Roadside kits
Discussion in 'Off-Topic Discussion' started by OceanSkyWolf, May 21, 2018.
  1. May 21, 2018 at 9:21 AM
    OceanSkyWolf
    OceanSkyWolf [OP] New Member
    2017 MGM CM
    Anybody recommend any rowdside emergency kits? Found some on Amazon, thinking about getting an emergency and flat tire kit. I already carry a small compressor in my truck.
    TXRailRoadBandit73 likes this.
  2. May 21, 2018 at 9:29 AM
    15whtrd
    15whtrd Mr. Blonde
    I sort of pieced my own together. Tire plug kit, compressor, gloves, multiple flashlights, jumper cables, tie down straps, big giant machete LOL, sharpening stone, giant Rambo knife, and emergency first aid kit. I should probably get some road flares and a proper lug wrench besides the factory one. Also when I go on trips I don’t trust the compressor so I bring a hand pump just in case.
  3. May 21, 2018 at 9:36 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I don't like kits... build my own with what I want and better quality parts.
  4. May 21, 2018 at 10:11 AM
    Tacogrande
    Jeremy
    I have the Safety Seal tire repair kit. It has saved my ass a couple times on the road. Iv made 5 repairs total and never had one fail.
  5. May 21, 2018 at 10:19 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Can you link the tire repair kit you have?
    I have had the stuff for plugging for decades and replace the goop and plug stuff from time to time. Not to useful for side wall damage but punctures stay sealed pretty well.
    OceanSkyWolf[OP] likes this.
  6. May 21, 2018 at 10:23 AM
    I thought about starting this thread I need to get a kit started
    OceanSkyWolf[OP] and 15whtrd like this.
  7. May 21, 2018 at 10:24 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  8. May 21, 2018 at 10:27 AM
    15whtrd
    15whtrd Mr. Blonde
    I also keep some basic hand tools under the rear seat, I should probably have a more complete tool set for 100% of the time. I do grab my small toolbox on extended trips. I feel like you could never be too prepared but at the same time where do you call it enough? LOL in a perfect world you have a spare part for any typical failures as well as a welder, air compressor and impact tools. I just don’t have that kind of money or space!
    040Tundra and OceanSkyWolf[OP] like this.
  9. May 21, 2018 at 10:28 AM
    ToyotaTundraMike
    2015 Tundra
    One of the benefits of having a tool box is I have a huge emergency kit.
    I keep a tow strap, battery charger, spotlight, jumper cables, first aid kit, machete, ratchet straps, bungee cords, a scissor jack, and almost every tool that I own either in it or in the DUHA container under the back seat.
  10. May 21, 2018 at 10:39 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
  11. May 21, 2018 at 10:43 AM
    OceanSkyWolf
    2017 MGM CM
    Great info! Include anything else you can think of that you would need in an emergency.
    Do you all have this stuff in the truck bed or back seat? I’ve seen some storage compartments for the bed.
  12. May 21, 2018 at 10:44 AM
    15whtrd
    15whtrd Mr. Blonde
    I guess it depends on where you’re going. A winch would be a huge recovery device and pay for itself in one use if you’re in the middle of nowhere. Plus the kinetic recovery strap as well as all the other little goodies to go along with it. Snatch blocks tree savers tow straps D rings etc.
  13. May 21, 2018 at 10:48 AM
    OceanSkyWolf
    2017 MGM CM
    What about a jack? I have a 2 ton one at home but it’d be a PIA to carry around in the truck
  14. May 21, 2018 at 10:52 AM
    15whtrd
    15whtrd Mr. Blonde
  15. May 21, 2018 at 10:54 AM
    OceanSkyWolf
    2017 MGM CM
    Ahhh can’t forget the cooler!
    :cheers::sandwich:
    15whtrd likes this.
  16. May 21, 2018 at 11:05 AM
    OceanSkyWolf
    2017 MGM CM
    Anybody recommend a good cargo net to store some of this stuff in the bed?
  17. May 21, 2018 at 11:15 AM
    Tacogrande
    Jeremy
    Here it is. It was only $35 back when i bought it...damn price increases. Yea i would not try to plug a sidewall.
    https://www.amazon.com/gp/product/B001DIECCK/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    I also have a bunch more gear in my Locker down under seat safe and behind the back seats. I do want to get a Swing case or something like it but the fact that its plastic just does not make me too confident in it.
  18. May 21, 2018 at 12:10 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've got the same kit, they work very well. I've used them in UTV tires, lawn tractor tires, and vehicle tires. The only one that didn't seal was when my wife hit a hubcap and broke one of the belts in the tire.
    I also carry a Viair 88P, it's a nice compromise between a cigar lighter pump and a full out underhood compressor.
  19. May 21, 2018 at 12:11 PM
    ToyotaTundraMike
    2015 Tundra
    Look into a scissor jack.
  20. May 21, 2018 at 12:14 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i'll have to go take inventory. i have decked drawers in the bed. one drawer is dedicated to emergency/recovery gear.
  21. May 21, 2018 at 12:15 PM
    Tacogrande
    Jeremy
    Waddya know...just looked and my viair is the 88p. Lol.
  22. May 22, 2018 at 2:43 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    Ok. Here’s the full list.
    - jumper cables
    - 12v compressor
    - winch dampener
    - arb d-ring shackles
    - arb snatch block
    - hi-lift slider adapter
    - hi-lift parts kit
    - 4 tie down straps
    - dbpower jump starter
    - arb pressure gauge
    - staun deflators
    - 2 pairs of gloves
    - breaker bar with 22mm socket
    - 2 lug keys
    - bag of mini fuses
    - extra lug nuts
    - winch controller
    - arb tire repair kit
    - arb compressor hose
    - hi-lift base
    - med kit
    - arb tree saver
    - arb snatch strap
    - factor55 shorty strap
  23. May 22, 2018 at 3:00 PM
    Let's see
  24. May 22, 2018 at 3:04 PM
    HELLAFIED kit!!!
  25. May 22, 2018 at 3:04 PM
    TheBeast The Beach
    that's a legit kit !
  26. May 22, 2018 at 3:08 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s all stashed either under the seat in the storage box as well as behind the seat. My forward facing camera still doesn’t work on my phone LOL I’m cheap and it probably won’t get fixed until I need a new phone.
  27. May 22, 2018 at 3:10 PM
    :facepalm:
  28. May 22, 2018 at 3:16 PM
    OceanSkyWolf
    2017 MGM CM
    :amen::amen::amen:
    smslavin[QUOTED] likes this.
  29. May 22, 2018 at 3:17 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I know... maybe next time I’m cleaning the truck I’ll get a wild hair and snap some shots with the wife’s phone or my iPad. I’ve got it all neatly tucked away.
  30. May 22, 2018 at 3:26 PM
    As of now...
    Jumper cables
    Reflective vest
    Gloves
    First aid kit
    Extension socket wrench
