Rubbing Issue Confusion
Discussion in 'Wheels & Tires' started by tgrave1, May 3, 2021.
  1. May 3, 2021 at 1:37 PM
    tgrave1
    tgrave1 [OP] New Member
    Huntington Beach, CA
    2020 SR5 TRD 4X4 Sport
    Eibach Pro Kit. Camburg UCA's. Coachbuilder bumper shims. Cab mount chop. N-Fab side steps. 18 inch Method 308 Roost wheels. Falken Wildpeak AT/3 tires (295-70-18). Gator EFX bed cover.
    I have read through a bunch of threads and am still a little baffled as to what is going on with my setup. Running Method 308's (+18 offset) and an Eibach Pro Kit on the top setting (about 3 inches) in the front and a 1 inch shackle in the rear. I am still getting a little rubbing on the front bumper and cab mount even though I didn't expect to. This confuses me since I seem to read that some members run a similar wheel/tire setup with just a level lift and don't seem to experience any rubbing at all. I have decided that I don't really care for the truck to be as high as it is and would like to remove the rear Shackle and take the front down an inch to improve the ride, but I am concerned that the rubbing will be considerably worse. Is there something that I am overlooking that can be done to avoid rubbing with a simple level lift or am I going to end up having to do some cutting/trimming? Thanks in advance for any advice or links to posts that I may have missed.
  2. May 3, 2021 at 1:42 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Eibachs lift numbers are over stated. Have you confirmed you actually got 3” of front lift? Most all only get between 2-2.5” of lift. Anyhow, what size tire are you running?
  3. May 3, 2021 at 1:52 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    alignment numbers?
  4. May 3, 2021 at 1:52 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Your tire width is going to play a role in this.
  5. May 3, 2021 at 2:05 PM
    tgrave1
    The suspension definitely seemed to lift that much. I was running some pretty good reverse rake after putting them in so I had to add the shackles to level. running 295/70/18's. Sorry. Should have put that in the first post.
  6. May 3, 2021 at 2:06 PM
    tgrave1
    I don't have the alignment numbers but was wondering if the alignment shop didn't really know how to adjust to help me out.
    Loose likes this.
  7. May 3, 2021 at 2:20 PM
    tgrave1
    This was with the 1 inch shackles in the rear. Still looks a little higher in the front to me most of the time.
  8. May 3, 2021 at 2:29 PM
    Destro748
    Destro748 New Member
    H
    2018 Cement
    i've got 3.5" lift and running 295/18 and still have slight rubbing on full lock. i do not think there isn't rubbing under 3" lift with 295s. Some have said the tires also play a big role since many are running the Nitto Ridge Grapplers and they don't seem as tall or wide. You'll need to remove the thin guards and push the front liner in. I know others have opted to get 1/2" shims to push out the front bumper and heat the liners and push it in with a small ball. Just my opinion but if you're not rubbing the bodymount, you're fine.
    Elduder likes this.
  9. May 3, 2021 at 2:31 PM
    Elduder
    Elduder New Member
    Eibach doesnt state 3", Toytec does.
    Both Eibach stages are quoted as level with the rear, which is at most a 2.25" lift.
  10. May 3, 2021 at 2:35 PM
    Elduder
    Elduder New Member
    Offset is the key, I ran 315s with Icon wheels on my Pro at 2" of front lift.
    Methods 18s are 18x9 +18, which would be comparable to the Icons if they were a 17x8.5 +12. So the Methods are sticking out 1/2" further than my Icons were. Lift wont correct this if you ever take it off road as the suspension will still cycle the same and will rub at some point.
    Best and easiest option is to get a cab mount chop and either push the front bumper plastics forward or remove them all together.
  11. May 3, 2021 at 2:38 PM
    Elduder
    Elduder New Member
    BroTun13, BiggHertz and Destro748 like this.
  12. May 3, 2021 at 2:47 PM
    tgrave1
    Thanks for the info. Perfect stance on your truck in my opinion. Looks great! Apparently I may have bumper shims and a CMC in my near future.
    Elduder[QUOTED] likes this.
  13. May 3, 2021 at 3:14 PM
    Destro748
    H
    2018 Cement
  14. May 3, 2021 at 3:54 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Agreed me a lift will allow you to fit larger tires, but to many, a lift where you can't use the full range of travel without clearance issues is an unacceptable compromise. :sawzall::welder:
    From another post of mine:
    While waiting on my front coilovers to come in, thought I'd better test fit and perform a drivability test.
    MR701 18x9 +25 w/ 35x12.50r18 Ridge Grapplers at stock ride height with mild BMC, CoachBuilder front bumper shims, removed front flaps, happy to report that there is no rubbing.
    -JS
  15. May 3, 2021 at 6:01 PM
    Elduder
    Elduder New Member
    Sexy
    BiggHertz[QUOTED] likes this.
  16. May 3, 2021 at 8:45 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    Eibach on the 2.5 setting with 35x12.5 on 17x8.5 +25 Icons. No CMC or bumper rub but everything is very close. Your caster needs to be adjusted to clear the body mount.
    tgrave1[OP] and Elduder like this.
  17. May 3, 2021 at 8:55 PM
    MoonRock2021
    MoonRock2021 New Member
    2021 TRD Pro Crewmax Lunar Rock 2021 4Runner Nightshade
  18. May 4, 2021 at 8:05 AM
    tgrave1
    Huge thanks for all of the info everyone. I think my plan is to go with the bumper shims first to try and avoid cutting if possible, and then adjust the caster and see where I end up. Seems like my offset may be the variable that causes issues.
    MoonRock2021 and Elduder like this.
  19. May 4, 2021 at 8:28 AM
    Zelphrin
    Zelphrin New Member
    Jon
    2014 Toyota Tundra Limited Double Cab
    Aftermarket antenna, interior LED lights, license plate LED lights, LED bed lights, 6" Rough Country lift kit with V2 rear shocks and front lifted struts (no spacers), ION 134 20x10 matte black wheels with Toyo Open Country AT2 33" tires
    Was gonna say, when you start adding offset wheels, that's where you may or may not get some rubbing. Mine are -19 offset, and there's no initial rub while driving or turning, but there is a rub... simply not noticeable.
  20. May 4, 2021 at 8:32 AM
    MoonRock2021
    Here is mine with bumper shim added.
    180329018_3851640951615758_5503762584014_788176f3451f003c4d2d6eb4d4256d23b18f4f6b.jpg
    tgrave1[OP] likes this.
  21. May 11, 2021 at 4:48 PM
    Burdturger
    Burdturger New Member
    I too am having terrible rubbing with my new set up. Got 295/70-18 with a 0 offset wheel. Got the BMC still rubbed. Added caster and still hitting but also hitting the front bumper now. Got 6112, top setting no shims and camburg UCA. All i can think is maybe adding shims on bumper and shocks.
  22. May 11, 2021 at 4:51 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    How much caster do you have with the Camburg UCAs?
  23. May 11, 2021 at 4:58 PM
    Burdturger
    Last I know it was about 6 degrees. I had an alignment done and thats what they set it to. Had a hard pull to the right and they "adjusted" it but I didn't get the sheet. So now with my new set up and had horrible rubbing, the advice I've received from many people is just play with the caster. I don't really know what it is now since i don't have an alignment machine just trying to get it not to rub.
  24. May 11, 2021 at 5:23 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    With that much caster and 0 offset you are probably going to need a much more aggressive CMC
  25. May 11, 2021 at 6:07 PM
    F.N.G MOTO
    F.N.G MOTO New Member
    2019 Tundra TRD
    You were able to run 35’s without any trimming? I’m a bit confused, thought 35’s were too big. I was going to go with 33’ with just a front level. Not looking for a lift.
  26. May 11, 2021 at 6:23 PM
    Kanobi13
    Kanobi13 New Member
    No trimming just cutting lol
  27. May 11, 2021 at 7:29 PM
    F.N.G MOTO
    2019 Tundra TRD
    Lol. I don’t want to get into all that. 33’s it is I guess.
  28. May 11, 2021 at 7:52 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    With Mild BMC, CoachBuilder Bumpershims, and removing front flaps, I have no rubbing lock to lock, from full droop through full bump, which is more important to me than having no rubbing at static ride height (stock as I am now or the 2.25-2.5 inch ride increase from my inbound coilovers :fingerscrossed:). Hell I didn't even rub on my OE skid...
    -JS
  29. May 11, 2021 at 8:14 PM
    F.N.G MOTO
    2019 Tundra TRD
    I’m in the process of learning all this $h!t so I’m going to google everything you just said lol.
  30. May 11, 2021 at 8:18 PM
    Kanobi13
    Kanobi13 New Member
    Translation theres alot that goes into for no rub :rofl:
