Roof console removal/modification?
Discussion in '2.5 Gen Tundras (2014-2021)' started by smslavin, Oct 20, 2017.
  1. Oct 20, 2017 at 7:58 AM
    smslavin
    smslavin [OP] Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    So, in the roof console, there's the sunglass holder up front then the giant useless clip thingy. Does anyone know what's behind it? Is there a little cavity like the sunglass holder? Can it be removed? Is there a way to pull the whole console down?
  2. Oct 20, 2017 at 8:40 AM
    SoCalDave
    SoCalDave New Member
    Dave
    2016 DC 4x4
    Comes down pretty easy. Pull that clip thingy cover off, then I believe it was 4 screws and the whole thing comes down. I think it's where the sunroof/moon roof controls are suppose to be? Lots of plastic there which is also connected to the lights. I was looking to put rocker switches there, but it looks like a lot more work than I wanted to put into it.
    Sunnier and smslavin[OP] like this.
  3. Oct 20, 2017 at 8:57 AM
    smslavin
    Hudson Valley
    Some stuff
    Nice. Didn't realize that the clip portion would pop off by itself. I think I'm going to mount the HAM faceplate there. Need to pull it off and do some tinkering.
  4. Oct 20, 2017 at 9:55 AM
    DVYota
    DVYota Super stock street truck
    South Carolina
    2014 Sequoia 2021 Tacoma
    Basically stock
    Like what this guy did in a 5th gen T4R?
  5. Oct 20, 2017 at 9:58 AM
    smslavin
    Hudson Valley
    Some stuff
    similar but i've actually been using the sunglass holder and i'd like to keep it. i'll see what i can get mocked up and post some pics.
    831Tun, Sunnier and DVYota[QUOTED] like this.
  6. Oct 20, 2017 at 12:05 PM
  7. Dec 26, 2018 at 10:38 PM
    johnny0t
    johnny0t New Member
    I actually just started doing some work on the overhead console on my 2017. I want to put a coax switch and possibly some other things in that space, so I pulled that panel off this afternoon. There is some additional structure behind it (possibly for some features my truck does not have), but nothing that looks critical. I started drawing up a blank to 3D print, and I will try and finish up a fitment tomorrow to verify the 2D profile. Once I have the blank drawn up I will upload the .stl to youmagine.
    Thank You,
    Johnny
    panicman and tinman10101 like this.
  8. Jan 3, 2019 at 1:39 PM
    johnny0t
    johnny0t New Member
    TRDblvd likes this.
  9. Jan 14, 2019 at 7:14 PM
    hnsmrob
    hnsmrob New Member
    Tampa, FL
    Maximum Effort
    great mock up @johnny0t ! I am a new tundra owner who will be modifying for camping/overlanding and have been disappointed with the options thus far for the locations of new accessory switches. The overhead is the best location and will be my choice. With respect to your design, is it a plug/n/play piece? ie. are the OEM tabs printed on the part so that it will simply 'pop' into place of the old piece? if so, would you consider printing the piece for purchase? I think you are on to something huge with this design!
    Thanks for the great work.
  10. Jan 14, 2019 at 8:13 PM
    Welcome from NY.
  11. Jan 15, 2019 at 6:45 AM
    hnsmrob
    hnsmrob New Member
    Tampa, FL
    Maximum Effort
  12. Jan 15, 2019 at 6:47 AM
    And......:spending:lots of! :rofl:
  13. Jan 15, 2019 at 10:24 AM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    RNDABOUT, Ostrich, B737 and 1 other person like this.
  14. Jan 15, 2019 at 12:18 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    I like that. What are all the different compartments for?
  15. Jan 15, 2019 at 3:57 PM
    SiberianTundra
    Greg
    War Machine
    I honestly do not know what the compartments are for. But I been eye balling this over my current short ceiling console.
    B737 and AlmightyCrash[QUOTED] like this.
  16. Jan 15, 2019 at 5:17 PM
    johnny0t
    johnny0t New Member
    @hnsmrob Thank you! That design does include all of the tabs, and some relief geometry for an OE fit, and it is quite snug. That design is meant to be a starting point for further customization, so it would really not do you much good without adding geometry for the switches, or whatever else you wanted to do with it. I do not have any interest in producing these (at least not with a 3D printer), but if you do not have access to a 3D printer you can upload the design to https://www.3dhubs.com/ to find somebody who can print it for you (and even get multiple quotes before buying). I would recommend ABS for the material (which is what I will use when I do the final print for mine), as it should (theoretically) tolerate the heat of a vehicle in summer better than PLA.
    @SiberianTundra I considered doing the same thing, but without knowing what it would take to install the larger console I do not want to start down that path. I am a little bit leary of what it might entail to get everything mounted correctly and in a sturdy fashion.
  17. Jan 15, 2019 at 8:28 PM
    hnsmrob
    hnsmrob New Member
    Tampa, FL
    Maximum Effort
    @johnny0t, thanks for the info. I'll be pursuing this further and I'll post my progress for anyone else who is interested or has struggled to find an ideal location for switches.
  18. Jan 15, 2019 at 8:39 PM
    hnsmrob
    hnsmrob New Member
    Tampa, FL
    Maximum Effort
    FYI - $26 to have the 3d printed piece of abs from 3dhubs.
    Might have it printed just to do some tinkering myself.
    SiberianTundra likes this.
  19. Apr 11, 2019 at 1:13 AM
    shinobitactical
    shinobitactical Tundra buddies for life!
    2022 Platinum Tundra long bed
    Black out emblems, tailgate insert, airbag rear suspension, Toyota branded bakflip bed cover.
    This setup came on my 07 tundra and I loved it. The two back ones are like large sunglasses doors but double the size of the actual one. I used to keep all sorts of things up there. The one just after the sunglasses cubby is basically a flip down paperclip deal. In my new tundra I only get the sunglasses one and a stupid plastic paper clip thing that is the most useless thing I’ve even seen. I have been searching how to put the old setup on my new truck, I’m hoping it’ll work.
    jtwags likes this.
  20. Apr 11, 2019 at 4:26 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
  21. Apr 11, 2019 at 5:00 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    B7892BB2-04FD-4DA9-AB52-D43F0AFB35B5.jpg 49F3C882-0480-42B0-B697-6C17A27A8032.jpg
    Put a CB in my overhead
  22. Apr 11, 2019 at 7:27 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Someone please do this and then tell me it is pretty dang close to plug and play..... It would cause a nation-wide shortage of the part.
  23. Apr 11, 2019 at 9:00 AM
    SiberianTundra
    Greg
    War Machine
    if you search ebay for 2007-2013 overhead console there are so many. But I do not think they will fit. We might need the headliner as well
    darkknight2014 likes this.
  24. Apr 11, 2019 at 10:14 AM
    n2deep
    n2deep Pavement Princess
    I put wireless switches in the worthless business card spot.
    shinobitactical likes this.
  25. Apr 11, 2019 at 10:24 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Switch Pro went there. I made a panel and mounted this on my bro's truck. I will be doing the same in mine.
  26. Apr 11, 2019 at 10:48 AM
    SiberianTundra
    Greg
    War Machine
  27. Apr 11, 2019 at 10:56 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Plan on making this for sale?
  28. Apr 11, 2019 at 11:37 AM
    matictundra
    Franco
    AZ
    Not at the moment.
  29. Mar 13, 2020 at 2:50 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    On a 2015 1794 CM with sunroof.
    How do you remove the overhead console?
    Winks4x4Toy likes this.
  30. Jun 25, 2020 at 3:17 PM
    2a_TX_Tundra
    2a_TX_Tundra New Member
    2020 SR5 CM TSS in Quicksand
    What year is yours? You don't seem to have the envelope holder like the rest of us do on our newer tundras
