RRW wheels group buy---the RRW crew
Discussion in 'Wheels & Tires' started by TheBeast, Apr 15, 2022.
  1. May 22, 2022 at 10:32 AM
    #151
    DK1865
    DK1865 New Member
    Kansas City
    2021 WCP Tundra Limited
    I paid my invoice last week too! Waiting for shipping notification.
    TheBeast[QUOTED][OP] and Toe404 like this.
  2. May 22, 2022 at 10:45 AM
    #152
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Anyone else going to be running longer studs for the front wheels? I should get my 20mm longer studs tomorrow and I’ll take some measurements and photos in comparison to a new OEM stud so others can decide if they want to get them.
    reywcms, Silver17 and TheBeast[OP] like this.
  3. May 22, 2022 at 11:15 AM
    #153
    TheBeast [OP] The Beach
    No plans on doing so. I will check once I have the rrw wheel on the oem studs see how many threads are engaged.
    I have been running aftermarket wheels with ET lug nuts for the past 8 years with no issues.
    I'm definitely interested in your findings though.
    Silver17 likes this.
  4. May 22, 2022 at 12:12 PM
    #154
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Same as @TheBeast as long as the RRWs are no different than any of the other wheels I’ve had from Fuel to Methods and several others I have no plans to change them. Running the ET lugs has worked fine for me for many years. If the lug holes are big enough to accommodate ET lug nuts and I get 8-10 threads I’ll be happy. If longer studs are needed I may have to find out more about the ones you’ve bought however.
    TheBeast[OP] likes this.
  5. May 22, 2022 at 3:55 PM
    #155
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    yeah I ordered the offical RRW open end ET lugs, I’m curious to see as well
  6. May 23, 2022 at 4:22 AM
    #156
    Silver17
    Eastern PA
    I had some thoughts on the protection rings and I’m wondering if anyone has answers.
    1. Should the rock protection rings be installed after the tires are mounted, or before? I would assume that after the tire is mounted is best; but not sure.
    2. Is it likely that the protection rings will scratch up the surface of the wheel in the areas they make contact? I don’t know if anything is protecting the wheel from scratches or not. I would think it’s bound to happen with vibration and dirt getting between the mating surfaces.
    Any thoughts?
  7. May 23, 2022 at 5:07 AM
    #157
    Mrf1987
    Mrf1987 New Member
    2020 Trd sport tundra
    Not sure about these RR7's but my last set of RRW RR5-V's did not have the lug hole bored big enough to accept et lugs. I tried 2 different brands of lugs to no avail. I tried Gorilla brand and some Amazon ones. Hopefully RRW et lugs work with the new RR7'S
    Toe404 likes this.
  8. May 23, 2022 at 5:53 AM
    #158
    Silver17
    Eastern PA
    I was being wishful that RRW would have made the lug holes larger by now on the RR7s if some customers complained with other wheel models. If not I’ll be exploring other options.
  9. May 23, 2022 at 6:06 AM
    #159
    Gin05
    Gin05 New Member
    WA State
    2022 limited trd off-road
    still on the checklist! lol
    Oh man!! I just missed this awesome deal. I wish they’ll run another group buy this year.
  10. May 23, 2022 at 6:15 AM
    #160
    VigTundy
    VigTundy New Member
    Josh
    2019 TRDSport 4x4 5.7L
    If you scan through this thread there is 1 or 2 who are willing to give up there spot if you want them.
  11. May 23, 2022 at 9:43 AM
    #161
    Gin05
    Gin05 New Member
    WA State
    I am not in a hurry coz I just placed my order on 2022 tundra limited 2 days ago. I’m just hoping that there’s another group buy this year. I want that RR7 in bronze set of 5. Those are lit!
    VigTundy[QUOTED] likes this.
  12. May 23, 2022 at 9:50 AM
    #162
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yes! I def plan on changing my lugs. Keep me posted on what you order etc. Not great info out there but found this thread and links.
    https://www.dormanproducts.com/p-32696-610-471.aspx#productBuy
    https://www.tundratalk.net/threads/tundra-longer-wheel-studs.763520/
  13. May 23, 2022 at 9:51 AM
    #163
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    If anyone who ordered beadlock rings in black and doesn't want them let me know. I plan on ordering some but willing to take them off your hands if needed.
    Toe404 likes this.
  14. May 23, 2022 at 9:58 AM
    #164
    Mrf1987
    Mrf1987 New Member
    I did a write up on how i swapped to longer studs that are the same thread pitch as the oem rears. Expensive yes but they are oem quality. I bought the dormans as well but the knurl was not big enough for a tight fit like oem.
    https://www.tundras.com/threads/the...em-lugs-aftermarket-studs.76918/#post-2765793
    reywcms[QUOTED] likes this.
  15. May 23, 2022 at 10:04 AM
    #165
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    I’ll keep you guys posted, I know those Blackhawk ones from Japan that @Mrf1987 used are OEM if not better than OEM quality, I just wanted to try out a cheaper option before I drop 100 bucks on just shipping.
    I wonder if we all ordered at the same time if shipping would be cheaper? Might be a way for all of us to save some money
  16. May 23, 2022 at 10:43 AM
    #166
    1. install them after.
    2. that is a good question but that ring will be bolted with 20+ bolts so I don't think it's moving anywhere to scratch the wheel surface.
  17. May 23, 2022 at 10:45 AM
    #167
    From their site. Let's see how that goes when I mock up the wheel on the truck.
    https://www.relationsracewheels.com/collections/lug-nuts/products/hex-open-end-lug-nuts
    Note: these locks are 60° conical seating and fit all of our wheels
    VEHICLE FITMENT
    14x1.5: Toyota Tundra, Chevy Colorado ZR2, Chevy Silverado, Ford F150 Raptor, GMC Canyon
    Toe404 likes this.
  18. May 23, 2022 at 10:48 AM
    #168
    The next restock is August looks like. They are currently sold out of all Tundra wheels.
    Hopefully no covid shutdown in Asia or else the wheels wont be here until next year..lol
    Gin05[QUOTED] likes this.
  19. May 23, 2022 at 10:52 AM
    #169
    VigTundy
    VigTundy New Member
    Josh
    You may have better luck on the Tacoma Forums for your Lug Pattern for those as well. I don't see them posted often at all. TRDJon has them on his '22 white Off Road they look great on it!
    Gin05[QUOTED] and TheBeast[OP] like this.
  20. May 23, 2022 at 11:05 AM
    #170
    also Last Line of Defense. One of my favorite youtuber.
    Gin05 and VigTundy like this.
  21. May 23, 2022 at 11:37 AM
    #171
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    those are the exact lugs I ordered, hopefully they have enough engagement with the OEM studs
  22. May 23, 2022 at 1:14 PM
    #172
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    Ok studs came in, quality is very nice, on par with OEM for sure. Sizing looks to be perfect. I need to swing by work to grab the stock stud for side by side pics
  23. May 23, 2022 at 1:23 PM
    #173
    was that from Ebay ? I recall seeing some for sale there.
  24. May 23, 2022 at 1:25 PM
    #174
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
  25. May 23, 2022 at 1:33 PM
    #175
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  26. May 23, 2022 at 2:03 PM
    #176
    55K truck, 3K wheel set...Ebay special lugs..what could go wrong :D:D
    j/k
    Gin05, reywcms and Toe404 like this.
  27. May 23, 2022 at 4:02 PM
    #177
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    correct, same tread pitch as stock m14x1.5
  28. May 23, 2022 at 4:14 PM
    #178
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    hahaha I know right!
  29. May 23, 2022 at 5:39 PM
    #179
    Gin05
    Gin05 New Member
    WA State
    That’s great! I got two months to save for 5 set of wheels and tires! lol
    VigTundy likes this.
  30. May 23, 2022 at 5:55 PM
    #180
    Gin05
    Gin05 New Member
    WA State
    Yeah, I want to copy TRDJon’s wheel and tires set up. Btw, I ordered 22 Tundra on wind chill pearl color so RR7 Bronze are gonna be lit on the truck!
