Roadmaster Active suspension review
Discussion in 'Suspension' started by thedonn, Feb 25, 2022.
  1. Jan 5, 2023 at 12:41 PM
    #151
    dhalsey
    dhalsey New Member
    Does anyone have any experience with the RAS at full stuff on the suspension in a off-road situation? Does it limit up travel? I know in theory it would but I haven't seen anyone confirm this in a real life scenario.
    Thanks in advance.
  2. Apr 13, 2023 at 5:48 PM
    #152
    Tonkatoytaco
    Tonkatoytaco New Member
    Louie
    Maryland
    2017 Platinum XP MGM
    LRO 3/1 Leveling Kit, Dirty Deeds 10" exhaust, Bully Dog Programmer, AFE Super stock Intake with TB Spacer, Custom Rough Country Grill, Andres Devil Horns, Caliraised Fog lights, Morimoto XB Headlights, HRS taillight, Boost Auto tow mirrors, LED interior lights and Reg, light, Trail edition bed compartment, TRD rear sway bar, weathertech floor mats and window visor, Nitto Ridge grappler.
    I see you are running air bags as well, Can I ask why you are running both and if you like both?
  3. Apr 14, 2023 at 3:51 AM
    #153
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Those aren't airbags, they are SumoSprings. Basically an extended bump stop
  4. May 9, 2023 at 12:06 PM
    #154
    pistolpete
    pistolpete New Member
    reporting back here. After my cross country and Baja trip I can confidently say that these were not enough suspension for the payload of the GFC camper and gear in the truck. The leafs are flat and the suspension bottoms out off-road pretty regularly. The handling isn’t bad, but there’s definitely sag.
    not sure what the next move is.
    Zem0001 likes this.
  5. May 9, 2023 at 12:08 PM
    #155
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Bummer. I’ve had about the same weight as you mention in mine. Were you running the HD version of the RAS dialed in to the max setting (larger spacer)?
  6. May 9, 2023 at 12:22 PM
    #156
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    This, and also the stock springs flatten easily, my Dobinsons are holding up well towing a ~7k lbs travel trailer with family up front and gear in the bed. I have my RAS HD set at the minimum setting.
  7. May 9, 2023 at 12:41 PM
    #157
    pistolpete
    Yeah, I installed the HD version to the max spacer right off the bat. I’m probably close to 700lbs back there in the bed, I even tried shifting all the heavy shit towards the center of the vehicle.
    I have nothing against the RAS I just think at this weight, it’s too much for the stock leafs. I think a leaf upgrade perhaps in conjunction with the RAS could be the move. One of the guys suggested Alcan from an off-road shop in San Diego, I know this forum really likes deavers. The tricky part is balancing the lighter unweighted truck…
  8. May 9, 2023 at 4:24 PM
    #158
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Airbags?
  9. May 9, 2023 at 5:50 PM
    #159
    CoffeeAddict
    2016 Tundra CrewMax
    I only have the regular Dobinsons not the “HD” version of them, but if memory serves their capacity is +150lbs each over stock. I’m hoping the RAS HD helps prolong their life and with our narrow Tundra leaf spring size I’m under no illusion they’ll last forever, but so far so good! For reference, I have ~2500 miles with some gear in the bed and towing the 7000lb trailer and ~26,000 total miles on the springs.
    I’ve already posted this but I’ll repeat, the ride is much better unloaded and loaded with the Dobinsons + RAS HD setup. The ICON 2.0 VS shocks I got from Demello round out my rear suspension in the rear(2.5 VS CDCV’s in the front), and I love the setup!
    WFD473 likes this.
  10. May 10, 2023 at 2:17 AM
    #160
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Can you add a link for the Dobinsons please?
  11. May 10, 2023 at 6:11 AM
    #161
    CoffeeAddict
    2016 Tundra CrewMax
    pistolpete and Bergy24[QUOTED] like this.
  12. May 10, 2023 at 4:59 PM
    #162
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    We started carrying the Roadmaster Active Suspension kits over here at Hotshot Offroad - And we actually are running a promo for $40 off of an HD kit (discount in checkout) for the next week :spy:
    https://hotshotoffroad.com/products/active-suspension-kit-14-21-tundra-1
    @pistolpete do you have a lift in the rear? Or rather... what is your goal height over stock in the rear? It certainly sounds to me like your stock leafs are definitely not up to the task of managing that weight.
  13. May 17, 2023 at 6:17 AM
    #163
    pistolpete
    I installed Fox 2.0 in the front and rear. Nothing more. The length of the 2.0 rears is a longer shock that probably adds negligible amounts of lift.
    I’ve taken all the weight out of the bed since being home and the truck drives pretty great empty with my current setup. Those dobinsons might do the trick to just slightly boost payload back there.
  14. Jun 21, 2023 at 5:58 AM
    #164
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Has anyone experienced driveline vibrations just after takeoff with RAS?
  15. Jun 21, 2023 at 6:01 AM
    #165
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    I have not, but I am only at the 25% spring rate. Are you at the 40%? If so, that amount of lift could be causing your vibrations. If you can try dropping to the 25% and seeing if it goes away, that might help figure out what's going on.
  16. Jun 21, 2023 at 6:20 AM
    #166
    ZPhilip
    Philip
    West Chester, PA
    Thanks. I will keep that in mind. Although the CB 0-2” carrier bearing drop kit is cheap enough to just try that first. Should be a lot faster than adjusting the RAS.
  17. Jun 21, 2023 at 6:26 AM
    #167
    MadMaxCanon
    I would do the CB kit definitely. It will take you 5 minutes to install.
  18. Jun 21, 2023 at 6:51 AM
    #168
    Eborseti22
    Evan
    Agreed if he's at the 40% mark.
    Yea don't disagree with that...are you at the 40% (black puck) or the 25%?
  19. Jun 21, 2023 at 7:39 AM
    #169
    MadMaxCanon
    Honestly, you could probably just thrown some washers on there and try it out before commiting to the kit. You should have enough thread on the stock bolts to get a decent amount of washers in there. But, if you are getting the vibrations then you plainly just need the drop anyway so the kit wont be wasted.
    ZPhilip likes this.
  20. Jun 21, 2023 at 9:54 AM
    #170
    ZPhilip
    Philip
    West Chester, PA
    I went with the thicker disc, think it is the black one.
    Eborseti22[QUOTED] likes this.
  21. Jun 21, 2023 at 1:05 PM
    #171
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    When I set it with black shim with factory shackle or white shim with toytec 1” shackle and bed empty, there’s a little vibration at takeoff..
    ZPhilip[QUOTED] likes this.
  22. Jul 2, 2023 at 4:41 PM
    #172
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    HD kit ordered, $76 off :D
    bulldog93, Winning8 and MadMaxCanon like this.
  23. Jul 3, 2023 at 2:39 PM
    #173
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    Black shim with new Eibach 2.0s all the way around, really happy overall so far. Getting alignment dialed in next weekend, then hooking up the trailer next weekend for the real test.
    bgdv1 and bulldog93 like this.
  24. Jul 6, 2023 at 3:37 AM
    #174
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    I'm looking at these as a possible solution to a situation I have. Maybe someone who knows more about these then I do can help me out here. I have a 2019 crewmax with a 4" Pro Comp bracket lift installed. I bought the truck with the lift already installed. It's not the rout I would have chosen to go but it's on the truck so I will work with it. I'm doing some upgrades with new coil overs up front and shocks in the rear. At the moment the rear of the truck is squatting. I don't know if the rear has always been this way or if the spring pack has lost some of it's springyness, if that's even a word. But regardless the rear sits at least one inch lower then the front and is something I want to fix. It uses a block under the axel to achieve lift. Here is what it looks like under the truck.
    So here is my thinking. First get rid of the spacer block. Then get some Coach Builder or equivalent shackles. Lastly get a set of these Roadmaster active hooky loows.
    So my questions would be first, is there any advantage to getting rid of the spacer block and going with the CB shackles? I'm assuming there is.
    If I do get rid of the spacer block and go CB what size CB shackles will I need to bring the rear up to level with the 4" front lift if combined with the Roadmasters? I gather they will add an additional 1 1/2" of lift all by themselves?
    Will the Roadmasters help correct for a flat or sagging leaf pack?
    Being a contractor my truck can see some pretty heavy loads put in the bed and I'm not always, but often enough, pulling fairly heavy trailers. One such heavy load I recently hauled may have caused the rear to sag or it might have been that way from the start and I just didn't recognize it but it is definitely squatting. I've had the truck for almost a year now and I'm thinking I would have noticed before if it was squatting but it isn't something that is really obvious unless you are looking at it from a little ways away you might not even realize it. So I don't know. I might need a new leaf pack but I'm already going to be spending a small fortune on the new shocks and coil overs and I don't want to have to spend money I don't have to at this point so.
    Does it look like the leaf pack is going flat from the pics? I really can't tell.
    Although the lift kit should have supplied larger bump stops it looks like the ones I have on the truck are the stock factory bump stops. So I should probably put new stops on my grocery list.
    If someone could help answer my questions I would appreciate it. I'm a total newb when it comes to all of this off road suspension stuff. All I know is this stuff is expensive I don't want to waste my money buying things that aren't going to meet my expectations or won't work so I'm trying to do my research before shelling out the cash.
  25. Jul 6, 2023 at 7:37 AM
    #175
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I think it is better to get new leaf spring at this point
    Cthulhu, CoffeeAddict and MadMaxCanon like this.
  26. Jul 6, 2023 at 10:22 AM
    #176
    CoffeeAddict
    2016 Tundra CrewMax
    This. If your stock leaf springs are toast, start there. I’m not a spring expert but if the truck is sagging, it’s sagging and you probably have your answer? The RAS will supplement your new leaf pack but they’re not primary suspension parts. New leafs with 1/2-1” lift less than you want with the RAS HD added will get you where you want to be.
  27. Jul 6, 2023 at 10:52 AM
    #177
    art64
    art64 New Member
    I strongly cautioned using Roadmaster with a lift block. RAS puts a lot of pressure on that area. That pressure can also cause the axle to rotate upwards so the driveline will move towards the bed of the truck and causing vibrations and it can cause misalignment, shifting or worst failure of the u bolts.
    Looking at that picture, don't use longer shackles. The springs are flat already and with longer shackle it will allow the top spring, which is hooked up to the shackle, to bend further and can break.
    If you're going to replace the springs, go with a custom one to account for the height and weight of the load, so you don"t have to use lift block.
    Air bags- yes it can be done with some customization like using longer bracket to accomodate for the lift. We don't want the bags to be too extended to get the lift that is desired. The air pressure can be too much and will provide harsh ride.
    CoffeeAddict likes this.
  28. Jul 6, 2023 at 1:43 PM
    #178
    Jack_A_Lope
    Aaron
    I should probably just bite the bullet and get a new leaf pack then. Better to be on the safe side I guess. So is everyone off the opinion that the leaf pack has gone flat? Is there anyway to know for sure?
  29. Jul 6, 2023 at 2:45 PM
    #179
    art64
    art64 New Member
    It is not super flat. Probably looked like mine but with the weight you’re carrying it will flatten really quick. It still have some space between the overload spring (bottom) and the next leaf spring on the last picture. I’m thinking too that if the truck didn’t have 5 inch lift, the rear wouldn’t sag. If you were close to me, I’ll have you try my firestone airbags with extended bracket. Not installed on my Crewmax right now. How much are you carrying?
  30. Jul 8, 2023 at 10:50 AM
    #180
    DZ_
    DZ_ New Member
    Frederick Co., MD
    RAS arrived, after being delivered into my neighbor's garage... who then shut their garage and didn't noticed until today :facepalm:
    Preload question: has anyone set a little more tension on the driver's side to counteract the lean?
    MadMaxCanon likes this.
