rough idle
Discussion in '1st Gen Tundras (2000-2006)' started by Fringco, Aug 11, 2018.
  1. Aug 11, 2018 at 12:11 PM
    Fringco
    Fringco [OP] New Member
    2000 dark green tundra limited
    After close to 200k miles on my 2000 Tundra it started idling rough one night all of a sudden.
    After replacing spark plugs ,checking coil packs ,throttle body,map sensor,cam sensor and fuel injectors,no issues found there.
    I'm going to run a fuel pressure test and fuel filter inspection next.
    No codes show up on the ob2 scanner.
    Am I barking up the wrong tree here?
  2. Aug 12, 2018 at 6:19 AM
    Professional Hand Model
    Hand Protectors
    Cheap start is to clean your throttle body and your MAF sensor. Changing fuel filter is good. Make sure your fuel station is giving good product. Add some fuel injector cleaner to a few tanks. Let us know how it goes.
  3. Aug 12, 2018 at 8:55 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    If it seems to be running right but just causing a shake Check the condition of your motor mounts
    FrenchToasty likes this.
  4. Aug 16, 2018 at 3:37 PM
    Hand Protectors
    Might be throttle body gear box needing repair. Saw this can be a problem while watching youtubes about other repairs stuff. Guy had similar problem and disassembled gear box and re-lubed with white lithium. Make any headway on this?
  5. Aug 16, 2018 at 5:36 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Compression test and a vacuum leak check on the intake manifold are some places I’d be looking sooner than later.
