Rough Country 30" lightbar
Discussion in 'Lighting' started by Patriot, Aug 3, 2017.
  1. Aug 9, 2017 at 2:31 PM
    finn
    finn New Member
    Ryan
    Has anyone seen just the mount for sale? I have a 30" Baja Designs bar that came off my old rig. Just looking for a way to mount it.
  2. Aug 9, 2017 at 2:35 PM
    Awesome Sauce!!!
    geno0506 and Patriot[QUOTED][OP] like this.
  3. Aug 9, 2017 at 5:46 PM
    Patriot
    Patriot [OP] Member
    Western NC, “Boondocks”
    Thanks for your input on the RC lightbar Adam! :thumbsup:
  4. Aug 9, 2017 at 5:48 PM
    No prob Dave!!! what we all here for!!! :thumbsup:
    Patriot[QUOTED][OP] likes this.
  5. Aug 9, 2017 at 6:29 PM
    Patriot
    Patriot [OP] Member
    Call Rough Country, they might sell you a set. Only costs a call.
  6. Aug 9, 2017 at 6:35 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    It wont "hurt" the battery... But having an LED burning 24/7 cant help it either.
  7. Aug 9, 2017 at 6:38 PM
    1BadTundra
    Clinton
    Too Much to List
    Anytime man... Glad you like it.
  8. Aug 9, 2017 at 6:42 PM
    Patriot
    Patriot [OP] Member
    Have had a factory OEM LED light blinking in my Platinum dash since I took delivery new in 14. Never had an issue. It does not appear two tiny LEDs are gonna draw enough current to create any problems.
  9. Aug 9, 2017 at 6:44 PM
    1BadTundra
    Clinton
    Too Much to List
    Its your rig... I did one install where the customer insisted it be hooked to the battery. He liked the bluish/purple LED on the switch, and wanted it constant. He hasn't had any trouble to date, but I just wire things to ACC or IGN whenever I can. That's just me though.
    NewImprovedRon likes this.
  10. Aug 9, 2017 at 7:18 PM
    PMG
    PMG New Member
    So where exactly should it be wired to?
  11. Aug 10, 2017 at 1:32 AM
    Patriot
    Patriot [OP] Member
    PMG- Rough Country instructions say wire it to the battery, which I did. It comes with a nice long wiring harness and switch relay, and inline fuse located at the battery and ready to go. It's an extremely bright light bar @12000 Lumens, dam bright.
    And for the price, seamless appearance and so far performance, plus 3 yr replacement warranty.
    PMG[QUOTED] likes this.
  12. Aug 10, 2017 at 3:21 AM
    Wish RC sold 40-42" straight to put behind Pro grille
  13. Aug 10, 2017 at 3:25 AM
    Patriot
    Patriot [OP] Member
    I am already thinking of adding the Headlight Revolution Tundra specific light bar for behind the Pro grill.
    Adam I think you need to just buy the HL Rev LB...just do it!!! :rofl:Do it now!
  14. Aug 10, 2017 at 4:45 AM
    Your talking bout the one for hood buldge from nsv???
  15. Aug 10, 2017 at 5:46 AM
    Never mind i just saw it yeah ill look into it...need some overtime here at work for it
  16. Aug 10, 2017 at 6:18 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    This looks great, may have to look into it. Been wanting a lightbar for that area for a while now, but didn't want to spend 1K + on it.
  17. Aug 10, 2017 at 10:46 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Can you post up a pic of the switch please?
  18. Aug 10, 2017 at 11:15 AM
    Patriot
    Patriot [OP] Member
    Wes, I don't think you will be disappointed for the price it's a blinding light bar. With rock solid mounts!
    TTU19[QUOTED] likes this.
  19. Aug 10, 2017 at 11:16 AM
    #49
    Patriot
    Patriot [OP] Member
    I will post up a pic of the switch in a few hours. I am headed to the pistol range.
  20. Aug 10, 2017 at 1:51 PM
    #50
    PMG
    PMG New Member
    How's the install? Does the bumper need to be removed or just the grill?
    Patriot[OP] likes this.
  21. Aug 10, 2017 at 2:20 PM
    #51
    Actually nothing jus some minor cutting of plastic
  22. Aug 10, 2017 at 2:32 PM
    #52
    Patriot
    Patriot [OP] Member
    A very basic LED switch with a tape backing, so nothing fancy, no wow factor. Red light stays on which concerns some with potential battery drain, RC says not an issue. I have no OEM switch blanks on my Platinum dash. So I will keep this for now until I decide on some thing else.
    scpete24[QUOTED] likes this.
  23. Aug 10, 2017 at 2:44 PM
    #53
    Patriot
    Patriot [OP] Member
    No bumper removal, as @aramirez73 said, so carefully cut the lower grill out, you can use a small hack saw, blue painters tape to protect painted bumper area. Loosen all six fasteners under lower bumper on left and right side 14mm with breaker bar. Instructions are ok, pretty easy to figure out.
    Install mounting brackets, then install light bar. Run your wiring up to battery, I zip tie the wire loom to keep it neat looking. Run your switch wire through your firewall. Then mount your relay, I used my negative battery grounding point for relay mount. It was close and just convenient. Attach your neg and positive connections to your battery. Done.
    Let there be light.
    I saved the extra RC LB mounting hardware in the event I wake up some morning and UPS mysteriously drop ships a free amazing custom bumper and warn winch on my doorstep for a Tundra..doubtful, but you never know.:rofl:
  24. Aug 10, 2017 at 2:50 PM
    #54
    My switch fell off few times from extreme heat...that said... one drop of gorilla super glue bah bam!!! Never coming off
  25. Aug 14, 2017 at 9:35 PM
    #55
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    Interested in getting one of these as well and I have spare LED monogrammed switch, think there would be any issues wiring up to a prettier switch?
  26. Aug 15, 2017 at 1:18 PM
    #56
    1BadTundra
    Clinton
    Too Much to List
    We install these. I don't care for the stick on stick on's... If we install them, people will bring their car back EVERY time is comes off the dash. We've even had people bring their own kits they bought off the internet, insisted we install the stick on button, then bitch when it peels off...After we warned them it would.
  27. Aug 15, 2017 at 1:19 PM
    #57
    Patriot
    Patriot [OP] Member
    Here's the link to order...
    http://www.roughcountry.com/led-backlit-rocker-switch-709sw.html
    MotoTundra likes this.
  28. Aug 15, 2017 at 3:37 PM
    #58
    Dilsky
    Shawn
    Edmonton, Alberta
    Sweet that is what I have already just not an RC one. Now where to mount it....
  29. Aug 15, 2017 at 5:08 PM
    #59
    Patriot
    Patriot [OP] Member
    Yeah, I hear ya, I was going to go with a behind the grill LB, but being a bit of an clean freak, I wanted to be able to clean the LB lens. The lower bumper mount allows for cleaning.
  30. Aug 16, 2017 at 8:56 AM
    #60
    1BadTundra
    Clinton
    Too Much to List
