Roof rack on bed rails?
Discussion in 'General Tundra Discussion' started by Sas, Aug 4, 2018.
  1. Aug 4, 2018 at 7:58 PM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Anyone found a roof rack that will sit on top of the bed rails for the short bed?
  2. Aug 4, 2018 at 8:04 PM
    Sas
    OKC, OK
  3. Aug 4, 2018 at 8:44 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
  4. Aug 4, 2018 at 8:47 PM
    Sas
    OKC, OK
  5. Aug 4, 2018 at 8:49 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    They do have stuff for short beds but in my honest opinion I would never recommend that especially if you're going to be loading it down with weight.
    Look online and you'll see plenty of instances where the sheet metal underneath the plastic caps crack. They mount the bed rail in a way that does not distribute the load, it's all focused into a very small area
    Black Wolf and Sas[OP] like this.
  6. Aug 4, 2018 at 8:52 PM
    Sas
    OKC, OK
    Yeah, I'm not really wanting to utilize the Tundra rail system anyhow. I'm really looking for something that will just rest on the bed rails and have some legs that go down into the tiedown holes for stability. I want to be able to take the thing off pretty easily.
  7. Aug 4, 2018 at 8:55 PM
    nk1794
    San Jose, CA
  8. Aug 4, 2018 at 8:55 PM
    nk1794
    San Jose, CA
    If I don't have a cap I would consider something like this.
    jewsNbrews likes this.
  9. Aug 4, 2018 at 9:00 PM
    Sas
    OKC, OK
    That's pretty nice, but not really what I'm looking for unfortunately. I basically just want a shelf to separate the load up a bit for easier access when I'm loaded up for camping or something. I want to put the heavy stuff that can slide on the bottom and the squishy, light stuff on the rack.
  10. Aug 4, 2018 at 9:26 PM
    Vancepp
    Vancepp New Member
    2017 TRD Off Road
    Toytec Boss Kit, Method Grids, 305/70-18 STT Pros
    If you are just looking for crossbars to go across the bed to mount a cargo basket to, check out the Yakima BedRock System. Simple, easy and even easier to remove when you don't want it on. They are actually coming out with a new version of it in February that will have a super heavy duty crossbar. Not my picture, just used as an example. This guys has two bike racks and the cargo basket on it.
    jewsNbrews, nk1794 and Sas[OP] like this.
  11. Aug 4, 2018 at 9:32 PM
    Sas
    OKC, OK
    That looks damn near perfect, thanks!
  12. Aug 4, 2018 at 9:38 PM
    Vancepp
    Vancepp New Member
    2017 TRD Off Road
    No problem! There are two different sizes of the basket. LoadWarrior (smaller) and the MegaWarrior (larger). Either would fit. Any Yakima dealer could help you out. Or call any Rack Attack and mention coupon code Rack10 and you will get 10% off. (That was a shameless plug... sorry.)
  13. Aug 5, 2018 at 6:02 AM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I use a similar setup - Yakima cross bars and a LoadWarrior basket. Works well - there is plenty of cargo room under the rack and it is easy to remove when needed.
    Mater, jewsNbrews, don3032 and 2 others like this.
  14. Jun 28, 2020 at 2:11 AM
    BigLando310
    BigLando310 New Member
    orlando
    Southern California
    2016 Tundra SR5 crewmax TRD off road 4x4
    TRD PRO grill, tint lol
    2016 TRD O.R CM...
    looking for bed cover (Tonneau covers) but my question is.. are bed covers compatible with truck bed cross bars for a cargo basket? is this set up possible? any leads pointing me to right direction thanks.
    most covers fold up which wont work with bed cross bars, is there a cover that slides in? would prefer if the system is easily removable if possible. thanks
  15. Jun 28, 2020 at 7:42 AM
    Vancepp
    Vancepp New Member
    2017 TRD Off Road
    Retrax XR series works great.
  16. Jun 28, 2020 at 7:54 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Can you still open your tonneau with that setup?
  17. Jun 28, 2020 at 7:56 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Truck covers USA works as well
  18. Jun 28, 2020 at 8:21 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Yes. I have a retractable cover that rolls in a canister at the front.
  19. Jun 28, 2020 at 8:50 AM
    BIGUGLY
    Paul
    2018 Limited
    KB Voodoo might have some options for you
  20. Sep 20, 2021 at 12:46 PM
    FLMallCrawlr
    FLMallCrawlr New Member
    2019 Tundra limited
    20x9 pro comp wheels Custom built exhaust w/magnaflo S&b intake 6112 front Fox back Rigid ditch lights Infinity speakers with kenwood amp 2 10” mtx subs
    I used had their cross bars with my Tacoma. They are nice but very pricey.
