Rookie move....need some help
Discussion in 'General Tundra Discussion' started by Mr Swervlin, Feb 8, 2020.
  1. Feb 8, 2020 at 5:43 AM
    Mr Swervlin
    Mr Swervlin [OP] "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    So....left my windshield wipers on accidentally. Next day everything was covered in ice. Get in to fire up the truck and the driver side wiper got stuck but, the passenger side continued like normal. I tried doing a search but, couldn't find what I'm looking for. Can anyone please post a wiper schematic for a 3rd gen? Need to do a little investigation. I know...I know....I'm fired. Thanks
    NewImprovedRon likes this.
  2. Feb 8, 2020 at 5:49 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Don't have any real info but I suspect the wiper transmission is bad on the passenger side, I'd see if it's covered under a warranty if you have one.
    Mr Swervlin[OP] likes this.
  3. Feb 8, 2020 at 5:57 AM
    Mr Swervlin
    O H I O
    I have an extended warranty but, not sure when I'd be able to drop it off. I use this truck to pull a trailer for work every day. I try to do most of the maintenance myself if possible
  4. Feb 8, 2020 at 6:01 AM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    It’s an entire assembly. If you remove the plastic cowl under the windshield it’s very self explanatory. You may have stripped the arm so remove it and reinstall. If that doesn’t fix it the assembly is about $130
  5. Feb 8, 2020 at 6:05 AM
    Lake.Life24
    Lake.Life24 Dogs > People
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I had this happen to be because the bolt loosened up. I just positioned the wiper at the bottom of the windshield and tightened the bolt. Everything is good to go now
  6. Feb 8, 2020 at 6:30 AM
    Mr Swervlin
    O H I O
    Thanks. When this snow finally stops falling I'll get out there and give it a shot
  7. Feb 8, 2020 at 6:34 AM
    Istvank11
    Istvank11 Shine On
    AZ
    2016 CM
    Luckily I was able to fix my wiper the same way
  8. Feb 8, 2020 at 6:42 AM
    Mr Swervlin
    O H I O
  9. Feb 8, 2020 at 7:24 AM
    15whtrd
    15whtrd Mr. Blonde
    Seen this happen around here before. Most likely you should be able to reposition the wiper and tighten it back up.
  10. Feb 8, 2020 at 7:45 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Nah, no worries, man. I hadn't ever thought of that until you mentioned it. Hope it resolves itself easily.
  11. Feb 8, 2020 at 9:36 AM
    Mr Swervlin
    O H I O
    Update...the wiper arms main screw was loose
    That it. 2min fix. Thanks for the heads up folks.
    MT Madman, Istvank11, 15whtrd and 4 others like this.
  12. Feb 8, 2020 at 10:05 AM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Rookie...LOL....Glad it was resolved so easily!
    Mr Swervlin[OP] and 15whtrd like this.
