Rough cold start
Discussion in '2.5 Gen Tundras (2014-2021)' started by Slswoosh9, Dec 27, 2018.
  1. Jan 16, 2019 at 3:40 PM
    2016 sun bro mic
    2016 sun bro mic New Member
    Nelson
    Conover NC
    2016 sunset bronze mica tundra
    Front leveled new wheels and tires
    Should be I also bought an extended warranty from the car lot I bought it from
  2. Jan 16, 2019 at 3:42 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Get the TSB done.
  3. Feb 16, 2019 at 9:51 AM
    CiscoMn
    CiscoMn New Member
    Francisco
    2014 red sr5 tundra
    Completely stock, not for long.
    I've had the same issue, where it extends the crank, went from that to misfiring, replaced battery at first, same issue, replaced spark plugs, same issue, what basically do now is turn the key to on and let it sit for about 10-15 seconds and it starts right up or else it just idles really rough, have had misfire codes, ecm codes, lost of communication with cluster. Really annoying
  4. Feb 16, 2019 at 9:55 AM
    CiscoMn
    CiscoMn New Member
    Francisco
    2014 red sr5 tundra
    Take in mind I live in MN temps here winter time anywhere between 30+ to -20. Started noticing this back in end of November
  5. Feb 16, 2019 at 10:41 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Do you have extended warranty? Those codes would makes me want to bring it in.
  6. Feb 17, 2019 at 9:38 AM
    CiscoMn
    CiscoMn New Member
    Francisco
    2014 red sr5 tundra
    Unfortunately no hit 100,000 already
  7. Mar 25, 2019 at 12:12 PM
    2016 sun bro mic
    Nelson
    Conover NC
    Just had the tsb done the ecu said I was running e85 but I wasn’t it was running to rich remapped hopefully this helps
  8. Mar 25, 2019 at 2:41 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Same for me. It has been perfect since.
  9. Mar 25, 2019 at 3:18 PM
    2016 sun bro mic
    Nelson
    Conover NC
    Thanks sounds good nice truck too
  10. Mar 25, 2019 at 5:19 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Likewise. I dig that color.
  11. Mar 25, 2019 at 6:25 PM
    2016 sun bro mic
    Nelson
    Conover NC
    Thanks appreciate it
  12. Apr 7, 2019 at 6:22 PM
    2016 sun bro mic
    Nelson
    Conover NC
    Mine has been perfect and even get a little better fuel mileage since the tsb thanks for the info on here guys
    8MINT8 and BTBAKER[QUOTED] like this.
  13. Apr 7, 2019 at 7:08 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Good to hear! Mine has been solid.
  14. Nov 17, 2019 at 2:14 PM
    kgordon96
    kgordon96 New Member
    Kyle
    2015 Toyota Tundra SR5 XP
    I think I am going to call a dealer tomorrow about this TSB. Just bought my tundra 2 months ago. It’s been great until it started getting upper 30s and low 40s over night. Now struggles to crank in the morning. What should I tell the dealer? Just tell them about a TSB for FFV tundras where it may be running too rich? I have a used 2015 btw.
  15. Dec 1, 2019 at 7:13 PM
    kgordon96
    Kyle
    I brought mine in and had the TAB done. Went on a trip from GA to VA and was great. Especially on a cool 26 degree morning. It started like a champ. I drove back home to GA and the next morning started to struggle again on cold starts. Any thoughts?
  16. Dec 11, 2019 at 7:33 AM
    Target612
    Target612 New Member
    I have a 2016 FFV 5.7L V8 4x4 crewmax. I feel the need to notify the public that my car was having really really bad rough starts in the morning - didn’t matter if weather was cold or warm - first start of the day always sounded like the engine was choking. I googled online and found this site and many other message boards about the Alcohol Density Calculation problems and the need to “reflash” the ECM (see Toyota Service Bulletin T-SB-0058-13).
    I took the truck in to the dealer yesterday, they did a cold start this morning after it sat in the lot overnight, and concluded it had this problem that is specific to FFV Tundra engines.
    The service advisor said that Toyota just came out with a new TSB a few days ago updating the old TSB so that it now covers the fuel pump and the “reflashing” of the ECM, it now also covers all FFV Tundras from 2009 - 2019. The new TSB is T-SB-0166-19.
    So I hope this info helps, hit up your dealer if you are having enginestart-up problems with your FFVengine Tundras, and pass the word around!
    If I had known about these engine issues, I would have NEVER bought a FFV engine!!!
  17. Jan 3, 2020 at 8:48 AM
    BigBert7198
    BigBert7198 New Member
    2014 1794 Tundra
    Just found the forum and I appreciate the information. Mi e just started doing exactly as described in this thread! Appointment is scheduled for the 8th. Thanks for the TSB 187888 info. Described exactly what is going on.
  18. Nov 4, 2020 at 2:17 PM
    TRDSteepSLOPE
    TRDSteepSLOPE New Member
    Kevin
    2019 Tundra CrewMax
    Hey Guys, I've been following this thread and 2 days ago had the Fuel pump and fuel line replaced per the Bulletin. I don't think they reflashed my computer because its still starting rough. I'd would appreciate follow up from all that had theirs reflashed and if this has lasted.
    Thanks
  19. Nov 18, 2020 at 5:11 AM
    #49
    TRDSteepSLOPE
    Kevin
    2019 Tundra CrewMax
    Any update? What solved the problem
  20. Nov 18, 2020 at 5:13 AM
    #50
    TRDSteepSLOPE
    Kevin
    2019 Tundra CrewMax
    Any update, This is what my truck has been doing and the dealer has no clue.
  21. Nov 18, 2020 at 5:24 AM
    #51
    timsp8
    NY
    While they might get an email notification, the 2 people you quoted haven’t been seen since Jan 20 and Sep 19. I think BTBaker is still around. Try to PM or tag him.
  22. Nov 18, 2020 at 5:30 AM
    #52
    TRDSteepSLOPE
    Kevin
    2019 Tundra CrewMax
    Any update now that the weather has gotten colder, I just had the ECU and the TSB done and the rough start is still happening. The dealer hasn't given up but they do not seem to have any ideas
  23. Nov 18, 2020 at 6:53 AM
    #53
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Mine has been flawless after the software flash. Sorry to hear you’re still having issues. Please keep us informed.
  24. Nov 18, 2020 at 8:25 AM
    #54
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    As a temporary fix. Use an OBD2 app to read alcohol content. I have Torque Pro. If it is higher than say 35-40%, I would try resetting it. For that I've used Techstream and reset the alc. density value. This always worked for me on my 2014. Note that everytime you fill up a near empty tank, the % will most likely creep up. Then just use Techstream and reset. I had the ecu reflashed and fixed this. But when I flashed a bullydog tune, it was a modified old flash, so it started doing it again. Being I had the BD on it, I just would occasionally reset the % myself. YMMV
    Edit. Did it sound like this?https://photos.app.goo.gl/sWzHu75bRoapS3oT6
  25. Nov 18, 2020 at 9:21 AM
    #55
    TRDSteepSLOPE
    Kevin
    2019 Tundra CrewMax
    yes that’s exactly what it sounds like, some times it won’t turn over until after a few tries.
  26. Nov 18, 2020 at 9:23 AM
    #56
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Alright. Try what I put in the previous post and see if that helps.
  27. Dec 21, 2020 at 6:52 AM
    #57
    Gwiz17
    Gwiz17 New Member
    2014 Tundra 1794 FFV
    TSB 0166-19 is the new one and covers a replacement of the fuel pump now and is covered under warranty for 96 months or 80K miles. I had this issue a few years ago with my '14 and they reflashed it and I had no issues for a few years. Last week my truck started doing it again, and of course I'm at about 86K miles. Just heard from the dealer and it is the same issue so they are going to replace fuel pump and reflash the system per the TSB. Looking at $1500, which I challenged them a bit on, but honestly I don't have time to drop the fuel tank and don't have the know how to reflash the system. All in all though, I love my truck and If this is the only issue I have had, I can deal with that.
  28. Jan 22, 2021 at 8:56 AM
    #58
    Silver flex
    Silver flex New Member
    2018 sr5 Trd flex double cab
    Thanks to target 612 and everyone else ! Finally getting my truck fixed with the new tsb 0166-19 been complaining about the smoke /
    Rough start for 2 years . Now we get a fuel pump on top of it at 19000 mi on a 18 - my fifth tundra and second flex . Hopefully this fixes it . Some times I wish I kept my 2013 . Anyway if your truck smoke and runs bad at start up , make sure you press your dealer to fix . All ya need is the thing to be in limp mode when far from home . Let you if this really fixes it Thanks again everyone for bringing this out !!!
  29. Jan 23, 2021 at 6:53 AM
    #59
    Tundra41
    Tundra41 New Member
    2013 black tundra platinum ffv
    Glad I came upon this thread. I’ve had my tundra for almost 2 years now and started noticing a rough start only in the cold. Yesterday was the worst it’s been and weather was bout 17 degrees and would not turn over so I had to take my wife’s car instead. When I returned I tried starting the truck up again and this time it turned over but I had a large black cloud of smoke and smelled awful. I’ve read that could be the tsb that everyone was speaking about so I’ll call the dealer and ask. Is this covered or how much would I pay out of pocket?
  30. Jan 23, 2021 at 7:00 AM
    #60
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    You guys definitely nailed it as a FFV issue. For contrast, cold starts in my non FF 16 are non descript.
