Roadmaster Active suspension review
Discussion in 'Suspension' started by thedonn, Feb 25, 2022.
  1. Mar 28, 2022 at 9:29 AM
    #91
    lakedrum03
    lakedrum03 New Member
    Seth
    2021 Tundra Platinum
    Working on it.
    Planning to install my HD's this Thursday evening.
  2. Mar 29, 2022 at 7:18 AM
    #92
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    yes, i had to take the side of the back shackle off.....not hard to do....
    and yes, when i unloaded the leaf springs to set the tension on the RAS, i noticed it hits.... not sure how to prevent this... but its only when its completely unloaded
    MadMaxCanon[QUOTED] likes this.
  3. Mar 29, 2022 at 1:15 PM
    #93
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    Just installed mine on Sunday, and am very pleased with the way it rides.
    I have 130K on stock springs and could feel a little soft/ uneasy while driving down the free way.
    Noticed it also helped with axle wrap and and planting those tires to the road.
    Also it raised the back about an inch, and I went with the HD kit & used the white disc 1mm setting.
    WFD473 likes this.
  4. Apr 1, 2022 at 4:16 AM
    #94
    lakedrum03
    Seth
    Working on it.
    Did my install last night. Took me about an hour while working with the truck on a lift. I set them to the white spacer and felt an instant improvement. Big test will be next weekend when we take the boat on an 8 hour road trip to TN from Ohio.
    WFD473, Chucho and 18DCTRD like this.
  5. Apr 1, 2022 at 4:27 AM
    #95
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Did you go with the standard or HD version? What kind of boat will you be towing? How much sag did you have with the boat before and after the RAS install?
    I ask because I got my Tundra late last year after we were done boating, I hooked our boat (2019 Ranger 212LS, 91% full on gas but no fishing gear) up last weekend to start getting it ready for the season and it only dropped the rear of the truck about 1/2". Not looking to lift the rear, just want to prevent the drop when towing. I expect once I have all the gear in the boat it'll drop the rear of the truck a bit more but it isn't significant so I'm think of just getting the standard version. Looking forward to hearing you thoughts after your trip.
  6. Apr 1, 2022 at 7:05 AM
    #96
    lakedrum03
    Seth
    Working on it.
    I went with the HD at the 25% setting and got about an 1" of rise. I have a 21' Mastercraft which is an inboard wakeboard boat that weighs about 5000 lbs fully packed for vacation and it over 12' tall with the tower. I get about 1.5-2" maybe total sag, which isn't terrible. I do notice that the rear end is "squishy" with the boat and I am excited to see how much the RAS helps with planting the truck and making it more stable on the highway.
  7. Apr 4, 2022 at 3:18 AM
    #97
    Gaston
    Gaston New Member
    Gary
    SE MI
    Thank you for the reply. I believe my boat weighs just slightly less fully loaded but I plan to get it weighed once I have it fully loaded. Look forward to hearing your thoughts after your trip.
  8. Apr 4, 2022 at 8:33 AM
    #98
    lakedrum03
    Seth
    Working on it.
    Got the boat out of storage this weekend. This is basically empty and there is probably 500 lbs that needs added for regular service. Vacation trim will probably add 1000 lbs.
    Truck is pretty level now, so would be expecting a little sag with vaca weight. For the vacation trip, I may tighten it up a bit.
  9. Apr 4, 2022 at 8:53 AM
    #99
    Gaston
    Gaston New Member
    Gary
    SE MI
    Nice looking truck and boat. I haven't snapped a picture of my truck towing the boat yet lol. Did have it out this weekend for the first time and slid down the ramp on ice while launching the boat, first time that's ever happened, thought I was going in for sure, luckily I stopped right before my back tires hit the water after sliding about 8ft or more.
  10. Apr 4, 2022 at 9:06 AM
    #100
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    I have OME shackles(OMEGS222), that allow for greasable pins/bushings. It’s supposed to be a stock replacement but they’re really almost 1/2” longer. Zero issues with the RAS HD install.
    I do have Dobinson’s leaf springs as well, I had to knock the rear spring clamp of the leaf pack back with a sledge a bit to make room for the RAS HD and the RAS barely reached at first but it wasn’t a huge deal once I figured it out. I forgot to log the heights before and after leaf pack replacement, shackles, and RAS HD, but the RAS HD bumped the rear maybe 1/2”. The springs were about 1.5” from stock by estimate, my stock packs were collapsed so no good comparison available there.
    Performance review: Love them so far with one towing trip with the travel trailer and about 500 miles of normal mixed driving. Huge difference towing, they really help with porpoising/bouncing on rough roads and smooth everything out and with significantly less sag. I had to re-tune my WDH as it didn’t have to do as much work, and lower the hitch because of the lack of sag. Road manners are also much better, even bombing down bad roads with a mix of gravel and broken asphalt. No kicking out to the side at all, between my ICON shocks, Dobinsons, and the RAS HD I’m absolutely loving the suspension on the truck now. I set mine at the minimum with the white disk slipping in and out with a tiny bit of friction.
  11. Apr 11, 2022 at 4:41 AM
    #101
    lakedrum03
    Seth
    Working on it.
    Got back from our 1,023 mile, 18 hour, road trip. We had the boat on the back for half that. Truck felt way more planted and stable while we were cruising the highway. Previously, the truck felt "squishy" and would bounce on the highway with the boat. Even without the boat, the truck felt way smoother overall. I am impressed with the performance and would recommend anyone to do this update.
  12. Apr 14, 2022 at 9:49 AM
    #102
    Dansly56
    Dansly56 New Member
    daniel
    Dude this is what I need as I’m having sag issues and I feel like it’s my leaf pack and shocks that are stock and have 82k miles on them. I have RAS, Timbrens and TRD sway bar with a WDH and still sag 1.5”
  13. Apr 15, 2022 at 8:13 PM
    #103
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    So I installed my RAS HD today along with CB +3, durobump stops, bilstein 5160 and used brand new u bolts and nuts, also I took off my sway bar. I set the RAS slightly bigger than the white disc. I really like the setup on my short drive. No weird noises or vibration. I used the CB carrier bearing drop kit for 0 to 2 inch lift, plus I added 2 standard size washers, just in case, since I'm passed 2 inches. Also installed CB abs line relocation kit.
    Planning to load up the back tomorrow with some weight and go for a little drive. I'll be checking torque in 500 ish miles.
    I initially tried to use the CB +1 shackles but I can confirm they didn't fit. I needed about a quarter inch more space. Oddly enough pushing out my stock bushing was really easy with some pb blaster and the fact that the trucks only a year old.
  14. Apr 15, 2022 at 8:42 PM
    #104
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd check torque on the U bolts after 50 miles, then do 500.
  15. Apr 15, 2022 at 8:42 PM
    #105
    MadMaxCanon
    Good lookin out
  16. Jun 9, 2022 at 1:15 PM
    #106
    Blue Thunder
    Washington
    Installed the HD version a few days ago. Set the tension to the 2mm shim and got 2” of rise (measured at the wheel well). Not sure I’ll keep it that high, but want to tow with it first before making any adjustments. I was dead level before the install and had at least 1.5” of negative rake while towing. I don’t care so much about being level when towing, just need to stop the bouncing and improve overall stability.
    Only driven about 35 miles so far, but I’m pretty impressed.
    MadMaxCanon and CoffeeAddict like this.
  17. Jun 11, 2022 at 3:44 PM
    #107
    bflooks
    bflooks New Member
    Metrowest MA
    Also just installed the HD model and got 1/2" of additional lift using the white disc.
    Initially it was 7/8" when set with the back disc, and on top of the CB +2 and air bags with cradles, it was too high for my liking.
    Both extra heights forced me to change the mounting of the TRD sway bar to avoid contact with the springs. All is well now and no more clanking.
    I took measurements and headed to the scales to see how badly the WDH was off. Changed things by about 60lbs on the front axle, so it'll be need some relatively minor adjustment. Overall, the ride is already very much improved and axle wrap with the 5.29s is reduced as well.
    Took a second to realize how to make this work with the lower bag mounts, but it is doable.
    I regret not adding these until now, and that is after only one short tow. Def tames low speed porpoising.
    frichco228 and MadMaxCanon like this.
  18. Sep 6, 2022 at 6:30 AM
    #108
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    So will the HD RAS fit with the TRD Rear sway bar and everything else stock?
    KingsAustin likes this.
  19. Sep 6, 2022 at 6:34 AM
    #109
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Yes, fits stock with TRD sway. It is going to lift the rear about an inch, and you may need a carrier bearing drop to address take off vibration which often occurs when you lift the rear of the Tundra.
    IowaGuy[QUOTED] likes this.
  20. Sep 6, 2022 at 6:37 AM
    #110
    lakedrum03
    Seth
    Working on it.
    +1 on what frichco said. I have the rear sway bar and no issues.
    Bill3648 and IowaGuy[QUOTED] like this.
  21. Sep 7, 2022 at 7:03 PM
    #111
    BPMOUCO
    BPMOUCO New Member
    2019 Tundra Crew Limited TRD
    Looking for some guidance. I just had Bilstein 6112/5160 setup installed with the front at the top setting with CB shims and 3” CB shackles in the rear with the carrier drop kit.
    Running 17” Fuel wheels with 35” Wildpeaks.
    I have a decked drawer system and an ARE topper for about 500 lbs loaded in/on the bed.
    I’m almost level in the rear, but there’s a slight sag.
    Loaded up for our normal camping load out and had a ton of sag.
    I run my trucks off-road overlanding and am looking for a solution that would keep me level in the rear and with the ability to tow a light <5k lb trailer.
    Would this setup be a good approach or should I be looking at a new leaf pack or air bags?
    Any thoughts from anyone running a similar setup? This truck gets run off road so I do care about offroad capabilities too.
    ConcordCarlos likes this.
  22. Sep 7, 2022 at 7:17 PM
    #112
    MadMaxCanon
    Crank the RAS to a little over the black disc. It will give you more lift and less sag.
    I run the same setup in the rear and I have my RAS set at between the white and black disc. I'm at exactly 2.5 inch rear lift.
    DiamondW likes this.
  23. Sep 7, 2022 at 7:18 PM
    #113
    BPMOUCO
    BPMOUCO New Member
    That makes sense. No concerns about the 3" shackle + the RAS?
  24. Sep 8, 2022 at 5:09 AM
    #114
    lakedrum03
    Seth
    Working on it.
    Lots of opinions there. The RAS will level you out but it is a static piece. If you wanted to have full mobility of the suspension with the softest possible spring rate, then I would recommend the air bags. You can pump them up when loaded on the road, then dump them on the trail.
  25. Sep 8, 2022 at 5:24 AM
    #115
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Just removed my airbags with daystar cradles and coachbuilder shackles. I’m installing RAS today. Will report back.
    I did not like the airbags when empty. Back end always felt bouncier, no matter the PSI.
  26. Sep 8, 2022 at 6:12 AM
    #116
    BPMOUCO
    BPMOUCO New Member
    This is my struggle, I Offroad more than I tow, but we are looking at getting a small travel trailer or Offroad trailer next season. The shop that installed the lift recommended the air bags too, but I also don't want them to be bouncy when not in use...
  27. Sep 8, 2022 at 6:12 AM
    #117
    BPMOUCO
    BPMOUCO New Member
    How much weight were you running in the bed day to day? I don't want them to feel bouncier, but I think the static 400 - 500 lbs I carry around may be able to offset that.
  28. Sep 8, 2022 at 6:59 AM
    #118
    Terndrerrr
    Music City
    6UR-FE
    I have a retractable TCUSA bed cover, a Plano trunk full of tools, shovel & axe, and a 2nd battery in the bed. My static load is around 300lb all in.
    I have to think that the daystar cradles account for some of my problem. If you off-road at all, you need them. They install where your bump stop would on top of the leafs and allow the air bag to decouple from the leafs, which is EXTREMELY NECESSARY if you are fully articulating your suspension in off-road situations. Otherwise you could very easily tear the airbags apart.
    The cradles also reduce the space between the leafs and the frame by at least an inch. I wonder if that reduced space was part of my issue...
    They were great at reducing squat and the poor handling that comes with it when I was loaded down, but just annoyingly bouncy when unloaded (meaning, when I'm down to my static 300lb load).
    You can't dump them on the trail. Unless you mean remove them. The air bags need at least 5psi in them at all times. Otherwise, your suspension could fold and tear the rubber at full compression. Additionally, if you off-road, you need to use Daystar cradles with them to keep from tearing them apart at full droop. They reduce the ability of each side to fully compress due to both of these factors. I liked them when loaded down, but hated the feel with only 300lb in the bed. And I could never find a PSI where my back end wasn't noticeably bouncier. Probably partially due to the cradles, but if you do any off-roading, you have to run the cradles, too.
    kos221 and CoffeeAddict like this.
  29. Sep 8, 2022 at 7:02 AM
    #119
    CoffeeAddict
    2016 Tundra CrewMax
    I’ve never had air bags but this post seems completely backwards. RAS is not static, it’s progressive, although I think I understand what you mean in that it’s largely set and forget. Depending on how you set it, it’s hardly noticeable during unloaded driving unless you hit bumps or hard turns, or small jumps for that matter. In those cases you’re right, the RAS springs always kick in but that’s when you want them working.
    Maybe you’re talking about if you have cradles and a lift so the air bags are not making contact when aired down?
    A better question might be how many have disliked the RAS and removed it after install vs how many have removed airbags. I’ve read of many, many people who have removed air bags and known people in person who have, and maybe one ever who removed RAS.
    Terndrerrr likes this.
  30. Sep 8, 2022 at 7:04 AM
    #120
    CoffeeAddict
    2016 Tundra CrewMax
    Would love to hear your comparison review after some time with RAS. Your experience matches everything else I’ve heard.
