Rubbing after new UCAs
Discussion in 'Suspension' started by RadSki, Mar 27, 2021.
  1. Mar 27, 2021 at 8:18 PM
    Qwazymoto
    Qwazymoto New Member
    AKTCHUALLY UR WRONG
  2. Mar 27, 2021 at 8:20 PM
    rustytoys
    rustytoys New Member
    Nah.
  3. Mar 27, 2021 at 8:22 PM
    rustytoys
    So what don't you understand about this diagram?! I am truly confused as to why you guys can't wrap your head around this...
    The green line is positive - as you can see the green line is pushing the wheel towards the bed of the Tundra - or body mount.
  4. Mar 27, 2021 at 8:26 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    The Camburg UCAs, like most after markets, move the upper ball joint/uniball aft which allows more alignment in the LCA. There is a reason most prefer 4+ degrees in the Tundra. @rustytoys please go get an alignment and ask for 0 or negative numbers and update us on how great the clearance from the body mount is. In the diagram the wheel pushes forward from the LCA, not the stationary UCA.
    Edit: go take the spindle off your upper control arm and move it around it will make sense.
  5. Mar 27, 2021 at 8:31 PM
    rustytoys
    Correct, stock UCA no body mount rub - Camburg positive caster UCA and you now have body mount rub on your truck as your wheel has been moved toward the bed of the truck; I'd say its only set back maybe 1/2" or 3/4" max if you measured the middle of the tire - but it is setting back some now. Just chop the body mount, would be a nice upgrade really.
  6. Mar 27, 2021 at 8:31 PM
    RadSki
    RadSki [OP] New Member
    Radek
    2019 Toyota Tundra Crewmax SR5 TRDoffroad
    Bilstein 6112's up front set 2nd from top Bilstein 5160's in rear Camburg UCA's Camburg 1.5 Shackles Toytec Diff Drop kit Toytec Carrier Bearing Drop kit Readylift skid plate kit Trd front sway bar Trd Skid plate Trd Cold Air Intake Trd cat-back exhaust Trd rear sway bar Fuel Vector 18x9 +20offset Falken AT3W's 295/70r18
    So your saying if i drop the numbers to 4+ i should clear the body mount? Im at 6.6 and im rubbing at half way thru turning the wheel forward or reverse this is what makes no sense! Rusty had a valid point i didnt rub with stock arm that had less caster??
  7. Mar 27, 2021 at 8:33 PM
    rustytoys
    I'm not a mariner, but it sounds like you are saying the upper ball joint on a Camburg moves the wheel towards the bed of the truck correct? Kind of like I have been saying for the last hour?!
  8. Mar 27, 2021 at 8:35 PM
    Qwazymoto
  9. Mar 27, 2021 at 8:36 PM
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    Read the post. The UCA goes aft which increases the caster angle positive (moving the wheels contact patch forward)
  10. Mar 27, 2021 at 8:36 PM
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    Good luck OP. This has derailed to full retard!
  11. Mar 27, 2021 at 8:37 PM
    rustytoys
    Since when did the Caster angle of an Upper Control Arm start making changes to a lower control arm? Damn, those are some magical control arms you guys got!
  12. Mar 27, 2021 at 8:37 PM
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    You forgot to make the positive caster driver have a frowny face!
  13. Mar 27, 2021 at 8:38 PM
    Qwazymoto
    Thought about it but I was laughing my ass off when "drawing" it.
  14. Mar 27, 2021 at 8:45 PM
    rustytoys
    An Upper Control Arm is only affecting the top control arm area, the Lower Control Arm is not moving - as all of the diagrams and drawings suggest - this is perhaps why you guys can't wrap your head around this.
    When you move the upper ball joint towards the rear of the Truck bed (like Camburg UCA's do with built-in positive caster) - and you keep your stock lower control arms as they were - then obviously the mostly top portion of your wheel/tire follow that ball joint. It's that simple.
    alb1k likes this.
  15. Mar 27, 2021 at 8:58 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
  16. Mar 27, 2021 at 9:09 PM
    rustytoys
    I drew this illustration so you guys can understand this better, as those other ones are misleading - as they all seem to change the lower UCA position. In the real world this is what a Camburg high-caster control arm does - and this is why the OP's tire is now hitting his body mount.
  17. Mar 27, 2021 at 9:12 PM
    RadSki
    Radek
    @rustytoys so your saying if i decrease the castor on the LCA the tire will move forward following the UCA's ball joint but will still remain positive since it has built in positive caster or am i missing something??
  18. Mar 27, 2021 at 9:17 PM
    rustytoys
    Not sure if I totally follow, but you can overcome built-in-caster of a UCA - they are "building in" caster - but that doesn't mean you couldn't overcome it. However, moving the lower UCA while keeping a Camburg upper would I think end up really wonky - like the reverse of those old 60's funny cars? I guess
  19. Mar 27, 2021 at 9:20 PM
    #49
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    What you are missing is that the largest diameter of the tire moves forward with the increased caster. That is why higher caster increases the chances of clearing the Body mount. The LCA plays a role in this also. There is a reason there is adjustability in them.
  20. Mar 27, 2021 at 9:25 PM
    #50
    rustytoys
    I never touched that lower ball joint circle in my illustration - it stayed in exactly the same place in both examples. As you can see the tire moved towards the bed of the truck.
    However, lets entertain what you are saying - if you are correct, then why exactly did the OP not rub his body mount with stock caster (2'ish positive) - but now with MORE positive caster in the 6.5 range he now rubs his body mount? His stated problem sort of disproves what you are saying. If you disagree with why he is rubbing now - after he has MORE positive caster - then please explain?!
  21. Mar 27, 2021 at 10:05 PM
    #51
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I don’t know about Camburgs, but one who helped me with my Total Chaos had me at +3. Now, mine is a Gen I. I’m actually around +2.8. I think later model Tundras go higher towards +6, but it seems you are too high. Positive moves the wheel back from the top, the bottom is unchanged.
    rustytoys likes this.
  22. Mar 28, 2021 at 9:10 AM
    #52
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Everyone else making pictures, didnt want to feel left out
    Hightide likes this.
  23. Mar 28, 2021 at 10:10 AM
    #53
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Wow, this is mind numbing.
    Does everyone agree that the aftermarket UCA has the Upper ball joint location moved further back(aka towards rear of truck) compared to the stock UCA?
  24. Mar 28, 2021 at 10:45 AM
    #54
    RadSki
    Radek
    So i keep reading about this issue and ppl claim that with the Camburgs you can shoot for higher numbers in castor because it pushes the ball joint further back to avoid the bmc and increases caster because of the way they are built! 7's 8's even and bring camber in at the negative, .01-.03 with even toe because they are purposely designed that way with crazy high caster for aggressive driving, any thoughts on this for the experienced? Still
    Waiting on Camburg to email me back their insights, Thanks to all for good and bad info :)
  25. Mar 28, 2021 at 11:02 AM
    #55
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Some cool shit here!!
  26. Mar 28, 2021 at 11:17 AM
    #56
    rustytoys
    Look at my illustration again, pushing the ball joint back (towards cab) is pushing the wheel right into the cab body mount... you do see that right? I mean, you are experiencing exactly that issue - your wheel is now hitting your cab body mount AFTER Camburg installation, correct? All of the answers are right there.
    I have already told you that you need to chop your cab body mount to fix this. Or, if you want to complicate your life - you can buy new lower-caster control arms like SPC or Zone, install them, get another alignment, go through the entire process all over - and cross your fingers that +1 built-in caster won't rub... OR, buy all new smaller tires and different offset wheels - again, huge amount of work and money. Now, doesn't simply chopping the cab mount seem like the simplest solution? (Btw, I don't mean to sound harsh, but just know your not going to find some missing adjustment or easy fix to your problem, a chop is probably you're easiest option)
  27. Mar 28, 2021 at 11:17 AM
    #57
    ZPhilip
    Philip
    West Chester, PA
    With only 1.9” lift and 295s on +20mm offset, put back on stock UCAs, get alignment and all will be fixed.
    Blkdmax, 14burrito and rustytoys like this.
  28. Mar 28, 2021 at 11:32 AM
    #58
    rustytoys
    The Camburg ball joint sets back very roughly 1" from stock (Positive Caster) - that means your entire wheel and tire is moving towards the Cab and body mount.
  29. Mar 28, 2021 at 5:19 PM
    #59
    rustytoys
    Many of you appear to think that Caster regulates wheel position - this is not the case - Caster is only a measurement of angle - the wheel can be placed forward like a funny-car or rear towards the cab - with each instance achieving the same degree of positive Caster.
    The example below on the left is apparently what many of you were thinking when you stated that positive Caster would move the tire farther away from the cab body mount. However, doing this is only possible with a LOWER CONTROL ARM adjustment - BUT, THE OP HAD INSTALLED CAMBURG UPPER CONTROL ARMS - THAT IS WHAT THE THREAD WAS ABOUT. The Tundra has almost no ability to introduce positive Caster through the LCA cam adjustment (as +Caster sacrifices your Camber) - this is why UCA’s are so popular.
    This leaves you with the example on the right. The only way to introduce any significant caster on your Tundra is with a high-caster Upper Control Arm, which is going to push the wheel/tire closer to the cab body mount.
    RadSki[OP] likes this.
  30. Mar 30, 2021 at 11:09 AM
    #60
    RadSki
    Radek
    @rustytoys you were 100% right, dropped the caster, more responsive... less wonky! bmc a must tho, oh well
    Thanks
