Rotors that won't warp?
Discussion in 'General Tundra Discussion' started by SA183, Jan 30, 2021.
  1. Sep 28, 2021 at 7:12 PM
    #61
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Cryo cast iron, no slots.
    Should easily last life of the vehicle for any non race application.
  2. Sep 29, 2021 at 5:04 AM
    #62
    timsp8
    NY
    I had this same issue with powerstop. They only lasted a little over a year or about 15k miles before I had horrible wobbling even when I wasn’t hitting the brakes.
    I went with stoptech slotted and ebc yellowstuff pads. I only have about 1k miles on them now, but so far they are really good.
    Uhhhh....[QUOTED] likes this.
  3. Oct 4, 2021 at 3:41 PM
    #63
    Pa'Zapp's
    Pa'Zapp's New Member
    PaZapp's
    2003 Tundra
    Brake Rotors, exhaust, Bull bar, side steps & pin stripped tailgate
    My experience is the Callipers fail, get sticky and the back sides of stock rotors heat crack like crazy. This creates uneven braking, noise and a feeling of luck ya stopped !
  4. Oct 14, 2021 at 6:46 PM
    #64
    Pa'Zapp's
    PaZapp's
    2003 Tundra
    So fasten a dial indicator and rotate them and see if they run out thousand'ths of an inch.
  5. Oct 14, 2021 at 7:17 PM
    #65
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    If the rotors are warped they will move more then the shimmed amount when they get hot. It will be better, but you might want to account for this and put in some more shims.
    I would buy some shim-in-a-can, yes it is called that, and use some good scissors to cut out small pieces that can be held in place with a little bit of grease. Just a dab so that it doesn’t affect the brake surface.
  6. Oct 14, 2021 at 7:31 PM
    #66
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Yup, that’s how you do it. I never thought .005 of an inch was much (and probably would have laughed at someone 10 years ago if they said it’d make a difference), but after getting a mill and a lathe, 5 thou is a noticeable cut when you run your finger over it. I can start to imagine now how a difference like that would negatively impact a braking system
  7. Oct 14, 2021 at 7:48 PM
    #67
    crewmaxlmt
    scott
    You can feel .0002” on face milled aluminum sub plate. Our senses are quiet amazing.
    Mater[QUOTED] likes this.
  8. Oct 14, 2021 at 8:01 PM
    #68
    CTundraForMe
    CTundraForMe New Member
    When I got my '15 with 98k miles on it, it had hard brake shudder at around 50mph.
    I have no idea how old or new any part of the braking system was, or whether it was OEM or not.
    At the recommendation of my uncle who is a Toyota Master Mechanic, I got Rabestos rotors and pads (980583R 980584R MGD1303CH MGD1304CH), non slotted, non drilled, from Rock Auto for what I thought was a fantastic price, even with $50 in shipping. (I had no idea 4 rotors could be so heavy!!) He uses the same set on his 2010 Tundra.
    That took care of the shuddering. Granted it's only been about 3-4k miles, so only time will tell I guess.
    It drives incredibly smooth on the highway, even at speeds I won't mention.
    Needless to say I love driving my truck.
    crewmaxlmt likes this.
  9. May 6, 2024 at 3:06 AM
    #69
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Anyone recommend a good site to buy the StopTech cryo slotted? Thanks!
  10. May 11, 2024 at 3:46 PM
    #70
    therealjonwick
    JR
    2019 OR
    Are they the “s” slotted? That’s all I see on rock auto
  11. May 11, 2024 at 5:23 PM
    #71
    therealjonwick
    JR
    2019 OR
    Ok thanks. How many miles do you have on them? I decided against powerstop because I heard about the warping.
  12. May 11, 2024 at 5:49 PM
    #72
    centex
    centex New Member
    https://brakeperformance.com/
    I’ve run their dimpled and slotted and dimpled rotors on everything from sports cars to HD trucks and have never had a rotor warp. Also US made.
  13. May 11, 2024 at 6:04 PM
    #73
    therealjonwick
    JR
    2019 OR
    Their prices seem decent. $504 for cross/slotted or just slotted with ceramic pads. Almost too good to be true. So the pads come with any replacement hardware?
  14. May 11, 2024 at 6:06 PM
    #74
    centex
    centex New Member
    Haven’t bought them for a tundra (yet) but the other ones came with the pad shims or clips.
  15. May 12, 2024 at 8:30 AM
    #75
    therealjonwick
    JR
    2019 OR
    Do they come with the pin retainer hardware. (Hawk LTS)
  16. May 12, 2024 at 10:10 AM
    #76
    *D*
    *D* New Member
    Dimitri
    Rhode Island
    ‘24 DC Long Bed 4x4 SR5
    I bought my 07 brand new and struggled for a good 5 years with rotors warping easily. Even when I was super careful it would still happen.
    Interesting to note that this stopped happening when I switched to another dealership for service.
    Even more interesting to note is that I too had heard about over tightened lug nuts contributing to the problem (mentioned by @glowblue ). I had to change a flat on the side of the road one day- the lug nuts were on so tight, that I actually bent my lug wrench taking them off. That experience is what made me change dealerships.
    I never had warped rotors again after that. In my case, it was mostly due to bad installation practices. I’ll admit that for the first 30K miles I drove that 5.7 like a maniac, but quickly changed my tune because of rotors constantly warping.
  17. May 12, 2024 at 10:28 AM
    #77
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    How did driving it like a maniac cause your rotors to warp? Because you had to brake more aggressively?
  18. May 12, 2024 at 12:28 PM
    #78
    *D*
    *D* New Member
    Dimitri
    Rhode Island
    Yes, I was heating those brakes up pretty good.
  19. May 13, 2024 at 6:12 AM
    #79
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I didn’t realize there were like 6 flavors of stop tech rotors for the tundra. In my ignorance I ordered the “sport slotted rotor” version and not the cryo. I’m not in a hurry to do the brakes. Am I best to return and find the cryo or just run these?
  20. May 13, 2024 at 6:53 AM
    #80
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    Tire rack or rca garage. I tell ya. I have been watching the delivery date slip and slip on stopTech slotted cryo rotors. I have the front left and rear right in my garage and have been trying to get the other 2 for 6 months. If you are in a hurry you may look at a different brand. Not sure what the hell is going on with them and manufacturing.
  21. May 13, 2024 at 10:21 AM
    #81
    therealjonwick
    JR
    2019 OR
    Thanks for the info! Sold out on tire rack. Summit racing seems to be the only spot.
  22. May 13, 2024 at 11:10 AM
    #82
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    If they are in stock please let me know. My guess is they will promptly go to back order when you place an order. At least that is what I have seen other places do. Hope I am wrong for your sake!
