ROUND 3 | GROUP BUY: Morimoto XB LED FOGS (20% Off)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Apr 5, 2017.
  1. Apr 8, 2017 at 10:22 PM
    BB Stacker
    BB Stacker New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    I have a set of similar lights on my harley. I am in!
  2. Apr 9, 2017 at 7:17 AM
    MrWrench
    MrWrench New Member
    2017 White Tundra limited
    Spray on bed liner, Bak mx4
    I'm in
  3. Apr 9, 2017 at 7:56 AM
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Yes sir! I will have it shipped to the address you pm me with.
    ej63090[QUOTED] likes this.
  4. Apr 12, 2017 at 6:57 PM
    eledobleu
    Orlando, FL
    ***UPDATE***
    Orders will begin shipping after Easter Holiday. Group Buy will remain open until Sunday April 23rd @ Midnight.
    MrWrench, AKJ78 and baylrballa like this.
  5. Apr 17, 2017 at 2:04 PM
    Teriks
    Teriks New Member
    Tom
    Front Range, CO
    2008 Toyota Tundra Limited DC 4x4 5.7
    Just submitted my payment, too. Cheers to the group buy!
  6. Apr 18, 2017 at 5:55 PM
    PermaFrostTRD
    Northern NY
    Just ordered. Thanks man!!
  7. Apr 19, 2017 at 8:45 AM
    Windwarrior
    Windwarrior New Member
    2017 TRD Pro
    Stock
    Just Ordered, thanks.
  8. Apr 21, 2017 at 7:50 PM
    eledobleu
    Orlando, FL
    Alright guys! Only two days left for the group buy!
  9. Apr 23, 2017 at 9:27 AM
    eledobleu
    Orlando, FL
    GROUP BY ENDS TONIGHT AT MIDNIGHT EASTERN TIME. ORDER BEFORE ITS TOO LATE!
  10. Apr 24, 2017 at 9:35 AM
    eledobleu
    Orlando, FL
    ***GROUP BUY IS NOW CLOSED***
  11. Apr 24, 2017 at 6:47 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    Arrived today!!!
  12. Apr 24, 2017 at 10:04 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Arrived today!
  13. Apr 25, 2017 at 8:21 AM
    baylrballa
    baylrballa New Member
    2016 Black Crewmax Limited
  14. Apr 25, 2017 at 11:24 AM
    Sporto
    Sporto New Member
    2014 Radiant Red Tundra Limited CM TRD
    Did you take off your wheel to more easily remove the front fender liner to install these or just crank your steering all the way to one side to gain access?
  15. Apr 25, 2017 at 11:31 PM
    mazmaz17
    mazmaz17 New Member
    2017 Cement TRD Pro
    I just installed mine tonight and turning the wheels all the way to one side gave me more than enough room to install the fogs on both sides. It was really simple and straight forward. Hope that helps.
  16. Apr 26, 2017 at 4:40 AM
    MrWrench
    MrWrench New Member
    Do you need to install ballasts for LED lights to work?
  17. Apr 26, 2017 at 3:04 PM
    mazmaz17
    mazmaz17 New Member
    2017 Cement TRD Pro
    There are no ballasts to install. Just connect the wires to the wire harness. Purely plug-n-play, the only other thing you have to do is mount the fogs with the one screw and that's it.
    MrWrench[QUOTED] likes this.
  18. Apr 26, 2017 at 7:06 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    They have to be "aimed" I'm thinking
  19. Apr 27, 2017 at 6:31 AM
    #49
    MrWrench
    MrWrench New Member
    Thank you. Do you remember which wire is hot and which wire is ground?
  20. Apr 27, 2017 at 4:25 PM
    #50
    mazmaz17
    mazmaz17 New Member
    2017 Cement TRD Pro
    I don't exactly remember. On the driver side there was a pink and a white wire, while on the passenger side I think there was a blue and white (I did the install late at night). I think the whites were the grounds but I could be wrong. The easiest way I checked was by plugging the fog wires directly into the harness (before inserting them into that black plastic adapter) and checking if they turned on or not. After I saw it light up, I then inserted the fog wires into that black plastic housing that comes in the box and securely attached it to the harness.
  21. Apr 27, 2017 at 9:09 PM
    #51
    baylrballa
    I think black to white on both sides then whatever other colors together.
  22. Apr 27, 2017 at 10:33 PM
    #52
    MrWrench
    MrWrench New Member
    I'm gonna assume white is the ground wire. Thanks for the info.
    mazmaz17[QUOTED] likes this.
  23. Apr 29, 2017 at 9:47 AM
    #53
    PermaFrostTRD
    Northern NY
    Here we go!!
    Oh man!!!
    Here we go boys!
    Thanks Leo!
    Noodle likes this.
