Rotors that won't warp?
Discussion in 'General Tundra Discussion' started by SA183, Jan 30, 2021.
  1. Jan 31, 2021 at 8:29 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I think in the end it’s all the same. The point is the guy needs new rotors, wether it’s due to warping or lateral runout. Good luck OP and keep us updated!
  2. Jan 31, 2021 at 9:32 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Bought my truck used with 21k miles. Front brakes were already pulsing. Replaced with frozen rotors and Hawk LTS pads.
    Jimes and deptrai like this.
  3. Jan 31, 2021 at 9:54 AM
    SA183
    SA183 [OP] New Member
    Thanks. Could you provide an example of a rotor with high carbon content? What is the product number of the duralast rotors you're using?
  4. Jan 31, 2021 at 10:16 AM
    SA183
    Mine are undoubtedly warped. I can see the runout inside the caliper if i take the wheel off and turn the hub by hand
    Gunship Guy likes this.
  5. Jan 31, 2021 at 10:19 AM
    SA183
    Thanks, but i do have a torque wrench and I have always torqued 97 Ft lbs in a criss cross pattern. I do all my own work on the truck so I have ruled out things like this.
  6. Jan 31, 2021 at 10:21 AM
    SA183
    Ceramics from Wagner. My rotors are not drilled & slotted. Maybe the next ones i get will be if this is your experience.
  7. Jan 31, 2021 at 10:46 AM
    timsp8
    NY
    Isnt warping just the term used when brakes shake? Using that term doesn’t mean the rotor is physically warped. It’s just the common term for it that people use. Like saying ‘hot’ water heater. Not sure why every rotor thread turns in to people correcting others and bragging about their mechanic experience.
    Tundyfundy likes this.
  8. Jan 31, 2021 at 12:14 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    If you are going to use ceramic then definitely upgrade your rotors to drilled / slotted, they will dissipate heat much more. :thumbsup:
  9. Jan 31, 2021 at 12:21 PM
    Trooper2
    JR
    My experience from above, the rotors were "warped". At low speeds, no brake applied, they would squeak hitting the pads off and on. We could feel it in the brake pedal when braking as well.
  10. Jan 31, 2021 at 1:02 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    . It’s a nice diversion from the transmission cooler threads...people love a good pissing contest.
    Saltyhero13 and Tundyfundy like this.
  11. Jan 31, 2021 at 1:51 PM
    timsp8
    NY
    Yep. Transmission cooler threads turn in to people bragging about being an engineer.
  12. Jan 31, 2021 at 2:08 PM
    Rubberdown
    What if you were a mechanic that then went to school for engineering? Which thread could you pipe up in? Asking for a friend.
  13. Jan 31, 2021 at 2:19 PM
    glowblue
    VA
    Quote of the thread: “I’m not a mechanic, but I play one on Tundras.com!”
  14. Jan 31, 2021 at 2:19 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    ever look at the exterior of an enclosed trailer or metal roof in the sun?
  15. Jan 31, 2021 at 2:53 PM
    timsp8
    NY
    The oil change at 3k, 5k, or 10k miles thread.
    Black Wolf and landphil like this.
  16. Jan 31, 2021 at 3:35 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    steved0xTD, microblues, RJVA and 4 others like this.
  17. Jan 31, 2021 at 3:47 PM
    Rubberdown
    haha... there is something for everyone!
  18. Jan 31, 2021 at 4:07 PM
    Po
    I would insert 8k to be all inclusive........
    timsp8[QUOTED] likes this.
  19. Jan 31, 2021 at 4:10 PM
    #49
    Tundra-dude
    Tundra-dude New Member
    2020 Tundra SR5 CrewMax
    I'll check in with my friend who is an industry consultant on brake rotors and has an invention for on-car or on-truck rotor geometry checks. He's helped me measure brake pads and my free-floating rotors that I use on my track car. I've run into a few issues and he helped measure the parts to determine the problems. For my track car I learned 1) Uneven pad deposition is real and is a huge watch out for a car that is tracked on a road course track. Pads claimed to be street/track pads seemed to be really prone to uneven pad deposition. Straight track-only pads were general fine. If you've never seen uneven pad deposition it looks like a leopard skin appearance on the rotor face. You have to get the lighting just right to see it. You will then feel a lot of brake pedal pulsation if severe. 2) New pads are not flat and really pretty pad for some big name companies. We measured some brand new, out of the box pads. Bedding the pad in per the manufactures recommendation is critical. It helps the pad "flatten" out under less aggressive wear conditions and mates with the rotor. What old pad that was on before the bedding process with the new pad matters and can impact whether or not you run into uneven pad deposition. Some folks install an aggressive "cleaning pad" to remove the old pad material from the rotor prior to installing the desired pad for the track. My track pads are so aggressive they seem to clean the rotor and bed-in great. 3) Rotor geometry has to be very precise not to get pulsation. I think the input is the rotors "clamped state" geometry matters. For that matter, the rotors clamped and hot state matters. I'll track down some more info from my friend. That's what I heard from my friend that consults within the industry. 4) I've seen one case on a brake job that I did for a street car where the rotor casting cracked where the internal air vanes intersect the rotor face. The rotor face then slightly protruded at this point and there was massive brake pedal pulsation. 1-2 month old new rotors did this! (I did get a refund) I only discovered the cause by getting the right lighting on the rotor and seeing a very faint bluing spot. I've read of the Tundra complaints on brakes so I know when it gets time to do a brake job I will track down what I think is a high quality rotor as a starting point and ask around for what pad works best. For my track car, I always used StopTech rotors but they were full floating rotors with aluminum hats and worked perfectly. I'll probably buy street StopTech rotors for the Tundra. Hopefully a few years from now! I hope that helps. Cheers.
    Black Wolf likes this.
  20. Jan 31, 2021 at 5:04 PM
    #50
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    I have been using Black Hart cross drilled n slotted rotors haven't warped on me almost through my first set of pads on them. an I do drive it Hard an whisper NasTundra :rofl:the only thing I've noticed using them is brake dust from hell could be my driving habits , could be the pads , or could be the nature of cross drilled an slotted rotors. if you need any other brake parts on top due to service than just rotors an pads I would recommend a complete kit from Stopping Power or someone else.
    but just for 4 Rotors an a 4 sets of ceramic pads $250 range isn't that bad....;)
  21. Jan 31, 2021 at 10:59 PM
    #51
    Tundyfundy
    Bay Area, CA
    best. Movie. Ever.
    Uhhhh....[QUOTED] likes this.
  22. Feb 3, 2021 at 7:53 PM
    #52
    Hughjanice
    Hughjanice New Member
    Hieu
    2015 Toyota Tundra CM 4x4
    Two single led light bars behind grille, bak revolverx2, fn 18" wheels, bfg ko2. 46gal transfer flow tank.
    Stoptech, EBC, Advics, Akebono to name a few. I went with Autozones GT series since it was on a promo and they wanted to gain some business. No complaints so far. Prior to these i've ran Wagner pads and rotors. By far the worst brakes i've had on the truck. Advic's pads and rotor combos have been working out great for all our toyota customers.
  23. Feb 3, 2021 at 8:03 PM
    #53
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    :popcorn:
    Hightide likes this.
  24. Feb 3, 2021 at 8:56 PM
    #54
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Once you go cryo you never go back.
    P.S. over torqued lugs can cause rotor issues as well.
    Just wanted to add more fuel.
  25. Sep 28, 2021 at 4:29 PM
    #55
    CoxTruckin07
    CoxTruckin07 New Member
    Joel
    2007 Tundra Double Cab, LTD, 5.7L, 4WD
    none... yet
    @SA183 if you find some that won’t warp, let me know… my stock ones warped, bought PowerStop Heavy Duty Truck (drilled and slotted) Rotors and they warped after 20k. It has to be something to do with Toyota’s braking system or the lack of airflow for cooling… my wife’s RAV4 did it, her Highlander did it… every Toyota I have ever driven, that had more than 60k on it, shimmied when you applied the brakes. Idk
  26. Sep 28, 2021 at 4:40 PM
    #56
    Pa'Zapp's
    Pa'Zapp's New Member
    PaZapp's
    2003 Tundra
    Brake Rotors, exhaust, Bull bar, side steps & pin stripped tailgate
    Replacement Calipers push the pads too tight. Causes problems with the Rotors. Select good Calipers and the problem goes away. Not Toyota but the Parts the parts store sell thas the fact of choice ! I chose slotted rotors at 150,000 miles with decent calipers and Pads. Sure the originals were worn and showed heat crack on the back sides if them, they also had 100,000 miles of interstate driving and hard slow downs. Of course I don't believe the Tundra has equivalent brakes to a Trailer Tow F150, absolutely not, but for 130,000 miles the Tundra truck is as most are, a (garage queen) & is a great truck !
  27. Sep 28, 2021 at 4:58 PM
    #57
    Drilled and slotted rotors are famous for that, especially PowerStops. You want slotted only. The StopTech Sport slotted only, cryo treated are the way to go. I have a post somewhere showing the hot spots that my PowerStops had. They were so bad that my steering wheel shook without even touching the brakes.
  28. Sep 28, 2021 at 5:38 PM
    #58
    Uhhhh....
    Dave
    7” BDS, 37s
    I picked up StopTech cryo drilled & slotted. Hopefully all will be well since they’re cryo. :fingerscrossed:
  29. Sep 28, 2021 at 5:43 PM
    #59
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I put these on my 2014 and had no issues. I am a very hard braking driver.
  30. Sep 28, 2021 at 5:48 PM
    #60
    Uhhhh....
    Dave
    7” BDS, 37s
    Good to hear :thumbsup:
