Rokblokz mud flaps - now w/ Installation guide/pictures
Discussion in '2.5 Gen Tundras (2014-2021)' started by BlueBottle, Jan 20, 2017.
  1. Oct 12, 2020 at 4:16 PM
    #91
    mdrabicki
    mdrabicki New Member
    Mark
    2020 Toyota Tundra TRD PRO
    Yes! I installed the Coachbuilder TRD Pro lift and level kit and with that 35x12.5R18 BFG KO2's with 1.25" spacers and tried to find answers to the same questions. Very hard to guesstimate what would be the best mudflap option that would extend further out from the wheel well but not too much and be thin enough to allow full turning radius with the larger tires. Mine rub a bit at full lock but still less than the stock one did.
  2. Oct 12, 2020 at 5:02 PM
    #92
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Just cut out a hole where the BM contacts the flap. They then fit flush. That’s what I did with my rokblokz and it stopped the rub.
    HulkSmurf14 likes this.
  3. Jun 3, 2021 at 11:02 PM
    #93
    SmokeyTT
    SmokeyTT Smokey The Tundra
    Oahu
    2018 SR5 Off-Road 4x4 Crewmax
    Hey dude so glad I came across this. So I am getting OEM flares from bushwhacker. I have same rim dimensions as you but 285/70. I'm wondering if you think these could work with flares (i'm sure I'll figure out a way to make them work?) and if you could snap a closer picture of the rear flaps in line with the tire? I need to have them cover the entire tread of the tire or I can't pass my reconstruction permit test for the truck haha.
  4. Jun 3, 2021 at 11:05 PM
    #94
    SmokeyTT
    Oahu
    AAny rusting with these?
  5. Jun 3, 2021 at 11:08 PM
    #95
    SmokeyTT
    Oahu
    Would you mind snapping a picture of you rear so I can see how much tread the mudflaps cover? I am getting OEM BW flares and looking to get these to cover the whole tread of my tire. I'm at 18x9 +25 with 285/70. My tire sticks out about .5-1" past the fender without flares.
    t4r2tundra likes this.
  6. Jun 4, 2021 at 5:39 AM
    #96
    t4r2tundra
    t4r2tundra New Member
    2019 Platinum 4x4 - Smoked Mesquite
    See sig for mods...
    Hey bud, check out my thread for pics of mine. Wheel specs in there too. Now I did get the XL and in the later posts in my thread, I drilled new holes and set them inward perfectly to cover my tires and not much more.
    SmokeyTT[QUOTED] likes this.
  7. Jun 4, 2021 at 11:09 AM
    #97
    SmokeyTT
    Oahu
    That was an awesome answer. I ended up contacting Rokblokz to switch from the regulars to XL's. I mean why not just have the extra coverage and modify it to what I'd like. Thank you sir!!
    t4r2tundra[QUOTED] likes this.
  8. Aug 4, 2021 at 1:31 AM
    #98
    Jbunn2001
    Jbunn2001 New Member
    2020 Trd Off-Road SR5 Crewmax
    Toytec Ultimate with shackles 3/1.5 Fuel Zephyr 20x9 +1 Nitto Ridge Grappler 33x12.50
    What are the dimensions of the front and rear flaps? Height/ width etc?
  9. Sep 27, 2021 at 9:33 AM
    #99
    SRNae
    SRNae New Member
    Nathan
    2021 Black Tundra TRD Offroad
    The website lists the RockBlocks as specifically not working for TRD models. That can't be right, can it? why would these not work?
    "(This kit does not currently work with the side-exit exhaust on the TRD Pro, TRD Off-Road, and TRD Off-Road Premium)"
  10. Nov 23, 2021 at 6:11 AM
    #100
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    Question for everyone...their website says it won't work with a TRD Pro or TRD offroad. They state it is because the side exhaust will melt the mudflaps. Has anyone had melting? I installed these on my 4Runner Pro and the coverage is fantastic, but they did melt with the PRO's side exhaust. Dont all Tundra's have side exhaust?
  11. Dec 3, 2021 at 6:38 AM
    #101
    ProtoJ
    ProtoJ New Member
    FYI....I just learned from Rokblokz that they have a new plastic formula that does not melt. So I ordered and installed their new version. They have not updated their website.
    baron and SRNae like this.
  12. Dec 3, 2021 at 9:17 AM
    #102
    SRNae
    SRNae New Member
    Nathan
    That's fantastic! Thanks for the info, I will be grabbing some as well. Much appreciated!
  13. Feb 22, 2022 at 10:01 AM
    #103
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Do you have pics posted?
  14. Feb 22, 2022 at 10:12 AM
    #104
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
  15. Feb 24, 2022 at 9:49 AM
    #105
    TundraRV
    TundraRV New Member
    2021 SR5 SX Double Cab
    Anyone have photos of the Rokblokz XL installed?
  16. Feb 25, 2022 at 4:15 PM
    #106
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Another option
    jgullace likes this.
  17. Jul 17, 2023 at 8:55 PM
    #107
    Landmark5
    Landmark5 New Member
    Zach
    Boise, ID
    2021 Tundra SR5 DC
    Bilstein 6112 & 5100 Toyota Sway Bar Boise Spring Works Heavy Duty Kit
    Out of everything I have seen, I really like how these came together. Mind sharing what material you used and where you got it? I am also in Boise
  18. Jul 18, 2023 at 1:34 PM
    #108
    Boisefly
    Boisefly New Member
    Boise, ID
    I used these:
    https://www.amazon.com/gp/product/B06XRJHFF1?ie=UTF8&th=1
    It actually worked out very, very well and the flaps have held up for 20K miles over 1.5 years. Still look like new.
    Needed a jigsaw to shape the flaps, drill to make the holes, and 3 hours of my time
