Rotors?
Discussion in '1st Gen Tundras (2000-2006)' started by literallyme, Nov 8, 2024.
  1. Dec 11, 2024 at 8:28 AM
    #61
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Scotchbrite pad and some WD40 will clean up the pins just fine, if you are not in a rust belt. I have reused several pins without a problem.
  2. Dec 12, 2024 at 2:14 AM
    #62
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    You can get pins at Advance too. Got springs at dealer and pins cheaper elsewhere. Reused clips and shims with OE Pads. OE at 25% off online with free shipping is good price, and can add in these odds an ends. But for the clips, why not just call a dealer with your VIN? They are probably under $5 localy for the OE. There's these too:
    https://www.amazon.com/Dorman-HW14023-Brake-Caliper-Bolt/dp/B004Y3GBD4
  3. Dec 12, 2024 at 3:11 PM
    #63
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    With Advance order online and use the 20% code and pick up at local store
    ToyotaDude likes this.
  4. Dec 15, 2024 at 7:47 AM
    #64
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    @literallyme were you able to wrap up the front brake job? any hiccups?
  5. Dec 15, 2024 at 1:22 PM
    #65
    literallyme
    literallyme [OP] New Member
    Southern California
    2006 Sequoia Limited 2WD, 1974 Pontiac Firebird 350
    Ok guys need your help, front rotors are pretty much seized, hit it with the hammer idk how many times. Any tips?
    Desert Dog likes this.
  6. Dec 15, 2024 at 1:28 PM
    #66
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    My first thought is to spray the area with a good lubricant or penetrant and let it set awhile before proceeding. This is always my default process.
  7. Dec 15, 2024 at 1:31 PM
    #67
    literallyme
    Southern California
    I did that right after you posted it came off lmao
    Desert Dog[QUOTED] likes this.
  8. Dec 15, 2024 at 1:32 PM
    #68
    Desert Dog
    Right on! Glad to hear :thumbsup:
    For future reference, one of the most-effective treatments I've ever used is a mixture of transmission fluid and acetone. It's best not to mix a large volume due to the fact that the acetone naturally flashes off quickly, but it is highly effective. Old school.
  9. Dec 15, 2024 at 1:39 PM
    #69
    shifty` Waving My Dick In The Wind
    Another thing you can do is insert stout flathead screwdrivers in the outer vent holes of the rotor to rock the entire rotor back/forth on opposing sides. If you take a BFH and whack the flat area where the lug studs pass thru, in a couple of rounds, then use the vent hole hack, they'll typically kick out.
    Be sure to use a little bit of anti-size on the surface where the rotor meets up.
  10. Dec 15, 2024 at 1:46 PM
    #70
    Desert Dog
    +1 on applying anti-seize at mating-surfaces.
  11. Dec 15, 2024 at 2:20 PM
    #71
    literallyme
    Southern California
    Guys, might have another issue. Is it possible that this new rotor might already be warped? I put the caliper back on, and it’s rubbing the caliper itself when you spin it to a certain spot. Or could it be that I didn’t put this back on right?
  12. Dec 15, 2024 at 3:48 PM
    #72
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Probably already have this figured out but rotor probably not tight against hub. You can hold it in place with a couple of lug nuts.
  13. Dec 15, 2024 at 3:52 PM
    #73
    Desert Dog
    Yes, it's possible, unfortunately, considering the quality of parts these days. What brand is it?
    True, but there isn't much to go wrong on assembly.
  14. Dec 15, 2024 at 5:49 PM
    #74
    literallyme
    Southern California
    Update: everything is good. Went on a test drive did the 30, 30 thing that Advics recommends. Thank everyone so much. Saved a couple hundred dollars on doing all 4 myself
  15. Dec 15, 2024 at 6:07 PM
    #75
    Kudos to you for having the gumption, confidence, and persistence to get it done!! That's what it's all about right there.
