward to see your 2nd/3rd gen Tundra skids, Relentless.
  16. Jan 12, 2016 at 8:06 PM
    csuviper
    Broomfield, CO
    I need to install mine as well.
  17. Jan 22, 2016 at 7:48 PM
    Relentless
    Eric
    We havent done one, but may try to in the future. It's a pretty straight forward process.
    1. Jack up the front of the truck and remove tires, rest on jack stands
    2. pop hood and remove the battery ground.
    3. Clean off the body mount in the rear of the fender well, trim a bit of the plastic around it if it has not already been cut.
    4. Hold the plate up with the small tapered side toward the outside of the truck, and the bend in the bracket in toward the body mount. Trace the cut line with a paint marker, silver sharpie, etc.
    5. cut to the inside of the line until the chunk of body mount to be replaced falls loose.
    6. Realign the chop plate to the body mount and grind it down until the plate fits all around.
    7. When fitted snug and cut back to the desired amount, clean the paint off near the edges of the cut, and clean a location on the frame for the welder ground clamp.
    8. Tack weld and then begin stitch welding the chop plate into place. DO NOT weld all in one shot, it will overheat the body mount bushing and melt! Use a blow gun with compressed air to cool between stitch welds.
    9. Once allowed to cool in between welding and then stitched completely paint the mount inside and out and repeat the process on the other side.
    10. Paint all bare metal thoroughly, then reinstall tires and torque lug nuts to factory spec. Enjoy less rubbing!
  18. Jan 22, 2016 at 10:28 PM
    Relentless
    Eric
    Opposite side of NV. Like 8 hours north
  19. Jan 23, 2016 at 3:12 AM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    Does anyone have a picture of these installed?
  20. Jan 23, 2016 at 5:44 PM
    Relentless
    Eric
    Kinda blurry, but you get the idea
    And this is with the piece I cut off held over the cut body mount to show how much clearance gain is actually possible
    And this is how I mark them to cut.
    LVLDUP18 and Jsena like this.
  21. Feb 17, 2016 at 9:54 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Just order these cant wait to get them and get them on! Didn't see the discount code till now lol. Anyways you guys have any plans of making sliders like this for a 12?
    JDimaggio4x2 likes this.
  22. Feb 18, 2016 at 9:40 AM
    Relentless
    Eric
    We potentially do, but we havent had a DC Tundra in our shop, only CrewMax's
  23. Feb 20, 2016 at 8:19 AM
    Virgils12
    I'm having trouble tracking the cmc plates I ordered. Wondering if you could give me a little help?
  24. Feb 20, 2016 at 9:38 AM
    Relentless
    Eric
    What's your order number and I can see if I can find anything
  25. Feb 20, 2016 at 9:55 AM
    Virgils12
    Invoice ID
    c5870922244.1
    That's from my PayPal
  26. Feb 20, 2016 at 10:03 AM
    Relentless
    Eric
    I need our website order confirmation number you should have received in an email, not Paypal transaction number/ID.
  27. Feb 20, 2016 at 10:09 AM
    Virgils12
    Never mind kind sir they came just now.
  28. Mar 15, 2016 at 11:44 AM
    PfdHoser
    PfdHoser New Member
    Pueblo, Co
    2013 Tundra, Bone Stock... For Now
    Just ordered mine.
  29. Mar 15, 2016 at 11:54 AM
    Come down and get some firewood. You have full access to my welder, torch, etc.
    rons23, Relentless[OP] and T-Rex266 like this.
  30. Mar 15, 2016 at 7:50 PM
    csuviper
    Broomfield, CO
    Seriously. You are very generous!
