Rock Warrior club
Discussion in '2nd Gen Tundras (2007-2013)' started by Medicth, Jan 6, 2014.
  1. Dec 13, 2018 at 9:14 AM
    #121
    YZTundy
    YZTundy New Member
    Denver, Co
    2011 Crewmax Rock Warrior
    Running 3" in the front and 2" of lift in the rear, the tires are 35x12.50R17 with 1.25" wheel spacers.
  2. Dec 13, 2018 at 9:37 AM
    #122
    Apocalypse
    Apocalypse New Member
    You run wheel spacers in back also. Was wondering what all modifications it took up front to get them tires to fit. I can see no mud flap. Truck does look good like that are you happy with it. Thanks for all your help.
  3. Dec 13, 2018 at 9:40 AM
    #123
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  4. Dec 13, 2018 at 9:45 AM
    #124
    Gibo244
    Gibo244 New Member
    KG
    Maui
    Gatlings are sweet. Best part of my q45
    More pics when done
  5. Dec 13, 2018 at 9:51 AM
    #125
    YZTundy
    YZTundy New Member
    Denver, Co
    No mud flaps in the front I did SPC UCA's which helped me push the tire away from the body mount and then I just heated up the front plastic and pushed it forward and I only have rub in reverse at full lock just a slight amount. I do run spacers front and rear
  6. Dec 13, 2018 at 11:15 AM
    #126
    Apocalypse
    What for lift you running. Is it a spacer lift
  7. Dec 14, 2018 at 6:21 AM
    #127
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Quick question for you Rock Warrior folk- Can I switch my stock, SR5 18" rim and tire combo for a stock Rock Warrior 17" rim and wheel combo WITHOUT having to adjust anything? I'm thinking since it is a stock-for-stock swap, I should be fine BUT you never know. Speedometer stay the same? Mileage stay the same? Any help is greatly appreciated!
  8. Dec 19, 2018 at 4:55 AM
    #128
    NE_WARRIOR
    NE_WARRIOR [HOONIGAN] Wannabe
    Nick
    Union, ME
    08 DC SR5
    Does anyone have a tried and true way to remove brake dust from our wheels? my back right brake pad disintegrated and the dust is starting to corrode. i got after it with a pressure washer and a scrub brush yesterday but i had to leave and wasn't satisfied with my progress. I have this stuff called poly-chem spray jet st-22 at work that eats through grime no problem but i don't know if its safe for the wheel or not. ill look into it more in the meantime but any advice is appreciated.
  9. Dec 23, 2018 at 6:05 AM
    #129
    DigsRW
    DigsRW New Member
    2010 White CM RW
    6112's w/ CB shim front, 5160's CB shackle rear, BLM, T-Rex grill with BAMF letters, TRD sway bar, TRD air box, SBAM, Clazzio seat covers, swing cases, Bronze finish RW wheels
    "Does anyone have a tried and true way to remove brake dust from our wheels? my back right brake pad disintegrated and the dust is starting to corrode. i got after it with a pressure washer and a scrub brush yesterday but i had to leave and wasn't satisfied with my progress. I have this stuff called poly-chem spray jet st-22 at work that eats through grime no problem but i don't know if its safe for the wheel or not. ill look into it more in the meantime but any advice is appreciated."
    Probably not quiet the answer your looking for, but my wheels have been nicked up and have pitting over the years I decided to have them sand blasted and refinished. I’m hoping with a little care they’ll last in this shape for a few years, it was much easier than looking for products to clean them back up or worse buying new wheels.
  10. Dec 25, 2018 at 12:14 AM
    #130
    LBGlossWorks
    LBGlossWorks New Member
    Rawr
    2013 Toyota Tundra RW
    My 13RW
    cygan1008 and Beardedbeast like this.
  11. Jan 2, 2019 at 6:01 AM
    #131
    NE_WARRIOR
    Nick
    Union, ME
    08 DC SR5
    I was thinking about powder coating the wheels a bronze color in the spring and plasti dipping the ring black very similar to your gold and black. I was debating the bronze color but after seeing your wheels I'm definitely going for it
  12. Jan 4, 2019 at 5:41 AM
    #132
    Big Yota
    Big Yota New Member
    2018 Double Cab TRD Off-Road 4x4 Blazing Blue Pearl
    Cap (soon)
    I've been reading this thread and I am wondering what makes the Rock Warrior special? I see the obvious which is a body color front bumper and grill surround. The black rear bumper and the simulated bead lock 17" wheels. What else is included on say a 2013? It appears colors are limited as well to Black, White, Red?
  13. Jan 4, 2019 at 7:33 AM
    #133
    NE_WARRIOR
    Nick
    Union, ME
    08 DC SR5
    You pretty much got all the details worked out except for the full skid plates and there was nine different color options
  14. Jan 4, 2019 at 7:58 AM
    #134
    Big Yota
    Big Yota New Member
    Cap (soon)
    So nothing special with the shocks unlike the Gen 3 TRD Pro. No special rear box just a decal like a current TRD Off Road?
  15. Jan 4, 2019 at 8:02 AM
    #135
    NE_WARRIOR
    Nick
    Union, ME
    08 DC SR5
    its essentially a TRD off road with color matched parts, nice wheels, and good tires
  16. Jan 4, 2019 at 8:20 AM
    #136
    Big Yota
    Big Yota New Member
    Cap (soon)
    Thanks that's what it sounds like. So Toyota shocks or Bilsteins of some sort? And if the tires are say 6 years old no real value there as starting to age out. The 17" wheels, although nice looking on a regular car, are kind of small by today's standards for a truck. I am just trying to justify any price difference over a similar non Rock Warrior 2013 and comparing to say a Gen 3 2015 TRD Off Road. The 2015 would still have some warranty. Pluses are nicer more modern interior and exterior styling, etc.
  17. Jan 4, 2019 at 8:29 AM
    #137
    10TundraSR5
    Tennessee
    Doesn't the Rock Warrior have 4.30 rear diff wheres all the other Tundras have 4.10's?
    Rica25 likes this.
  18. Jan 4, 2019 at 8:34 AM
    #138
    NE_WARRIOR
    Nick
    Union, ME
    08 DC SR5
    4.30 is the tow package ratio, im not sure if it came standard with the RW package
    Rica25 likes this.
  19. Jan 4, 2019 at 10:06 AM
    #139
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    New to the forum... Thought I'd join in on this thread.
  20. Jan 4, 2019 at 10:35 AM
    #140
    Big Yota
    Big Yota New Member
    Cap (soon)
    Shellboyz why does your Warrior have a chrome rear bumper?
  21. Jan 4, 2019 at 10:45 AM
    #141
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    That is how it came from the dealer. Not a fan of chrome at all and will make some changes to that in the near future.
    Bought it as a Limited - also came with power folding side mirrors... :yes:
    Rica25 likes this.
  22. Jan 7, 2019 at 4:49 AM
    #142
    BorderCop
    BorderCop New Member
    2012 Rock Warrior
    2.5" ADS coilovers. 35x12.50 tires. ARE Z series cap.
    New to the forum as well. 2012 here on 35s. In this picture the truck was on stock suspension with no lift and no rub.20170428_132502.jpg
    Sinkos, cygan1008, Macreggg and 2 others like this.
  23. Jan 7, 2019 at 5:12 AM
    #143
    Chaser31
    Chaser31 New Member
    2013 Tundra Limited Rock Warrior
    Because its limited.
    Stormtrooper81 and Macreggg like this.
  24. Jan 7, 2019 at 8:57 AM
    #144
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    what are you using to mount your front light bar?
  25. Jan 7, 2019 at 9:21 AM
    #145
    BorderCop
    2012 Rock Warrior
    It's an NFab led bar mount. Go it several years ago from Amazon.20160826_142055.jpg
  26. Jan 7, 2019 at 9:37 AM
    #146
    NE_WARRIOR
    Nick
    Union, ME
    08 DC SR5
    35s fit without rub on stock height? i was unaware of this but now that I am, I might be doing more burnouts to upgrade sooner
    dw8494 likes this.
  27. Jan 7, 2019 at 9:40 AM
    #147
    BorderCop
    2012 Rock Warrior
    BFG KO2 35x12.50 17s on Rock Warrior wheels for sure.
  28. Jan 7, 2019 at 9:43 AM
    #148
    Woodtickmp
    Woodtickmp Black beast/beauty/pearl
    Mathew
    west bend WI
    2010 tundra double cab black TRD rock warrior
    3in front leveling kit with camburg engineering upper A-arms, 2in block in the rear and 6 pack leafs, 295/65/17
  29. Jan 7, 2019 at 11:25 AM
    #149
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I've run across one other guy with the exact same setup who reported no rubbing. Does it have to be KO2s? Is it something about their specific dimensions or shape that allows this to work?
  30. Jan 7, 2019 at 1:45 PM
    #150
    Chaser31
    Chaser31 New Member
    Nice truck. I have the same steps.
