Rubbing fender liners after lift
Discussion in 'General Tundra Discussion' started by Dustydirt19, Jun 4, 2017.
  1. Jun 4, 2017 at 8:32 AM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Got a 6in lift put on Blue Betty and at full lock in reverse that bitch rubs the fender liner. I bought a heat gun to heat up and push the wells in a bit and was looking for some info on how to do this from you fine gentleman that have. Temp used, methods etc..
  2. Jun 5, 2017 at 10:23 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    When I did the heat method (700 F) it looked amateur. The Temps allow the fender liner to be melted quicker or slower depending what you start of with.
    I obligated the extra time to shim the bumper giving me a 1/2 inch forward. @Coachbuilder does make a shim for the bumper but I used washers. I do not have any rubbing forward and/or reverse, at full lock.
  3. Jun 5, 2017 at 10:35 PM
    Achuop
    Achuop Stormtrooper 5.7
    Anthony
    Orange County, CA
    2015 Tundra Crew Max TRD 4x4
    TRD Pro grill, Magna Flow Exhaust, 3/2 leveling kit, TRD sway bar, black out emblems, Bakflip G2 cover, 20” ProComp wheels and Tires and lots of love and affection.
    I just trimmed the plastics.
  4. Jun 5, 2017 at 10:41 PM
    Talking bout small mud flaps in front of tire? I have a 6" lift on 35*12.50*20s no wheel spacers I noticed that the plastic fenders inside wheel well in front of tires were cut and rear of fog lights exposed so i bought new ones and the small mud flaps came with and they rubbed so the bottom bolts that hold metal bumper ends i loosened up and had a buddy pull the bottom out towards him and tightened back up then i used 2 small short i dont know thickness but its like a wood screw and I screwed the front mud flap to the wheel well front fender and it kinda sucked in that mud flap so at full turn fwd rev no rubbing
  5. Jun 6, 2017 at 2:04 AM
    Dustydirt19
    Dustin
    Duluth, MN
    The small mudflaps had been donated to the garbage awhile ago lol. But I'll try jabbing the liners forward
  6. Jun 6, 2017 at 5:33 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Along with shimming the front bumper corners, you could also just loosen the two (or is it 3??) large bolts that hold the liner bottom and bumper cover assy together and pull the whole bumper end forward. There's some wiggle room. Depending on where you bumper ends are currently secured, you could get up to half an inch.
    Half an inch could make allll the difference.
    -She
    Dustydirt19[OP] likes this.
  7. Jun 6, 2017 at 5:56 AM
    So true
  8. Jun 6, 2017 at 7:37 AM
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    This is what I just did. cave about .5-.75" I threaded the bolt about .5 to the rear and .5 inward. It's also easier if you thread the bolt first, then push the liner so the tip of the bolt catches so you know you use the same hole.
    On the pass side, I just threaded it not knowing if it was going to line up. It did but at an angle.
  9. Jun 6, 2017 at 2:38 PM
    Dustydirt19
    Dustin
    Duluth, MN
  10. Jun 7, 2017 at 4:29 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Did you drill new holes in the liner? Are they bolts or self tapping screws?
  11. Jun 7, 2017 at 6:59 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  12. Jun 7, 2017 at 7:00 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Post #45
  13. Jun 7, 2017 at 7:23 PM
    Dustydirt19
    Dustin
    Duluth, MN
  14. Jun 7, 2017 at 7:34 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    No I'm not. I cut a little too much. Don't cut as much as I did if you are worried
  15. Jun 8, 2017 at 8:04 AM
    renlo
    renlo New Member
    Rene
    Yes, new hole in liner, same hole on bumper
  16. Jun 8, 2017 at 10:44 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Which 3 bolts are you talking about?
  17. Jun 8, 2017 at 1:41 PM
    Bear
    Bear
    Custer, SD
    I believe there is a small in the fender liner, and two larger ones that attach the bottom of the fender liner to the front bumper. Those 2 larger ones can be loosened slightly and the whole bumper corner can be slid forward in a slot hole. I got about 1/2 in out of mine and solved the reverse rubbing sound.
  18. Jun 8, 2017 at 1:46 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Gotcha
  19. Jun 8, 2017 at 5:08 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Is it the corners that move or the liner that would be pushed forward?
  20. Jun 9, 2017 at 1:40 AM
    Bear
    Bear
    Custer, SD
    If memory serves (it's getting a little rusty these days...too much other junk up there) the liner piece moves.
    My last response was a little misleading.
  21. Jun 9, 2017 at 5:16 AM
    Dustydirt19
    Dustin
    Duluth, MN
    All good. I kind of got what you meant but just wanted to make sure
