Rigid Lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by timkf1, Sep 7, 2020.
  1. Sep 7, 2020 at 5:22 AM
    timkf1
    timkf1 [OP] New Member
    Limited Tundra
    Zero
    Hi, I'm trying to find out how I can adapt Rigid SAE D Series Fog Lights to the factory harness? Not sure what type of bulb is factory on a 2020 Limited. Connectors are different. I'm thinking there's an adapter harness available, but the one's I've seen reference specific bulbs, and I'm not sure what the factory harness fits, to know which adapter to purchase.
    Anyone know?
  2. Sep 7, 2020 at 5:27 AM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    timsp8, timkf1[OP] and YotaMan like this.
  3. Sep 7, 2020 at 5:39 AM
    timkf1
    Limited Tundra
    Zero
    That's AWESOME. Thank you SO MUCH!
    Bob_Wiley likes this.
  4. Sep 7, 2020 at 5:44 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Go with Diode Dynamics SS3 sae fog lights. They are designed to work with oem housing. They provide you with the adapter to connect to oem wiring. And last but not least, they will out perform the rigids all day, every day.
    Black Wolf likes this.
  5. Sep 7, 2020 at 5:54 AM
    timkf1
    Limited Tundra
    Zero
    I looked at those as well, but already purchased the RIGID's. I'm seeing other "for sale" posts, with brackets too - Are those necessary? I pulled the fender liner out yesterday and couldn't tell if it was a MUST or not. Got stuck with the adapter harness, which I just ordered this morning.
  6. Sep 7, 2020 at 5:55 AM
    timkf1
    Limited Tundra
    Zero
    That, and I already purchased the TRD PRO bezel's so the square lights will fit... $70.00
  7. Sep 7, 2020 at 5:57 AM
    Bob_Wiley
    Eric
    AZ
    Yes, you’ll need an L-type bracket to mount the rigids, but they’re fairly cheap.
    timkf1[QUOTED][OP] likes this.
  8. Sep 7, 2020 at 5:57 AM
    Danman34
    Danman34 New Member
    Danny
    Yes, you will need the brackets.
    timkf1[OP] likes this.
  9. Sep 7, 2020 at 5:58 AM
    Bob_Wiley
    Eric
    AZ
  10. Sep 7, 2020 at 7:33 AM
    brobert225
    brobert225 Firm grasp of the obvious
    Easy mod, get the harness on eBay and make the bracket from an ell bracket from Lowe’s.
  11. Sep 7, 2020 at 7:37 AM
    timsp8
    NY
    I’ve been looking at the fog light adapters with bare wire on the other side for awhile, but I was too lazy to do it yet. I didn’t know they made rigid specific ones. You just saved me some wiring trouble. Thanks.
    timkf1[OP] and Bob_Wiley[QUOTED] like this.
  12. Sep 7, 2020 at 7:43 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I wasn't able to find any L brackets locally, but the ones @Bob_Wiley posted from Grainger would be great. I ended up using some garage door track brackets, hit with a couple coats of primer to keep them from rusting (hopefully).
    timkf1[OP] and Bob_Wiley like this.
