Rubbing sound after I lifted my tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Punisher4x4sr5, Apr 30, 2018.
  1. Apr 30, 2018 at 6:15 PM
    Punisher4x4sr5
    Punisher4x4sr5 [OP] New Member
    Hello, I hope you guys can help. I put a 3/2 readylift on my 2016 Toyota tundra 4x4. But actually lifted the front 4.5". Now I have a rubbing/stretching/slight pop sound when I turn wheel all the way. I did put the 2 differential spacers in. And the sway bar spacers . The truck drives very smooth. This issue only happens when I back up and cut the wheels all the way.
  2. Apr 30, 2018 at 6:24 PM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    What size tires? Wheel offset? I’d bet tires are rubbing/hitting.
    TXRailRoadBandit73 likes this.
  3. Apr 30, 2018 at 6:26 PM
    Punisher4x4sr5
    Factory 275 60 20. It's not rubber the small mud flap or skid plate.
  4. Apr 30, 2018 at 6:29 PM
    Punisher4x4sr5
    I don't know what offset means.
  5. Apr 30, 2018 at 6:30 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    How much the tire/wheels sticks out
  6. Apr 30, 2018 at 6:31 PM
    Stroke250
    Todd
    Idaho
    2023 Ford F-350
    If you are stock tires/wheels, offset shouldn’t matter in this case.
    With a 3/2, you say you got 4.5 in front? How was that accomplished?
    Have you went back over everything since you just installed it?
  7. Apr 30, 2018 at 6:32 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Rule out rubbing.
    Find a pavement incline or decline, put it in park, and crank the steering wheel all the way, both sides, look for contact. Put the truck in the opposite direction and do the same, look for contact. Sometimes there's no rubbing at full lock on level ground.
    TheBeast and Stroke250 like this.
  8. Apr 30, 2018 at 6:35 PM
    Punisher4x4sr5
    The wheel doesn't stick out the fender. It's factory rims & tires.
  9. Apr 30, 2018 at 6:35 PM
    Sounds like you may be over extended.
    Stroke250 and JoshuaA like this.
  10. Apr 30, 2018 at 6:38 PM
    Punisher4x4sr5
    How would that happen and what can I do to fix it?
  11. Apr 30, 2018 at 6:41 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    I had the same problem in my 08. If you had it at full lock one way or the other and the wheel dropped a little you would hear a loud pop in the suspension. Like trex66 said your over extended.
    Drives fine and no problems just at full lock sometimes pops.
  12. Apr 30, 2018 at 6:46 PM
    Punisher4x4sr5
    How can it be fixed? Will it tair something up driving like that?
  13. Apr 30, 2018 at 6:48 PM
    You’re stressing out all of your components. I’m not very familiar with ReadyLift, but you may need to have it reset to 3” if that’s the size you wanted and purchased.
    BTBAKER and Stroke250 like this.
  14. Apr 30, 2018 at 6:48 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    Not that i know of. I drove like that for 6 years never an issue.
  15. Apr 30, 2018 at 6:52 PM
    Punisher4x4sr5
    T-rex, how do you reset to 3"?
  16. Apr 30, 2018 at 7:21 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I'm kinda confused as to how you got 4.5" out of a 3" spacer kit? If you truly got an extra 1.5", you're definitely over extended. If you're closer to 3" take a look at your skid plate. I diagnosed a 3" on a Tundra at work recently. At full lock, sitting still the tires just cleared the skid plate. At full lock in motion there was just enough torque to make the tires graze the outer rear corners of the skid pan. A little angle grinder action fixed the rubbing.
  17. Apr 30, 2018 at 7:27 PM
    Can you post the link to the exact product you have?
  18. Apr 30, 2018 at 7:31 PM
    Punisher4x4sr5
  19. Apr 30, 2018 at 7:42 PM
    Punisher4x4sr5
  20. Apr 30, 2018 at 7:42 PM
    So how are you at 4.5” at the front on a 3” spacer and 2” block in the rear?
    Stroke250 likes this.
  21. Apr 30, 2018 at 7:45 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    So you have a 3- 4.5" lift with the stock UCA's?
  22. Apr 30, 2018 at 7:45 PM
    Punisher4x4sr5
    I measured from the top of the tire to the fender. It was 5" before and now it's 9.5"
  23. Apr 30, 2018 at 7:49 PM
    Measure from center hub to fender.
    SouthBoundSteve likes this.
  24. Apr 30, 2018 at 8:08 PM
    I bet he's rubbing skid plate or small mud flap in front of tire, why don't you have someone with you and walk while u drive walking speed to see if they can see or hear where it's coming from go to an empty parking lot n try
  25. May 1, 2018 at 1:25 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    And you had the same wheels before and after install?
  26. May 1, 2018 at 1:33 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    Also did you use the spacers for the sway bar?
  27. May 1, 2018 at 4:54 AM
    Punisher4x4sr5
    Same wheel and yes I use the sway bar spacers
