Rigid industries LED fog lights
Discussion in 'Lighting' started by cjscinta, Feb 11, 2018.
  1. Feb 11, 2018 at 4:06 PM
    cjscinta
    cjscinta [OP] New Member
    Nashville TN
    i see they are putting these on the 2019 TRD Pros. Does anyone know if they are making a plug and play option for the Tundra yet? I looked on their website and couldn’t find anything for the tundra. A link would be great. :)
    Piki and Black Wolf like this.
  2. Feb 11, 2018 at 4:18 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Not sure if they make a PnP adapter but someone like @BlueBottle could tell ya to put one together.
  3. Feb 11, 2018 at 4:36 PM
    cjscinta
    Nashville TN
    Thank you. I’ll give it a shot.
  4. Feb 11, 2018 at 4:42 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I would just wait till rigid releases it. Or you can always buy the Toyota part #s once it’s available. @Roman should be able to help with that.
    The Toyota mounting should be solid compared to the current rigid mount available. I would opt oem anytime.
    Roman and 831Tun[QUOTED] like this.
  5. Feb 11, 2018 at 5:02 PM
    cjscinta
    Nashville TN
    Sounds like great advice. Thanks for the quick response.
  6. Feb 11, 2018 at 5:11 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Yes, rigid's mounts suck, but they can be made better. I added an extra piece to stop the jiggle, others have welded in a gusset to there mounting bracket to stop it. Mine no longer jiggle, but I will still be looking to see what the OE mounts are like, because I am sure that they will look better than rigid's mounts.
  7. Feb 11, 2018 at 5:11 PM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    They do make a plug and play harness for the rigid lights, I have it on my truck. Now I'm not sure what style connector the '19 pro has, I have the dot legal rigid lights on my truck.
    And yes I want to see what the new mounting solution is that Toyota has cone up with. My brackets have gussets welded in and it does help alot but they still aren't rock solid. Hopefully the opening on the new mounts matches the standard size for rigid lights.
    831Tun likes this.
  8. Feb 11, 2018 at 5:22 PM
    Cuzican
    Cuzican New Member
    Louisiana
    This was my solution, as I didn't want to remove the mounts after getting everything in to weld a gusset in. All the mount issuses aside, the Rigid SAE duallies are awesome little lights.
    831Tun and 14burrito like this.
  9. Feb 12, 2018 at 6:55 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    I like that, I may try that in conjunction with the gusset.
    And your right the sae duallies are awesome.
  10. Apr 12, 2018 at 7:44 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    My future mods are those Rigids and the TRD Pro honeycomb grill.
  11. Dec 26, 2019 at 3:50 PM
    StoneBoy18
    StoneBoy18 New Member
    kevin
    2018 black sport
    3.5” rough country lift
    how did you guys wire the lights? just connect them to your factory wiring?
  12. Dec 26, 2019 at 3:53 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    Yes, factory wiring. You can buy a connector that is plug and play from the rigid to factory fog light
  13. Dec 26, 2019 at 3:57 PM
    StoneBoy18
    kevin
    2018 black sport
    i just cut the factory plug end off the wires, and hard wired mine. just got done with it this evening. checked made sure they came on and everything before i buttoned everything up. got in it to drive down the road to see how i liked them, they weren’t on. checked fuses, i had blown the factory fuse under the hood. went out and bought fuses. the factory is 15 amp. i put a 20 in it, and they come on, but very dim. i don’t understand what happend
  14. Dec 26, 2019 at 4:00 PM
    StoneBoy18
    kevin
    2018 black sport
  15. Dec 26, 2019 at 5:04 PM
    How are the wires connected? Solder, heatshrink, splices? It sounds like a short, especially if they were bright initially.
  16. Dec 26, 2019 at 5:27 PM
    StoneBoy18
    kevin
    2018 black sport
    just butt connectors. that’s why i don’t understand what’s going on. i put a 20 amp fuse in, and they turned on and were bright like they’re supposed to be, then got ready to pull out of the auto store, they went out again. i put a 25 amp fuse in, and the fuse never blew, but now they are very dim, and eventually goes out. i’m lost on it. i guess i’ll just take everything back apart tomorrow and see if i can figure it out. my thoughts were that the factory wires weren’t big enough. but everyone is saying that they use factory wires.
  17. Dec 26, 2019 at 5:35 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    What model lights are those and what did you have stock, LED or halogens? I swapped in some D-series for my factory LED fogs without an issue, but I also used an adapter from Cali Raised for the wiring. Do you have the polarity reversed or anything?
  18. Dec 26, 2019 at 5:39 PM
    StoneBoy18
    kevin
    2018 black sport
    they’re “D series pro” and i had LED factory. the only thing stumping me is that they came on super bright just like they’re supposed when i was first installing. but now they’re not.
  19. Dec 26, 2019 at 6:42 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I'd double check your polarity and make sure you don't have the wires backwards. Some LED drivers are sensitive to that.
  20. Dec 26, 2019 at 7:45 PM
    Yes factory wiring is fine for them. I have them in my truck. As mentioned, I would switch the wires and see what happens.
  21. Feb 19, 2020 at 4:27 PM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
  22. Feb 19, 2020 at 5:19 PM
    dekeman[QUOTED] likes this.
  23. Feb 19, 2020 at 5:25 PM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    Great, thanks!
  24. Feb 19, 2020 at 6:15 PM
    salmonfacesalad
    salmonfacesalad New Member
  25. Feb 19, 2020 at 6:16 PM
    salmonfacesalad
  26. Feb 19, 2020 at 7:53 PM
    Mgmtundra
    Mgmtundra MGM Crew
