Rock Sliders!
Discussion in '2.5 Gen Tundras (2014-2021)' started by l3LUEFALCON, Apr 25, 2018.
  1. Sep 10, 2020 at 9:14 AM
    #331
    BackwoodsResearchGroup
    BackwoodsResearchGroup New Member
    2014 Toyota tundra crewmax
    Thanks all for the responses and info. Likely going to run without the sliders for the trip and do some research. Will likely call WKO to see what they recommend in terms of not drilling into the frame or welding. If those two are a must likely to go with RCI. Will update with pics after all is said and done.
  2. Sep 10, 2020 at 9:33 AM
    #332
    kevine0001
    kevine0001 New Member
    Kevin
    With regard to drilling, as I recall when I made my own, there are 2-3 holes on the bottom of the frame that already have threaded nuts inside the frame, however, they are small. 3/8 or smaller. You could use these with the right size bolt to hold the bottom side of a bolt-on slider. The sides of the frame have holes, but they are larger, like 2"x2" squares, so you'll need large backing plates inside the frame (it's open on the inside) to use as large washers. When I made my sliders, I used 1/4" plate steel backing places, like 3" squares, along with washer and lock washer.
    Assuming there's only 2-3 holes on the bottom, IMO I do not believe that is enough for a "rock slider". Remember, it's that bottom bolt/mounting tab that holds the weight of your truck when you lay your slider on a rock. I don't think 2-3 3/8" nuts/bolts is even close to being enough. That's why most manufacturers have you drill out 1-2 more holes on the bottom. I actually drilled out ALL the bottom holes, even the OEM ones with welded nuts, specifically so I could fit 1/2" grade 8 hardware. Five on the bottom, and five along the side, for each slider.
    If you end up just using the OEM holes on the bottom with the 3/8" bolts, just realize that those bolts could potentially break if you drop your truck/slider onto a rock. that would be bad as it would likely bend your mounting plates attached to the side of the truck, and likely jack up your rocker panel.
    Just the thoughts of a weekend welder...
    BlueRibbon4x4 and jewsNbrews like this.
  3. Sep 10, 2020 at 8:05 PM
    #333
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    Lol
    Love the C4 sliders and they’re giving away a 4R right now. It’s actually my buddy’s 4R accessory wise (exterior) but brand new.
  4. Sep 10, 2020 at 8:08 PM
    #334
    fundra_goes_west
    Evan
    2022 SQ8
    C4’s are optional drilling, bolt on otherwise. They have great customer service. 11 weeks is what the lead time says right now.
  5. Sep 12, 2020 at 3:00 PM
    #335
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
  6. Sep 12, 2020 at 3:02 PM
    #336
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    6F96DE3F-C5BE-4F51-A94C-B7960F022F03.jpg Soon to be... @BashFab i also need a bike rack solution for wheeling
    :monocle:
    BashFab likes this.
  7. Sep 13, 2020 at 2:55 PM
    #337
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Not silders
    Guy lucked out and avoided body damage from what I can tell.
    jewsNbrews, Skey44 and BashFab like this.
  8. Sep 13, 2020 at 8:36 PM
    #338
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
  9. Sep 14, 2020 at 7:48 PM
    #339
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    I just received my RRW weld yourself kit & they came w/no instructions. Has anybody else welded these together? Any tips? Not sure if I'm supposed to attach the frame bracket to the truck, tack it all together then dismount & finish welding? Not sure where to line all the tubes up w/no advised measurements.
  10. Sep 14, 2020 at 8:01 PM
    #340
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    I did those also. Here is a response I got from them after welding them up. I still have photos of them getting fitted up. DM me if you need help.
  11. Sep 14, 2020 at 8:10 PM
    #341
    The Patriot 1776
    '16 TSS CM 4x4
    Awesome info. Thanks! I believe I've got it from here but if not, I'll DM you. Thanks!
  12. Sep 14, 2020 at 8:13 PM
    #342
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
    Yeah man, good luck. I found them to be slightly too short so I got some DOM and cold roll and added some length
  13. Sep 14, 2020 at 8:14 PM
    #343
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I need to get some real sliders one of these days. Or just add additional support to the frame on the ones i have.
    zcarpenter92 likes this.
  14. Sep 14, 2020 at 8:55 PM
    #344
    The Patriot 1776
    '16 TSS CM 4x4
    I paid $590 shipped so hopefully they're worth @ least that! I think all rock sliders are too short. They all leave too big of a gap in front of the rear tires. IDK why manufacturers don't put them closer to the front edge of the rear fenders (I'm assuming that's where you added length).
  15. Sep 14, 2020 at 10:00 PM
    #345
    Skey44
    Scott
    Greenville SC
    2018 GX 460
  16. Sep 15, 2020 at 9:28 PM
    #346
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    RCI. Kickout is wider than I expected.
    equin, Black Wolf, BigTaco and 3 others like this.
  17. Sep 15, 2020 at 9:37 PM
    #347
    NorAZ
    NorAZ New Member
    Brandon
    2019 Cement CM
    For those that have the RRW sliders can you please post pics of them when you get installed, thanks. Really liking these but I can’t find one picture of these on a tundra. Not even on there website.
    Mrf1987 likes this.
  18. Oct 20, 2021 at 5:52 AM
    #348
    Cb19
    Cb19 New Member
    Go Rhino's aren't great? Haven't seen them mentioned much?
  19. Oct 20, 2021 at 6:54 AM
    #349
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    That's because they are not rock sliders...they are steps.
