Rough transmission shifting
Discussion in '1st Gen Tundras (2000-2006)' started by Dadof5boys, Aug 8, 2021.
  1. Sep 5, 2021 at 4:02 PM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    An update on my experience: No more antifreeze contamination. My transmission was shifting perfectly after a 9 gallon flush. Slowly my shifting quality got worse and worse. It started slamming into 2nd again. Drove like that for a few weeks. Then one day it started slipping shifting to 2nd. It will go to shift, rpms go up and I feel my body lunge forward from the truck slowing down. The next day, it will not shift into 2nd. Not unless I get up to 20 mph, then let my foot off the gas until the rpms drop to 1000. Then lightly apply the gas pedal and I'll be in 2nd. It also down shifts into 1st under light load.
    I could drop the pan and the valve body, replace the shift and line pressure solenoids. But I still have clutches that are holding on for dear life. And that's going to be at least $300.
    I may have found a used trans in good shape for $650.
    FirstGenVol and tvpierce like this.
  2. Sep 6, 2021 at 1:37 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Sorry for your bad news, but thanks for the update.
    Good luck.
