road force balance
Discussion in '2nd Gen Tundras (2007-2013)' started by GROUNDHOGPHIL, Jun 16, 2019.
  1. Jun 16, 2019 at 4:27 PM
    GROUNDHOGPHIL
    GROUNDHOGPHIL [OP] New Member
    2008 TOYOTA TUNDRA SR5 DOUBLE CAB
    anyone ever have to road force balance their tundra tires , I have tried several tire shops over the years to spin balance my tires with NO luck . I always have to get them road force balanced and it does not matter if I buy cheap tires or name brand / why only the tundra ? 2008 TUNDRA SR5 4X4 5.7L
  2. Jun 16, 2019 at 4:39 PM
    I have not. Hopefully someone will chim in and answer your question.
    Welcome from NY.
  3. Jun 16, 2019 at 4:49 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    What size sidewall do you have?
  4. Jun 16, 2019 at 5:19 PM
    MoreCowbell
    MoreCowbell New Member
    2019 1794 Crew
    None
    I agree. Never heard of this til I bought my Tundra. But, mine was road-forced balanced several times by the dealer and another place and still had a shimmy in my steering wheel between 50-65 mph. Took an engineer from Toyota to finally resolve. He tweaked my alignment and claimed everything else checked out per Toyota specs. I say B.S. Something fixed it and I’m pretty sure it wasn’t the alignment.
  5. Jun 16, 2019 at 6:41 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Road force balancing is a better way to balance a tire. If you are putting force onto the tire while spinning it, you can better determine a truer "zero-point" balance. When I bought my tires I had one that was unable to be road force balanced but able to be regularly spun balanced. Since I supplied the tires, I called the manufacturer directly to see what they would say. They said "no problem, we'll you one right away, do you want us to send it to your shop?" The new tire came in 2 days, I watched them road force balance the tire and it is no joke... Definitely a better balance. I rotate every 2500 miles and they still feel perfect after 18k miles. I guess if it is a recommended method it can only help the overall situation of balance/alignment/smooth ride.
  6. Jun 16, 2019 at 6:43 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    The guys at my Discount Tire hate Tundras. They say they are the worst vehicle to get balanced.
  7. Jun 16, 2019 at 6:45 PM
    I bought my RG's in December at Discount Tire and they road forced them as part of the install.
