Rolled truck on left side...now have clicking coming from lower right side oil pan.
Discussion in '1st Gen Tundras (2000-2006)' started by Intuit, Feb 8, 2025.
  1. Feb 8, 2025 at 11:59 AM
    Intuit
    Intuit [OP] New Member
    Bill
    2005 Toyota tundra 4.7l
    Truck was running great prior to. Feel poss. bearings. Would like to keep truck. Ready to pull motor. Suggestions?? Tks.
  2. Feb 8, 2025 at 12:04 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Type more details.
    add pics.
  3. Feb 8, 2025 at 12:10 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Complete sentences are fun
  4. Feb 8, 2025 at 12:13 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  5. Feb 8, 2025 at 12:16 PM
    Intuit
    Bill
    Flipped over in flood (Helene). Motor runs. Initially had quite a bit of exhaust smoke after getting upright. Has set for a while, now no smoke. Still have clicking, strongest at upper oil pan, (left corner as looking at motor from front). Possible oil pump or bearings.
  6. Feb 8, 2025 at 12:18 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    You had exhaust smoke because you had oil in the cylinders. It doesn’t sound like you got the oil out of the cylinders before attempting to fire it up. Oil does not compress like air does mixed with fuel. I wouldn’t be surprised if there were at minimum bearing damage.
    Ideally, you should have pulled the spark plugs and turned the crank by hand several times to make sure you got most of that out. You still would’ve had exhaust smoke until it all burned up but could have possibly saved the motor. Too late now.
  7. Feb 8, 2025 at 12:41 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    A video/audio clip would be nice. I guess you could’ve starved the engine of some oil if it was running while on its side.
  8. Feb 8, 2025 at 2:32 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Can this be a damaged or cracked flywheel?
  9. Feb 9, 2025 at 6:06 AM
    shifty` I'm having daydreams about night things
    The Megathread does in fact include links to samples of the 'rattling marbles' sound typical of cracked flex plate, wouldn't surprise me to find the torsion of rolling would cause that:
    • Strange rattle noises at back of engine, like marbles rolling around: Several people here and at other forums have found this issue where they describe the sound as loose marbles banging around. Then found their flex plate was cracked in multiple places. Ticking timebomb. Check it out and another one with videos
