Rim width for 275/65r20 KO2's?
Discussion in 'Wheels & Tires' started by 18TRDSport82, Apr 15, 2018.
  1. Apr 15, 2018 at 3:24 PM
    18TRDSport82
    18TRDSport82 [OP] New Member
    Justin
    2018 Trd Sport 4x4
    Bfg ko2s Flowmaster exhaust
    Hello I have a 2018 tundra TRT sport And havd already put BFGoodrich Ko2s on my stock 20“ x 8 wheels. I want to change out the stock wheels because they are hideous, but the rims that I want only come in 20“ x 9. The size tires I have are 275/65r20 and was wondering if anyone could help me know if an inch wider rim on those tires will be ok and look ok. The reason I’m asking is because I was impatient and already spent the good amount of money on the tires and don’t want to have to replace those as well. Thanks and any suggestion will be appreciated!
  2. Apr 15, 2018 at 3:35 PM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    TC LT w/ king 2.5 C/O and bypass, ADS bypass rear, Toytech shackles, TRD dual exhaust dumped, KM3 37s on Method standard +18. N_Fab front bumper, Westin rear w/ hitch relocate, RCI skids, Desert Eagle tranny skid, All Pro sliders, ARB dual compressor, 5.29 gears and ARB rear locker
    Summit racing says 9.5" width max for that size tire.
    https://www.summitracing.com/search...recommended-wheel-width/9-50-in/load-range/sl
    18TRDSport82 [OP], Bob and 040Tundra like this.
  3. Apr 15, 2018 at 3:48 PM
    18TRDSport82
    Justin
    2018 Trd Sport 4x4
    Great news thank you for your reply!
    831Tun likes this.
  4. Apr 20, 2018 at 10:49 PM
    Cobeez
    Cobeez New Member
    Nick
    2012 White Tundra CrewMax TRD
    20" Black Toyota Rims 275/65/20 Sierra Radial A/T Tires 2" Leveling Kit Tow Mirrors w/ Side Markers
    I just put those exact tires on new rims today. 20x9 Ultra x108’s. They look awesome!!51E05F2E-4261-467A-A15B-8677E17CA949.jpg
  5. Apr 21, 2018 at 11:08 AM
    Big Green Thing
    Big Green Thing My cause is to have no cause.
    Dallas, TX
    '17 Limited White 4x4
    DAP Tune. 1.5" level on front. Revolver X2 Roll Back. Firestone 2445 air bags. TRD sway bar.
    I am looking to put that exact tire on my CM. No lift, but I do have a 1.5” leveling spacer on the front. Do you guys think they will fit without rubbing? I have the 20x9 TSS wheels.
    18TRDSport82 [OP] likes this.
  6. Apr 24, 2018 at 3:13 PM
    18TRDSport82
    Justin
    2018 Trd Sport 4x4
    My CM has no lift with stock suspension with that tire and it only rubs slightly during light flexing all the way turned on the inner part of the mud flap, which is an easy fix. But 99 percent of the time normally driving it doesn’t happen so it doesn’t bother me and I forget about it lol.
    Big Green Thing and outdoorboy like this.
  7. Apr 24, 2018 at 3:19 PM
    18TRDSport82
    Justin
    2018 Trd Sport 4x4
    Thanks for the pick! Looks great.
    Big Green Thing likes this.
  8. May 28, 2018 at 1:04 PM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Would you mind posting a pic of your truck with the KO2's? Thinking of going this same route. Thanks!
  9. May 28, 2018 at 2:54 PM
    18TRDSport82
    Justin
    2018 Trd Sport 4x4
    This is a pick of the ko2s after I put 20x9 method wheels. They didn’t rub at all before the rims were installed but the rims have an small offset and now they rub a lot. Also in the picture I very recently put on a set of fox 2.5 coil overs which gave me a 2inch front lift and now it’s alot better. But again if your going to just put the same tires on stock rims you won’t have a rubbing issue. Hope this helps.
    757TUNDRA likes this.
  10. May 28, 2018 at 3:42 PM
    18TRDSport82
    Justin
    2018 Trd Sport 4x4
    Here’s a pick of the ko2s on my stock rims before the lift and the methods, if this helps better, sorry I didn’t think I had this picture still lol.
  11. May 28, 2018 at 4:01 PM
    757TUNDRA
    Illinois
    Thanks, looks great!
  12. May 28, 2018 at 4:54 PM
    Landman500
    Landman500 New Member
    joseph
    2016 Tundra double cab limited try off road
    Stocks wheels powder coated look pretty good
  13. Jun 2, 2018 at 8:03 AM
    LifeCycle
    LifeCycle Build..build..build..
    Hugh
    Barcelona Red SR5 XP CM 2017
    TRD Dual exhaust TRD headlights bedmat Elka with adjustment knobs, ARB leafs-ring Fuel Crush +1 offset 20 inch 5 in backspacing TOYO open country 275/65 R20
    looks great!!
    what psi you running on these tires?
