Rounded flare nut advice
Discussion in '1st Gen Tundras (2000-2006)' started by bing5, Jan 18, 2025.
  1. Jun 1, 2025 at 7:46 PM
    bing5
    bing5 [OP] Long member
    New Mexico
    2004 Double Cab. 270k+
    Like she came out of the factory.
    Finally got around to replacing the fuel filter. Happy to report that the Irwin 7-inch locking wrench took the stripped flare nut off lickety-split! I suspect that are just a bit better at not tearing up the nut further than regular vise grips, but ?????
    I guess it had been replaced at some point because the old one had "Made in China" proudly displayed on it. Need one was Denso....
    shifty` and Jack McCarthy like this.
  2. Jun 1, 2025 at 7:52 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Great to hear it worked!
  3. Jun 1, 2025 at 8:04 PM
    bing5
    New Mexico
    Went back and proofread my reply. Damn, I need some sleep!
  4. Jun 1, 2025 at 8:19 PM
    It’s always the aftermarket ones that are clogged…
  5. Jun 7, 2025 at 7:36 PM
    Coastal_Tundra
    Coastal_Tundra New Member
    2003 5vzfe 5spd manual 2wd
    To for stuck flare nuts I use a pb blaster, a punch and hammer. Hit it with blaster let it sit. Use the punch to tap it off center in the direction you want to go. Tap it a few times and see if your wrench works. Repeat until you run out of patience and grab channel locks.
    The taping helps free it's up but don't expect to see it move. This method works well for most stuck/rusted bolts too.
    shifty` likes this.
